    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Ands43
      Apologies if this has been answered already, I'm getting this when I start sketchup. Is there a simple fix. Apple imac, SU7.
        There must currently be some permissions set that prevent you making folders/files in that location - either fix the permissions so you can [advisable]... OR make the folder that is needed... as clearly spelled out in the message 😒
          Daniel S
          I have problems with the update option too... Every time that I want to go to "Check Plugins for Update" nothing happens. If I have the ruby console open it says:
          Error; #<RangeError; 9947298230.424000 out of Time range>
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `at'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;677;in `tip_next_date'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;642;in `format_html_top'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;225;in `refresh_dialog_top'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;520;in `create_dialog_top'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;151;in `initialize'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `new'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Upgrade.rb;79;in `top_dialog'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;195;in `populate_support_menu'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
          C;/Program Files/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
          Any idea what´s happening?
          Daniel S
          • fredo6F Offline
            Daniel,
            two questions
            1. How many days did you set the "next check" in the dialog box
            2. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
              Daniel S
              I put 999 the first time because I wanted to do a manual check. But then the update option stop working.
              I try deleting and reinstalling Libfredo6 but the problem was still there.
              Now In default parameters "Next Check in (days)" says 15. But I´m not able to check.
              1. Can you type the following command in the Ruby Console: Upgrade.duration_next_check
              I tried and give different results. It says:
              Error; #<NameError; (eval);157; uninitialized constant Upgrade>
              (eval);157
              Error; #<NameError; (eval);677; uninitialized constant Upgrade>
              (eval);677
              or:
              Error; #<NameError; (eval);54; uninitialized constant Upgrade>
              (eval);54
              (eval);1; warning; Float 0.0 out of range
              Daniel S
              • fredo6F Offline
                Daniel,
                Sorry I meant Traductor::Upgrade.duration_next_check
                  Daniel S
                  When I put:
                  it says:
                  Traductor;;Upgrade.duration_next_check
                  99999.0
                  Daniel S
                  • fredo6F Offline
                    Daniel,
                    This is where is the problem: 99999 is too big for a number of days.
                    Can you change it in the default parameters or in the Upgrade dialog box
                    I'll put a check in a next release
                      Daniel S
                      I can´t change the 99999 because:
                      • The Upgrade dialog box don´t open
                      • In default Parameters I can change it but it doesn´t really change.
                        In the attach video I show what happens.
                      I tried reinstalling LibFredo6 but still no work.
                      Daniel S
                      cant change.zip
                      • COSEDIMARCOC Offline
                        COSEDIMARCO
                        Updated version of the Italian Translation of Fredo6 Library
                        [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                            Daniel S
                          If you feel up to adding one line of code into a rb file using a plain text-editor like Notepad[++].exe... find this file Capture1.PNG open it and add this line and save it Capture.PNG Then you can't wait more than a year [365 days]
                          • fredo6F Offline
                            Daniel S
                            Daniel,
                            I published a new release that should fix the issue.
                            • fredo6F Offline
                              NEW RELEASELibFredo6 3.7c - 07 Jun 2011
                              This is a minor maintenance release.
                              • Fix an issue in CheckForUpdate (next date t check) signaled by Daniel S
                              • Updated Italian translation by COSEDIMARCO
                              • Updated Spanish transaltion by Defisto
                              New release is available for download in the first post of this thread.
                                Daniel S
                                Thank you Fredo!!! The update fix it.
                                I am very good for breaking things.. and you are very good for fixing them. That´s a great team 😆
                                TIG, Thank you too. You are always there when someone has a problem 👍
                                Now, time to update some plugins 😄
                                Thank you again,
                                Daniel S
                                • fredo6F Offline
                                  I know you have a special bug detector 😛
                                  @TIG: thanks also for your quick support.
                                  The CheckFor Update functions is actually opened to other script writers, not just mine. It does not require that the scripts use LibFredo6 (by the way, JPP an BezierSpline don't use LibFredo6 but are visible in the list).
                                    To find buggy code in others scripts I start off with Baregrep looking for the particular method or reference by name...
                                    That then lets me open the potentially problematical .rb directly at the line indicated and I can read the code and hopefully see what needs adjustemnt...
                                    I even do it with my own stuff, as it's often awkward to work out what's defined/changed where - especially months after you wrote it... 🤓
                                      rjjvirusx
                                      Thank you ~~~~~~~
                                      • W Offline
                                        wagoneer
                                        Fredo's plug in looks exactly what I need. Does it work with SU 8? Having installed it as described (I'm OSX 10.5.8) I still get an error. I've read every post over the 19 pages and can't find any clues. My directory is not quite as shown as I have:
                                        Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
                                        All the files are there as described. Is it simply that it won't work with SU8 or am I doing something wrong?
                                        Thanks in advance to anyone can help.
                                        Wagoneer
                                          Kelly, what are you trying to install? (LibFreo will not do anything - it is just a "background" library for a bunch of Fredo's "real" tools)
                                          • W Offline
                                            wagoneer
                                            Sorry Gaieus, realised I hadn't said what I was doing as I hit 'submit'.....
                                            I want to use FredoScale. I have installed as per instructions, and have also installed RoundCorner. Enclosed is a picture of my plugins.
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 109
                                            • 110
                                            • 92 / 110
