[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Apologies if this has been answered already, I'm getting this when I start sketchup. Is there a simple fix. Apple imac, SU7.
There must currently be some permissions set that prevent you making folders/files in that location - either fix the permissions so you can [advisable]... OR make the folder that is needed... as clearly spelled out in the message
I have problems with the update option too... Every time that I want to go to "Check Plugins for Update" nothing happens. If I have the ruby console open it says:
Error; #<RangeError; 9947298230.424000 out of Time range> C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `at' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `tip_next_date' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;642;in `format_html_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;225;in `refresh_dialog_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;520;in `create_dialog_top' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;151;in `initialize' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `new' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `top_dialog' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;195;in `populate_support_menu' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call' C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
Any idea what´s happening?
Daniel S
Daniel,
two questions
How many days did you set the "next check" in the dialog box
Can you type the following command in the Ruby Console:
Upgrade.duration_next_check
- How many days did you set the "next check" in the dialog box
I put 999 the first time because I wanted to do a manual check. But then the update option stop working.
I try deleting and reinstalling Libfredo6 but the problem was still there.
Now In default parameters "Next Check in (days)" says 15. But I´m not able to check.@unknownuser said:
- Can you type the following command in the Ruby Console:
I tried and give different results. It says:
Upgrade.duration_next_check Error; #<NameError; (eval);157; uninitialized constant Upgrade> (eval);157
Upgrade.duration_next_check Error; #<NameError; (eval);677; uninitialized constant Upgrade> (eval);677
or:
Upgrade.duration_next_check Error; #<NameError; (eval);54; uninitialized constant Upgrade> (eval);54 (eval);1; warning; Float 0.0 out of range
Daniel S
Daniel,
Sorry I meant
Traductor::Upgrade.duration_next_check
When I put:
it says:Traductor;;Upgrade.duration_next_check 99999.0
Daniel S
Daniel,
This is where is the problem: 99999 is too big for a number of days.
Can you change it in the default parameters or in the Upgrade dialog box
I'll put a check in a next releaseFredo
FredoI can´t change the 99999 because:
- The Upgrade dialog box don´t open
- In default Parameters I can change it but it doesn´t really change.
In the attach video I show what happens.
I tried reinstalling LibFredo6 but still no work.
Daniel S
Updated version of the Italian Translation of Fredo6 Library
Daniel S
If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file open it and add this line and save it Then you can't wait more than a year [365 days]
Daniel S
Daniel,
I published a new release that should fix the issue.
NEW RELEASELibFredo6 3.7c - 07 Jun 2011
This is a minor maintenance release.
- Fix an issue in CheckForUpdate (next date t check) signaled by Daniel S
- Updated Italian translation by COSEDIMARCO
- Updated Spanish transaltion by Defisto
New release is available for download in the first post of this thread.
Thank you Fredo!!! The update fix it.
I am very good for breaking things.. and you are very good for fixing them. That´s a great team
TIG, Thank you too. You are always there when someone has a problem
Now, time to update some plugins
Thank you again,
Daniel S -
I know you have a special bug detector
The CheckFor Update functions is actually opened to other script writers, not just mine. It does not require that the scripts use LibFredo6 (by the way, JPP an BezierSpline don't use LibFredo6 but are visible in the list).
To find buggy code in others scripts I start off with Baregrep looking for the particular method or reference by name...
That then lets me open the potentially problematical .rb directly at the line indicated and I can read the code and hopefully see what needs adjustemnt...
I even do it with my own stuff, as it's often awkward to work out what's defined/changed where - especially months after you wrote it... -
Thank you ~~~~~~~
Fredo's plug in looks exactly what I need. Does it work with SU 8? Having installed it as described (I'm OSX 10.5.8) I still get an error. I've read every post over the 19 pages and can't find any clues. My directory is not quite as shown as I have:
Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/PluginsAll the files are there as described. Is it simply that it won't work with SU8 or am I doing something wrong?
Thanks in advance to anyone can help.
Wagoneer
Kelly, what are you trying to install? (LibFreo will not do anything - it is just a "background" library for a bunch of Fredo's "real" tools)
Sorry Gaieus, realised I hadn't said what I was doing as I hit 'submit'.....
I want to use FredoScale. I have installed as per instructions, and have also installed RoundCorner. Enclosed is a picture of my plugins.
