    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 162.8k Views 46 Watching
    • fredo6F
      I know there is a problem, which I need to fix.
      Are you on Vista or Windows 7, and which IE browser do you have?
      Fred
      • B
        Ben Ritter
        Thank you, again, Fredo.
        • halroachH
          halroach
          Fred
          I'm on windows XP 😎
          Internet Explorer 8
          FlexTools - Super Quick Windows, Doors, Slats...
          • JClementsJ
            JClements
            I do kind of like the idea of an alarm the user can set for the overall project (or maybe even a model file) when X hours has been attained.
            It would help to stay within a project's budgeted hours or within a budget hours for phase/task for a project.
            John
            • fredo6F
              John
              John,
              Would it be OK if I change the background of the clock (say to Red) to indicate that the time is over the limit (the limit will be set in the dialog box)?
              • JClementsJ
                JClements
                A nice idea. What ever is the easiest to implement.
                Alternative idea. One cirle. Green for well within budgeted hours, Yellow (or blinking yellow) for close maximum budget (ie., 2 hours), Red for over limit.
                Post Script: When I clicked on a link for donations via PayPal, I got a master page in French and my contribution did not take.
                • halroachH
                  halroach
                  When exporting to CSV for opening with Excel, Excel doesn't recognize the day dates in their current format which is:
                  "Tue 03 May"
                  I think it recognizes dd.mm.yy or dd.mm.yyyy or dd.mmm.yyyy etc. or with a / - dd/mm/yy or even the backward American way which is mm.dd.yy.
                  Anyone of those formats, preferable the first and second would be great!
                  On the other hand the month column is recognized OK.
                  great great plugin!
                  • halroachH
                    halroach
                    If I'm working on several sketchup models at the same time which are all linked to the same project, might there be any time syncing problems?
                      marne
                      too bad I've bought "time track" long ago. Thanks for this great script!!!
                      • fredo6F
                        In principle, this should work.
                        I am interested in your feedback however if you find issues. Just remember that activity is tracked on events, not on focus, i.e. when you use interactive SU Tools or scripts.
                        • fredo6F
                          NEW RELEASE: SUCLOCK 1.1b - 19 May 11
                          This small update just adds an extra column with the date formatted in Excel compliant format (dd-mm-yyyyy) for the CSV export of the view by Day/Month. This fixes a problem mentioned by Halroach.
                          Update is published in main post.
                          • halroachH
                            halroach
                            boy, you're quick!!
                            nice!
                            • KrisidiousK
                              Krisidious
                              I was wondering what the capabilities were for employees. could this be installed on an employee's computer to track his time? and I know it could. but could it be a protected file? how would you know that no one had edited the file for time tracked? if someone sends me their file will it show the clock on it and how much time has been used?
                              just thinking outloud... and as I have said before, fantastic plugin Fredo...
                              By: Kristoff Rand
                              • B
                                Ben Ritter
                                Fredo, thank you. Ben
                                • halroachH
                                  halroach
                                  For all those times when you worked hard on a model but forgot to track the time you've spent on it... and really wished you had...
                                  You could have a little check in the plugin preferences to 'track time for untitled projects'.
                                  This would generally eliminate all time spent with Sketchup, that is unaccounted for. great for spying too when you think about it...
                                  a step further could be to have an option to rename the untitled time/projects in retrospect and assign that time to an existing or new project.
                                  What do you think?
                                  • halroachH
                                    halroach
                                    Just thought of another use.
                                    At my modeling and rendering department, we generally tend to share the work on models between us. It would be nice to have a worker ID or computer ID which would be assigned for each time track.
                                    Then we could see how much time each of us spent on the same project.
                                    I really like this plugin!
                                    • fredo6F
                                      SUClock is not really designed for concurrent multi-user on a network, because it uses local temporary files to track the information.
                                      One possibility is that I give the option to put all files on a shared drive
                                      Another possibility is that each user has his own .suclock files, but I give the option to issue statistics on a several .suclock files. Note however that you can already do this with the Excel exports.
                                      • COSEDIMARCOC
                                        COSEDIMARCO
                                        Hi Fredo,
                                        I've two request for future realeses, if possible.
                                        • had the opportuny to export statistics in other formats such as HTML or tabbed TXT? I'd like to paste them in my blog posts.
                                        • Track usage of all your plugins.
                                        At last, great plugins like all of yours
                                        [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                        • fredo6F
                                          No problem, this is simple to do.
                                          SUClock only tracks 'interactive' plugins, that is those based on the Sketchup::Tools class, typically where you can click and do things in the screenport UI.
                                          All my plugins are enabled in their latest version.
                                          By the way, interactive scripts written by other writers can easily be tracked too.
                                          They just need to insert a single line of code in the activate() method of their tool
                                          def activate
                                             LibFredo6.register_ruby 'Name of the Plugin' if defined?(LibFredo6.register_ruby)
                                          • COSEDIMARCOC
                                            COSEDIMARCO
                                            Ok. Thanks a lot. 😄
                                            • 2 / 7
