    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • soloS
      Cool UI.
      One issue, if you close it you cannot open it again.
      • P
        Pierreden
        @solo said:
        Cool UI.
        Thanks for your reply... could you elaborate? I cant recreate it on my system... Are you on a mac? Sketchup 8? And how do you close it?
        Regards
        • soloS
          Sure.
          I opened the UI (from plugin menu) I started creating ivy but decided my ball (wanted it to grow over ball) was too big, so I exited by clicking the close X, resized the ball and tried to start Ivy again, it was checked in menu by no matter what I did the UI did not show again.
          • pugz1983P
            pugz1983
            @solo said:
            Sure.
            Same here,
            I do like the way this Ivy plugin is going. Nice interface, and I thank you are on the right track. Simple Ivy can be made, and i did a few testrenders with indigo and the results are nice. But for large walls covering Ivy you have to make several seperaty ivy bushes I think because of bugsplat when going over 150 branches. But thanxs for the hard work so far, Keep it up and this wil be a very welcome plugin 😄
            Greetz Pugz
            • lele_poggiL
              lele_poggi
              Great work!!!
              gsa | Gabriele Sacchi architetto
              http://www.gs-a.it
              • esteromxE
                esteromx
                reported the same problem as Solo, this problem appears only when you try to put leaves on the vine
                • OxerO
                  Oxer
                  Hi, i work on Mac and Sketchup reads the plugin but when i run the plugin the Ivy parameters window appears and immediately disappears, for this i can't use it.
                  • V
                    vidy
                    woow.. this getting to be more and more interesting...
                    thanks pierre..
                    regards
                    still so much to learn..
                    • soloS
                      This is heading towards being an epic plugin...similar to what 'Fur' achieved IMo.
                      • P
                        Pierreden
                        Thanks for the thumbs up and critics everyone!
                        I have fixed solo's bug, will upload i fix later today 👍
                        @oxer: This is not good. I'm really struggling with mac support. Will fix as soon as i can! Any error messages in the console?
                        Thank you! Really hope its of use. When i get time i will release additional plugins based on the same principles as this one. Have working proof of concepts for Cloth, fur and a simple particle flow system, all which i hope to develop further in the long run.
                        Peace
                        Pierre
                        • PixeroP
                          Pixero
                          Any chance of using existing components as leaves (preferable several different simultaneously) as a compliment to the "built in"?
                            +1
                            • pugz1983P
                              pugz1983
                              @thomthom said:
                              +1
                              yes, this would be a welcome adittion to the plugin. Like in the component spray plugin. The textures that come with the original Ivy Generator Script have a young and old leaf texture. These can be used to make components.
                              Greetz Pugz
                              • OxerO
                                Oxer
                                Thanks Pierreden for your efforts!! 👍
                                Nothing in the Ruby Console. I'll try to uninstall others plugins perhaps there is an incompatible plugin.
                                EDIT:
                                I have probed to uninstall all the plugins but it happen the same, the SketchupIvy window appears and disappears immediately.
                                  driven
                                  hi Pierreden,
                                  I finally got the dialog to stay open on mac, which then allows for console errors to show.
                                  Error: #<NoMethodError: undefined method face' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:45:in onLButtonDown'
                                  Error: #<NoMethodError: undefined method valid?' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SIvy/LiveIvy_tool.rb:73:in draw'
                                  hope this helps
                                  • Didier BurD
                                    Didier Bur
                                    Is it me or something went wrong: after finishing the ivy, I'm getting 2 black materials 'Ivy_stem' (no texture) and 'Ivy_leaf' (no texture too) and that is not used on leaves ?
                                    DB
                                      dbalex
                                      I have the same results.. black stem texture and default texture on the leaves.
                                      http://www.bocostudio.com
                                      • G
                                        gaonirico
                                        Me too. Without textures and black faces
                                        Ruby console
                                        • P
                                          Pierreden
                                          Thanks for the replies everyone!
                                          @pixero/thomthom/pugz: This is a brilliant idea. This wont be first priority, but will look into it after bug fixes and the mac issues 👍
                                          @oxero/driven: Thank you! Will look at it and hope to release a fix later today (saturday)
                                          @didier/dbalex/gaonirico: Looks like the textures isnt applied to the material... Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                                          Thank you for your patience and coops everyone!
                                          Peace
                                          Pierre
                                          • Didier BurD
                                            Didier Bur
                                            Hi Pierreden,
                                            @didier/dbalex/gaonirico: Are you using SU8 (im actually not sure if this is an requirement)? Mac Windows? Any console messages when you start a new model and then starts the plugin?
                                            I'm using SU8 Pro on Windows XP and 7. No console message at startup.
                                            Maybe there's a problem within the Pdn Materials class/module ?
                                            Keep on the good work !
                                            Regards
                                            DB
                                            • 36
                                            • 37
                                            • 4 / 37
