    E-on-Lumenrt render for Sketchup
    extensions
    102 Posts 27 Posters 36.2k Views 27 Watching
    • jamalitoJ
      jamalito
      @jamalito said:
      @gaieus said:
      I cannot compare as I do not know Vray RT (to be honest, did not even know there is one).
      no Mr Gaieus there are Vray RT and they release Vray RT 2.0 demo true I see it in Vray Max right now I don't know is there version to SU in true i wish ?
      you can see this Tutorial For Vray RT
      http://youtu.be/KOHcTDyR44o
      Albert Einstein:
      ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
        dbalex
        thanks gaieus for this little test, it's still not revolutionary I would say, maybe with more time you could achieve better results. Can you choose between multiple presets for the environment or you have just one? Can you render movies or is it only for realtime presentations to move around in your model?
        http://www.bocostudio.com
        • GaieusG
          There are more environment presets (neutral white, bad weather, nce weather - the one I exported - blue sky - with no clouds).
          Also note that the above render was made with the poorest quality available (draft) and there are three more "levels".
          If your model has animation scenes, after you launch the viewer, it will automatically start playing it. You can also export those animations just like a SU movie.
            dbalex
            ok so it looks like it's better than I thought, mmmh I'm tempted but as student I think it's still a little expensive for something I will not use everyday. Thanks Gaieus!
            • N
              Nicholas Phelps
              Panga,
              There's a user on the e-on registered forum who has a problem very similar to yours. The latest update appears to have solved his problem. Did you give it a try?
              Best regards
                dburdick
                @panga said:
                No,
                I'm still unable to produce anything with it as the fix for my graphic card is not released yet...or did I miss something ?? Two or Three weeks after buying it... 😠
                Hi Panga, were you able to get this problem resolved for your graphics card?
                • P
                  Panga
                  Yes I was the user on e-on forums that encountered the issue ! Everything is fine with my graphic board now. 😉
                    dbalex
                    nice to hear! hope to see some rendered livecubes 😉
                      dburdick
                      Hi Everyone,
                      Just a heads up. There's a new update for LumenRT coming out this week. It includes a greatly improved ability to render very large models more efficiently with much better performance. More details are forthcoming on this later after the update is released.
                        dbalex
                        will there be a demo too?
                        • PixeroP
                          Pixero
                          +1
                          • E
                            Ecuadorian
                            Will we be able to have a look at the forum before purchasing?
                            -Miguel Lescano
                            • N
                              Nicholas Phelps
                              Ecuadorian,
                              Yes, we've been wanting to open up our registered user forum for a while but haven't gotten around to doing it yet (it requires some work on the forum engine to let everybody read, but only let those who have a registered copy post).
                              We'll bump the priority on this a little more 😄
                              Best regards
                                dburdick
                                On the demo version request, duly noted. We're looking into this.
                                  dburdick
                                  Just a quick note, LumenRT is up for plugin of the year in the annual 3D CG Awards
                                  http://cgawards.3dworldmag.com/
                                  Thanks to many of the people on this forum with their ideas and help to make this possible
                                  • deaneauD
                                    deaneau
                                    hi at all,
                                    LumenRT was my favorite, however i have try this on different pc´s.
                                    LumenRT doesn´t work on pc´s nvidia Geforce 9800GT
                                    Intel(R) Core(TM) QUAD CPU Q600 @2.40GHz 32 Bit WIN7 Ultimate.
                                    a newer paccard bell (R) imedia WindowsÂŽ 7 Home Premium - Intel Core i5 (i5 - 2300, 2,80 GHz, 6 MB) - nVIDIA 1 GB - 4 GB DDR3 SDRAM - 1 TB Serial ATA - DVD - this work fine
                                    plus
                                    exe file is good when i dont want do give a file out of my hand.
                                    what i can see isn´t bad.
                                    navigation by the custumer/client
                                    animation like in sketchup
                                    plugin work on sketchup and sketchup pro 8
                                    different versions (download or DVD)
                                    work on WIN and MAC (macversion in a zipfile with password protection :-/)
                                    the price
                                    minus
                                    preprocessing
                                    no lights only sunlight
                                    not a demoversion only a livecubeversion (exe) both is better.
                                    only work for sketchup export from other apps isnt possible.
                                    my compares
                                    lumion work on a pc older than the packard bell(R)
                                    twinmotion work on older pc export from sketchup to 3ds (only for pro user :-/)
                                    my suggestion to pay for LumenRT
                                    insert lights, provide night scenes, let work the livecube on older PC/MAC
                                    insert animation that produced by other plugins in sketchup. provide a demo or trailversion.
                                    sorry for my bad english
                                    deaneau
                                      dburdick
                                      @deaneau said:
                                      hi at all,
                                      Hi Deaneau,
                                      The GeForce 9800GT card should work. Can you try updating your graphics drivers on this card by downloading from NVIDIA and then trying LumenRT again.
                                      • deaneauD
                                        deaneau
                                        @dburdick said:
                                        @deaneau said:
                                        hi at all,
                                        Hi Deaneau,
                                        oh hi ill try answer for this later
                                        • deaneauD
                                          deaneau
                                          @dburdick said:
                                          @deaneau said:
                                          hi at all,
                                          Hi Deaneau,
                                          Hello bad news for me...my pc doesn´t work with lumenRT 😞(
                                            dburdick
                                            Version 1.2 of LumentRT is now released:
                                            http://www.lumenrt.com/
                                            Biggest changes include
                                            • the ability to render super large scenes (e.g. 1km x 1km) much faster using the new AutoScale lighting feature
                                            • faster preprocessing speeds
                                            Exisiting LumenRT users can download the update from their account page
                                            • 4 / 6
