    How to make this?
    24 Posts 9 Posters 2.1k Views 9 Watching
      gulcanocali
      Glad you liked it. Cross-section tool is one of the most favorite among the many features of Tgi3D SU Amorph.
      Nice renders. And your model looks way better than mine too πŸ˜„
      Gulcan Ocali
      Product Manager
      http://www.Tgi3D.com
        cupko
        Heh, but you did it in 1 min. πŸ˜„.
        Thanks again.
          gulcanocali
          Oops, I forgot to mention that the video was sped up. 😳 It was more like 4+ mins. I sped up the video so that people would not get bored. That is how slow I model πŸ˜’
          Gulcan Ocali
          Product Manager
            @gulcanocali said:
            ...It was more like 4+ mins... That is how slow I model πŸ˜’
            Still very impressive. I have had this tool for a while but still exploring and am amazed what one can do with it. πŸ‘
              cupko
              Ok, new challenge πŸ˜„.
              Is there any plugin which works like ChamferAlongPath, but to preserve original edges (I don't need bevel). I just want to add some geometry which will be parallel with original edges from both sides.
                Try the native Offset tool - perhaps with some Move used on specific vertices/edges if required... πŸ˜•
                  cupko
                  Native Offset requires selected face. I have something like in attach, but much more complex.
                    Perhaps my ExtendEdgesByOffset ?
                    Part of the Extrusion Tools zipped set - search for it...
                    Although it only works on any set of coplanar edges... πŸ˜•
                      cupko
                      As you said, edges must be coplanar. One more thing, angles between faces aren't exactly 90Β°.
                      TIG, can we expect some plugin maybe? πŸ˜„
                        EEbyOffset will accommodate non-right-angle corners BUT all edges must be coplanar for it to work...
                        A relatively easy way is using the native Offset tool on each face [double-click to repeat last use offset dim], with some subsequent Move tool use on edges/vertices IF the offset isn't needed to be 'all round'...Capture.PNG
                          cupko
                          I should emphases that geometry is complex. I am practicing making a car from blueprint and there's a lot of triangles.
                          Easiest way to do this would be to select edges and then chamfer. This is not the only place where I need to do this 😞 .
                            bjornkn
                            Take a look at Tools On Surface and Joint Push Pull (JPP)
                              cupko
                              I've made this with those tools, but it's slow and unprecise.
                              • 2 / 2
