    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 36.2k Views 27 Watching
      dbalex
      yes indeed, it looks like they have something to hide
      http://www.bocostudio.com
      • GaieusG
        Hi guys, here is a very quick and dirty example (probably e-on would not be proud of) I made when testing bump and reflection maps.
        http://dl.dropbox.com/u/25025526/Untitled.exe (Mac users, sorry but I did not export a Mac compatible version yet as I could not test it anyway)
        Note two things when loading:
        • the scene is a bit off my ground plane so if you start walking around, scroll a bit to zoom in and only then click the mouse.
        • LumenRT places your scene onto its ground based on the lowest point (in my case, the bottom of the pool) of the model so you can easily "fall off" if you have basements or such, deep pools (certainly I should have added a bigger ground plane to the model but again, it was just for a quick test, nothing "real" as a presentation)
          Press F1 to see all navigation and other options. Note that this model does not have SU scenes so exporting animation or playing it in kiosk mode is not possible (that was not part of my testing).
        I should probably make some better model/example to show. Here is what you can "expect".
        • jamalitoJ
          jamalito
          I liked to works Vue and it Versions
          but
          Will it be a good rival for Vray RT ?
          Albert Einstein:
          ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
          • GaieusG
            I cannot compare as I do not know Vray RT (to be honest, did not even know there is one).
            • jamalitoJ
              jamalito
              @jamalito said:
              no Mr Gaieus there are Vray RT and they release Vray RT 2.0 demo true I see it in Vray Max right now I don't know is there version to SU in true i wish ?
              you can see this Tutorial For Vray RT
              http://youtu.be/KOHcTDyR44o
              Albert Einstein:
                dbalex
                thanks gaieus for this little test, it's still not revolutionary I would say, maybe with more time you could achieve better results. Can you choose between multiple presets for the environment or you have just one? Can you render movies or is it only for realtime presentations to move around in your model?
                • GaieusG
                  There are more environment presets (neutral white, bad weather, nce weather - the one I exported - blue sky - with no clouds).
                  Also note that the above render was made with the poorest quality available (draft) and there are three more "levels".
                  If your model has animation scenes, after you launch the viewer, it will automatically start playing it. You can also export those animations just like a SU movie.
                    dbalex
                    ok so it looks like it's better than I thought, mmmh I'm tempted but as student I think it's still a little expensive for something I will not use everyday. Thanks Gaieus!
                    • N
                      Nicholas Phelps
                      Panga,
                      There's a user on the e-on registered forum who has a problem very similar to yours. The latest update appears to have solved his problem. Did you give it a try?
                      Best regards
                        dburdick
                        @panga said:
                        No,
                        I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
                        Hi Panga, were you able to get this problem resolved for your graphics card?
                        • P
                          Panga
                          Yes I was the user on e-on forums that encountered the issue ! Everything is fine with my graphic board now. 😉
                            dbalex
                            nice to hear! hope to see some rendered livecubes 😉
                              dburdick
                              Hi Everyone,
                              Just a heads up. There's a new update for LumenRT coming out this week. It includes a greatly improved ability to render very large models more efficiently with much better performance. More details are forthcoming on this later after the update is released.
                                dbalex
                                will there be a demo too?
                                • PixeroP
                                  Pixero
                                  +1
                                  • E
                                    Ecuadorian
                                    Will we be able to have a look at the forum before purchasing?
                                    -Miguel Lescano
                                    • N
                                      Nicholas Phelps
                                      Ecuadorian,
                                      Yes, we've been wanting to open up our registered user forum for a while but haven't gotten around to doing it yet (it requires some work on the forum engine to let everybody read, but only let those who have a registered copy post).
                                      We'll bump the priority on this a little more 😄
                                      Best regards
                                        dburdick
                                        On the demo version request, duly noted. We're looking into this.
                                          dburdick
                                          Just a quick note, LumenRT is up for plugin of the year in the annual 3D CG Awards
                                          http://cgawards.3dworldmag.com/
                                          Thanks to many of the people on this forum with their ideas and help to make this possible
                                          • deaneauD
                                            deaneau
                                            hi at all,
                                            LumenRT was my favorite, however i have try this on different pc´s.
                                            LumenRT doesn´t work on pc´s nvidia Geforce 9800GT
                                            Intel(R) Core(TM) QUAD CPU Q600 @2.40GHz 32 Bit WIN7 Ultimate.
                                            a newer paccard bell (R) imedia Windows® 7 Home Premium - Intel Core i5 (i5 - 2300, 2,80 GHz, 6 MB) - nVIDIA 1 GB - 4 GB DDR3 SDRAM - 1 TB Serial ATA - DVD - this work fine
                                            plus
                                            exe file is good when i dont want do give a file out of my hand.
                                            what i can see isn´t bad.
                                            navigation by the custumer/client
                                            animation like in sketchup
                                            plugin work on sketchup and sketchup pro 8
                                            different versions (download or DVD)
                                            work on WIN and MAC (macversion in a zipfile with password protection :-/)
                                            the price
                                            minus
                                            preprocessing
                                            no lights only sunlight
                                            not a demoversion only a livecubeversion (exe) both is better.
                                            only work for sketchup export from other apps isnt possible.
                                            my compares
                                            lumion work on a pc older than the packard bell(R)
                                            twinmotion work on older pc export from sketchup to 3ds (only for pro user :-/)
                                            my suggestion to pay for LumenRT
                                            insert lights, provide night scenes, let work the livecube on older PC/MAC
                                            insert animation that produced by other plugins in sketchup. provide a demo or trailversion.
                                            sorry for my bad english
                                            deaneau
                                            • 4 / 6
