    Quantities from model
    23 Posts 7 Posters 5.3k Views 7 Watching
    • jemagnussenJ
      jemagnussen
      Hi Mac1,
      Yes, I get also the 62 and 60 mΒ³ in the cleaned up slices when grouped and I belive this to be correct. I had to look up "auto fold" but got some weird video on how to use the Alt (Command) key for making fold lines...?
      Best regards
      Jesper
      HP ZBook 15, Windows 10 64 bit
      Intel Core i7-6820HQ @ 2.70GHz
      32 GB Ram
      NVIDIA Quadro M2000M
      • jeff hammondJ
        @mac1 said:
        Don't use entity info. I think that is bounding box also.
        huh?
        it doesn't calculate the bounding box.. (and it's not that much work to test it out.)
        check the entity info for volume of these three items
        • jemagnussenJ
          jemagnussen
          Hi all,
          Yes, I believe that the Entity box gives rather accurate result, nlu issue is that you have to have a clean model with nice full faces and edges connected properly, otherwise it will not give you the volume, the model has to "waterproof". Using the Solid Inspector is of little use as it highlights most of the slice, it's easier to re-draw the whole cross-section and check the volume...
          Brgds
          Jesper
          32 GB Ram
          • sdmitchS
            sdmitch
            Here is my attempt to solve your problem. I made a copy of your Quantities_1.skp. Seperated and exploded the three layers of material and moved them to individual layers. To make the selections easier, I deleted the back face leaving only the front face and the edges that connected it to the back face before running the plugin. A report file is generated listing the area of each face and the volume between them.
            Quantities_1a
            Material C
            Material B
            Material A
            Volume Calculation
            http://sdmitch.blogspot.com/
            • K
              kyyu
              @sdmitch, WoW, that's a great plugin you whipped up for this one off problem. I will have to study it, a little, for my education. πŸ‘
              @jemagnussen, I always like to try things out. I used sketchup's "Outer Shell" feature to combine your 3 layers into 1 (2 at a time). Then used sdmitch's volume plugin, which looks to work great. One thing, that I had to figure out was, don't select the front face edges. Only the front face and the lines extending back. I double checked the volume by grouping the 1st and last slice, and checking the volume in "entitiy info box" and it was very close to the output file.
              Quantities_1b.skp
              volume_1b.txt
              -Kwok
              • jeff hammondJ
                keyboard maestro
                [flash=700,510:2c8kzkb2]http://www.youtube.com/v/EXnXNV61ycA?version=3&hl=en_US&rel=0&hd=1[/flash:2c8kzkb2]
                [sorry about the loud trackpad clicks.. i guess it's pretty close to the laptop mic.. i'll use a mouse next time]
                • jemagnussenJ
                  jemagnussen
                  Hi all and welcome to a new day... (here in West Africa that is... πŸ˜„ )
                  sdmitch,
                  I don't really know what is the problem with my setup, but when I try your method and run the Volume Plug-in on a slice where I take out only front face (with edges) and the edges protruding towards the back face that I have deleted after selecting both and then group them, I don't get a proper "group solid" that I can get the volume from. I run Sketchup 8 Pro on XP SP3 and tried to use your version of the volume plug-in, which I believe is same as TIG's volume plug-in... or ? But don't get it to work, so far only way for me is to re-draw every 1 meter cross section and make it into a "group solid" in order to get it to work.
                  kyyu,
                  I have tried to work with your file for a long time, but fails to get any "group solid" and volume out of it...? Must be my setup that is something wrong with.
                  Jeff Hammond,
                  WoW Jeff, I'm impressed. You did a very fine job at that, as you can see from my text above I'm in the situation that my old XP does not really have the capabilities of your Mac system. One friend of mine recently let me play around with his iPad for some days, and yes, it rocks. If only Steve was not as proprietary as he is then it would probably convince me to move to the Mac platform... I really wish I could do what you did on your Mac, that is just what I need, and probably a lot of other folks in the construction industry. Take a road for example; it would be a breeze to take out quantities with your setup.
                  So far it looks like there is only the hard way for me, but THANK YOU all for your time and effort to try to solve this for me, I really appreciate it. And please excuse my English, it’s my second language as I’m Danish.
                  32 GB Ram
                  • jemagnussenJ
                    jemagnussen
                    Hi again,
                    Come to think about it, it might be much easier to make the quantity take out by taking the volume of the first and last 1 m slice and enter the numbers in Excel and let it figure out the even distibution in between. Think that is an easier approach.
                    I'm working hard to use 3D visualization in my profession as Production Manager on construction projects, the model here is part of a new groyne, and being able to use Sketchup to produce and present the 3D visualization of the project and the steps in between is really a benefit for all parties involved.
                    The quantification would also look good if being able to present it visually in 3D, slice by slice, but it is probably overkill as an Excel sheet will just as well show the factual quantities and for the time being be most trustworthy for the parties involved as it is a sort of a defacto standard.
                    Best regards
                    Jesper
                    32 GB Ram
                      With v8 'volume' is built-in.
                      My Volume plugins come in two versions - an integration one [by slice], that is slow but reliable to within certain accuracy; and one using topology, that is fast but fails with non-solid/manifold objects.
                      My Slicer isn't probably accurate enough to use for your purposes.
                      Jeff's clever macro method is the best without writing a purpose made plugin...
                      This is a simple free PC tool http://www.nonags.com/freeware-do-it-again_43.html or this one http://freelabs.info/MacroRecorder.aspx or this http://download.cnet.com/Easy-Macro-Recorder/3000-2094_4-10414139.html [15day-trial] - there are also several others with more features for a few $...
                      • sdmitchS
                        sdmitch
                        jemagnussen, My volumn plugins doesn't create any "solids" it only creates faces at 1m intervals. Using Sketchup's face.area gives the area of the face and I just average the areas of the adjacent faces to obtain the volume of that "slice" and write that out to a text file. That's all I thought you were looking for.
                          mac1
                          @jemagnussen said:
                          Hi again,
                          Question this. Do you have an spread sheet to do this and checked it. The vol as you step down your model may not be linear and you may have as much work as just using SU. I have not checked this however.
                          Op Site. I had help on previous post on getting estimates of grain vol in a silo bins and it is not real straight forward. Used EXCEL there but this is more complictaed.
                          Do you have to show each slice for visualization. May contention is once you have the work flow set then getting the vol of each slice can be done quickly. One of your problem areas seems to be getting the solid vol to run calculations. I think there are some plugins which can help. Namely make faces and ?? ( Need to find for you). Some time ago I ran a number of test on TIG's cal I ref above using the prismatoid approach as an easy check point and it is most certainly accurate enough for what you are doing. I am like wise certain the SU 8 included capability is accurate too.
                          For presentation using scenes to separate the 3 materials maybe useful.
                          Well get the plugin info and get back with you
                          Good Luck
                          Best regards
                          Jesper
                          • jeff hammondJ
                            the top two layers are linear.. the bottom one isn't.
                            [well, just via a spot check of averaging the two ends then checking the middle]
                            any reason why you're not upgrading to 8? (or at least have a 8 installed alongside 7 on your computer?)
                            no offense to TIG or anyone else that's ever written a volume plugin or boolean plugin but su8's solid calculations and booleans are superior to anything else out there.. the volume is updated in real time and i've yet to come across any inaccuracies. dunno, it's worth checking out.
                            @jemagnussen
                            here's the 3 layers all sliced up.. i guess i should of uploaded this along with the video seeing how it only took 10mins to make (including the macro setup time) πŸ˜‰
                            quantities_macro2.skp
                            i guess you could use this to check your spreadsheet against if you haven't done so already.
                            [Edit]- so i just tried doing a 'generate report' on the file and it's actually a very easy way to get the individual volumes in a spreadsheet (after they're sliced up).. the weird thing though is that the volumes were shown in inches instead of meters in my .csv&html outputs.. i'm not sure if that's due to some settings of mine or if they always come out like that.. in numbers (apple's version of excel), i just divided the cu.inches by 39.37009^3 to get it into meters..
                            here's a .xls with all the volumes in meters.. (not sure how well this is going to transfer into excel.. i tried to keep it super basic so it should work πŸ˜„ )
                            quantities.xls
                              mac1
                              Jeff
                              great work as usual πŸ‘ πŸ‘
                              Ref Su8 upgrade. I don't need and will change over to free when my eval time runs out. At present my main use is as file converter.I do have both installed.
                              • L
                                Lauren
                                Personally, I use Zorro2 and I would suggest it to you as well judging from the tasks that you are in. From my experience, it is by far, one of the best tools out there that helped me slice models. It is very easy and user oriented as when compared with other tools.
