    SketchUp Pro [EXPIRED]
    17 Posts 10 Posters 8.5k Views 10 Watching
    • soloS Offline
      I have an even more irritating issue, I have SU on only one machine, when I open a second instance of SU it shows as expired in second intance and runs as slow as snot on a cold day.
      So far nobody has suggested a solution.
      • AnssiA Offline
        Anssi
        You might try to use your firewall settings to block SU from network access. It might slow down SU startup, though. Just an idea.
        Anssi
          tnt_tom
          Same thing here. If no solution to this, is there a way to have both, Sketchup 8 and Sketchup PRO 8 installed on the same machine?
          • jeff hammondJ Offline
            turn off your interweb connection πŸ˜„
            • soloS Offline
              Still no solution...f#cking irritating as I can only open one instance of SU at a time, if I try open another it becomes 'expired' and runs slower than jam on a window.
              I normally model with two instances...I'm screwed.
                tim
                Why do you need to do that? On my Mac I can open multiple windows on multiple files; surely Windows will do that as well? Is there some advantage to running multiple copies of the application?
                  Unfortunately on a PC each SKP file opens in a new instance of the Sketchup exe - unlike a MAC
                  πŸ˜’
                  Solo do you have a stand-alone or a network license ?
                  Neither should cause the problem!
                  Have you contacted Google support ?
                  Have you tried reinstalling the license ?
                  I have a stand-alone license [Vista] and can open multiple SKPs without difficulty.
                  The only time I get this message 'EXPIRED' issue is if the networked laptop PC version of Sketchup [using the same license] has a SKP open and then the desktop PC then opens a SKP - I am told that the license is already in use and it defaults to 'Free' for that SKP. If the laptop PC's Sketchup is closed then subsequent SKPs will open fine on the desktop PC using Pro ??
                  Is this a Win7 network issue ??
                  Or perhaps a user/rights issue - are you an Admin?
                  Tried running Sketchup as Admin??
                  πŸ˜•
                  • PixeroP Offline
                    Pixero
                    I too have a stand alone license and can open multiple SU.
                    Just a thought, have you tried turning off UAC in Windows Vista/7?
                    • soloS Offline
                      Okay, lets see...
                      I have the UAC off, I am running win& 64, sigle user license/ stand alone, I switched off (unplugged) network/internet and opened a second instance of SU and got same result.
                      I have NO other installed versions of SU anywhere.
                        @solo said:
                        Okay, lets see...
                        oh, that tip of mine was aimed at the original post.. opening SU on a laptop while having it opened on the desktop for instance..
                        i do it all the time πŸ˜„
                        i don't have a clue about the weirdness you're experiencing.
                        • PixeroP Offline
                          Pixero
                          Just to be sure.
                          Does it say "Single-User" in the License Info panel?
                          Help->License->License Info
                          • soloS Offline
                            Use:Commercial
                            Single-User
                            • PixeroP Offline
                              Pixero
                              Sorry, then I don't know what's causing it.
                              I can open at least ten instances of SU without problems.
                              Might be best to contact Google.
                                ScottPara
                                I am on a windows 7 64bit machine and I opened 4 sessions at the same time and got NO expired warning and no lag.
                                Scott
                                Love the fact that some HATE my avatar.....
