    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 36.2k Views 27 Watching
      dbalex
      thanks gaieus for this little test, it's still not revolutionary I would say, maybe with more time you could achieve better results. Can you choose between multiple presets for the environment or you have just one? Can you render movies or is it only for realtime presentations to move around in your model?
      http://www.bocostudio.com
      • GaieusG
        There are more environment presets (neutral white, bad weather, nce weather - the one I exported - blue sky - with no clouds).
        Also note that the above render was made with the poorest quality available (draft) and there are three more "levels".
        If your model has animation scenes, after you launch the viewer, it will automatically start playing it. You can also export those animations just like a SU movie.
          dbalex
          ok so it looks like it's better than I thought, mmmh I'm tempted but as student I think it's still a little expensive for something I will not use everyday. Thanks Gaieus!
          • N
            Nicholas Phelps
            Panga,
            There's a user on the e-on registered forum who has a problem very similar to yours. The latest update appears to have solved his problem. Did you give it a try?
            Best regards
              dburdick
              @panga said:
              No,
              I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
              Hi Panga, were you able to get this problem resolved for your graphics card?
              • P
                Panga
                Yes I was the user on e-on forums that encountered the issue ! Everything is fine with my graphic board now. 😉
                  dbalex
                  nice to hear! hope to see some rendered livecubes 😉
                    dburdick
                    Hi Everyone,
                    Just a heads up. There's a new update for LumenRT coming out this week. It includes a greatly improved ability to render very large models more efficiently with much better performance. More details are forthcoming on this later after the update is released.
                      dbalex
                      will there be a demo too?
                      • PixeroP
                        Pixero
                        +1
                        • E
                          Ecuadorian
                          Will we be able to have a look at the forum before purchasing?
                          -Miguel Lescano
                          • N
                            Nicholas Phelps
                            Ecuadorian,
                            Yes, we've been wanting to open up our registered user forum for a while but haven't gotten around to doing it yet (it requires some work on the forum engine to let everybody read, but only let those who have a registered copy post).
                            We'll bump the priority on this a little more 😄
                            Best regards
                              dburdick
                              On the demo version request, duly noted. We're looking into this.
                                dburdick
                                Just a quick note, LumenRT is up for plugin of the year in the annual 3D CG Awards
                                http://cgawards.3dworldmag.com/
                                Thanks to many of the people on this forum with their ideas and help to make this possible
                                • deaneauD
                                  deaneau
                                  hi at all,
                                  LumenRT was my favorite, however i have try this on different pc´s.
                                  LumenRT doesn´t work on pc´s nvidia Geforce 9800GT
                                  Intel(R) Core(TM) QUAD CPU Q600 @2.40GHz 32 Bit WIN7 Ultimate.
                                  a newer paccard bell (R) imedia WindowsÂŽ 7 Home Premium - Intel Core i5 (i5 - 2300, 2,80 GHz, 6 MB) - nVIDIA 1 GB - 4 GB DDR3 SDRAM - 1 TB Serial ATA - DVD - this work fine
                                  plus
                                  exe file is good when i dont want do give a file out of my hand.
                                  what i can see isn´t bad.
                                  navigation by the custumer/client
                                  animation like in sketchup
                                  plugin work on sketchup and sketchup pro 8
                                  different versions (download or DVD)
                                  work on WIN and MAC (macversion in a zipfile with password protection :-/)
                                  the price
                                  minus
                                  preprocessing
                                  no lights only sunlight
                                  not a demoversion only a livecubeversion (exe) both is better.
                                  only work for sketchup export from other apps isnt possible.
                                  my compares
                                  lumion work on a pc older than the packard bell(R)
                                  twinmotion work on older pc export from sketchup to 3ds (only for pro user :-/)
                                  my suggestion to pay for LumenRT
                                  insert lights, provide night scenes, let work the livecube on older PC/MAC
                                  insert animation that produced by other plugins in sketchup. provide a demo or trailversion.
                                  sorry for my bad english
                                  deaneau
                                    dburdick
                                    @deaneau said:
                                    hi at all,
                                    Hi Deaneau,
                                    The GeForce 9800GT card should work. Can you try updating your graphics drivers on this card by downloading from NVIDIA and then trying LumenRT again.
                                    • deaneauD
                                      deaneau
                                      @dburdick said:
                                      @deaneau said:
                                      hi at all,
                                      Hi Deaneau,
                                      oh hi ill try answer for this later
                                      • deaneauD
                                        deaneau
                                        @dburdick said:
                                        @deaneau said:
                                        hi at all,
                                        Hi Deaneau,
                                        Hello bad news for me...my pc doesn´t work with lumenRT 😞(
                                          dburdick
                                          Version 1.2 of LumentRT is now released:
                                          http://www.lumenrt.com/
                                          Biggest changes include
                                          • the ability to render super large scenes (e.g. 1km x 1km) much faster using the new AutoScale lighting feature
                                          • faster preprocessing speeds
                                          Exisiting LumenRT users can download the update from their account page
                                            dburdick
                                            Here's a user spotlight on Ronen Bekerman, an early adopter of LumenRT:
                                            Ronen Bekerman Spotlight
                                            http://www.lumenrt.com/showcase/ronenbekerman/index.php
                                            http://www.lumenrt.com/showcase/ronenbekerman/images/TitleImage.jpg
                                            • 4 / 6
