    [Plugin] Pen Tool +
    126 Posts 40 Posters 101.1k Views 40 Watching
    • H Offline
      hebeijianke
      Pen Tools + v1.4 updated with 2 new tools and some bug fixes.
      For latest version go here
      EDIT: I corrected this link, TIG
      [get a direct page link from right-clicking over the small 'post' icon under the post's title, and not from the top-bar html which leads to the page of posts containing the post]...
      weld draw error message
      Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
      F;/Google SketchUp 8/Plugins/PenTool+.rb;771;in `activate'
      F;/Google SketchUp 8/Plugins/PenTool+.rb;1802;in `select_tool'
      Error; #<NoMethodError; undefined method `add' for nil;NilClass>
      F;/Google SketchUp 8/Plugins/PenTool+.rb;756;in `getExtents'
        From starting to use the tool? From performing certain actions?
          That sounds like a language-handler issue - do you have the standard files like sketchup.rb and langhandler.rb in the Tools folder ?
          If you type [copy+paste] $exStrings in the Ruby Console it should return this
          #<LanguageHandler;0xb7d5f2c @strings={"Select first end"=>"Select first end", "Point at Center"=>"Point at Center", "Box"=>"Box", "Create Box"=>"Create Box", "Material"=>"Material", "Adds examples of tools created in Ruby to the SketchUp interface.  The example tools are Draw->Box, Plugins->Cost and Camera->Animations."=>"Adds examples of tools created in Ruby to the SketchUp interface.  The example tools are Draw->Box, Plugins->Cost and Camera->Animations.", "Select By Material"=>"Select By Material", "Select By Layer"=>"Select By Layer", "Select second end"=>"Select second end", "Box Dimensions"=>"Box Dimensions", "Cost"=>"Cost", "Total Cost Estimate"=>"Total Cost Estimate", "Stop Spinning"=>"Stop Spinning", "Spin View"=>"Spin View", "Animations"=>"Animations", "Default"=>"Default", "Assign Estimate to Material"=>"Assign Estimate to Material", "Cost Estimate"=>"Cost Estimate", "Ruby Script Examples"=>"Ruby Script Examples", "Layer"=>"Layer", "Width"=>"Width", "Compute Estimate"=>"Compute Estimate", "Assign Estimate to Faces"=>"Assign Estimate to Faces", "Hide Rest"=>"Hide Rest", "Depth"=>"Depth", "Height"=>"Height", "Cost By Material"=>"Cost By Material", "Create Cylinder"=>"Create Cylinder", "Could not find Material named"=>"Could not find Material named", "Cost per sq. foot"=>"Cost per sq. foot", "FPS"=>"FPS"}>
          If not then that's the issue... not this actual tool per se, but your setup πŸ˜•
            SketchUpNoobie
            @tig said:
            type $exStrings in the Ruby Console
            Seriously though, thanks for the update Rich. Construction points should be nice.
            SketchUpNoobie: the complete noob in all things SketchUp.
              Unfortunately ' $exStrings' is what @Last/Google decided to call it years ago πŸ˜„ πŸ˜’
                nothing like a bit of nostrings$ex πŸ‘
                  Ben Ritter
                  Rich, thank you very much. By the way, why was the pen to draw an edge with a face included,if it does the same thing as the line command?
                  Ben
                    Yes it's the same but you can toggle inference locking with the shift key. The native Line tool requires you to hold the shift.
                    By having the toggle option you can orbit with inference lock is toggled on whilst the native tool would cause you to pan. Csaba asked for this function in another thread.
                      The 'edge' tools doesn't form faces like the 'pen' tool [or for that matter the other line drawing tools].. The 'pen' tool is like native 'Line'... BUT it has some different inferencing etc... Try the different ones to see what I mean... πŸ€“
                      • utilerU Offline
                        utiler
                        Hey, I've missed this so far!!!!! haven't you got enough to do, Rich?
                        Well done mate!
                        Just Curious...
                          driven
                          hi Rich,
                          this is great, works on the mac except the
                           ###new_toolbar.show ### ONLY show if was visible before...
                              new_toolbar.restore if new_toolbar.get_last_state==TB_VISIBLE
                          [this may be due to the slightly different RUBY_VERSION i.e. 1.8.5]
                          however it does work if I cut and paste it to line 1175, directly under
                          new_toolbar = UI;;Toolbar.new("Pen Tool +")
                          tooltips, custom menu items and the tools themselves all work as advertised...
                          well done
                            Thanks for the Mac feedback John. Glad you got it to work πŸ‘
                            • yellow perilY Offline
                              yellow peril
                              I have just downloaded your pen tool, i am working on mac, it appears to workfine but with no icons.....any ideas?
                                driven
                                hi,
                                if the icons folder named, rob_hsltool is in your plugins folder, then you might just need to turn on the menu in View >> Tool Palettes >> Pen Tool +
                                • boofredlayB Offline
                                  boofredlay
                                  BTW, TIG solved my problem stated earlier in this thread. Thanks TIG.
                                  It turns out if you click the "Compatibility Files" button between Burn and New Folder it showed up.
                                  • H Offline
                                    hungnguyenpham
                                    Thank you!
                                      Panga
                                      Thanks a lot for this usefull plugins !! πŸ‘
                                      • jgbJ Offline
                                        jgb
                                        @dave r said:
                                        Comes of drinking American beer at high elevations for a week when you're not used to either. πŸ˜„
                                        Canadian beer will do that at sea level in less than a day. 🀣
                                        jgb
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi:
                                          Just trying out Pen Tool last night, I noticed that occasionally for one click I got 2 Cpoints. Also, one or two of the other pen settings doubled the endpoints which were placed short distances apart in a series of quick clicks randomly in the model space. Hard to explain. I did not save the file. This was in Sketchup 7. This mouse has shown no other misbehavior in other applications.
                                          Has anyone else seen this?
                                            Mitcorb I think this is down to you keeping the mouse-button pressed and dragging.
                                            Most of this kind of line tools allow for you to press+hold+drag+release to make the line, as well as more usual click+click to provide two ends.
                                            There's a short timer delay built-in to spot a real button-hold as that - obviously you're on the top limit time-wise and it's assuming a drag is wanted...
                                            Is your mouse-button sticky?
                                            For the cpoint tool if you don't do a clean click. but do more of a press. then it assume a drag and places a second cpoint at the release point - which might be only a short distance away if the mouse moves slightly.
                                            So to avoid this ensure a clean click with no holding down of the mouse button with a drag unless you want two points...
                                            πŸ˜•
                                            • 3 / 7
