    Drawing an arc with seperated segments
    10 Posts 5 Posters 507 Views 5 Watching
    • hellnbakH Offline
      hellnbak
      Is there any way to draw an arc so that it's segments are separated? In other words, so that you can select each segment separately. I know you can separate the segments by drawing a line from each junction, but this is such a pain, and sometimes doesn't even work right.
        d12dozr
        After you draw the arc, Right click on it -> Explode Curve
        http://goo.gl/f7ooYh
        • hellnbakH Offline
          hellnbak
          Thanks, I should have asked this question a long time ago πŸ˜†
            d12dozr
            πŸ˜‰ Just think of how many more models you could have finished by now!
            Do you have any more easy questions? πŸ˜†
            • hellnbakH Offline
              hellnbak
              Actually yes, I do have another dumb question - I know you can use Eraser/Ctrl/Shift to unsoften lines, but is there a way to use the eraser to turn hidden lines into unhidden lines? Or to softened lines? Or to bunny rabbits?
                d12dozr
                'fraid not 😞
                I'm sure there's a ruby around here somewhere for that! πŸ’š
                  Shift+Erase = Hide
                  Ctrl+Erase = Soft/Smooth
                  Ctrl+Shift+Erase = Unsoft/smooth (but not unhide)
                    To turn Hidden lines to Solid lines...
                    View > Hidden Geometry > ON
                    Next change to View Mode to 'Wireframe' [this makes selecting edges much easier]
                    Select the 'dotted' Hidden Edges you want to change to Solid... using the Entity Info > Uncheck the 'Hidden' box...
                    Reset the Hidden Geometry and the View Mode to your particular preference...
                    This method can also be used to manipulate Smooth/Soft-ness of edges...
                    • hellnbakH Offline
                      hellnbak
                      Thanks TIG, that works much better than having to draw over each line. I don't use wireframe mode though, with a complicated model it's difficult to figure out just what is what. I hardly ever use wireframe, looks like a spaghetti factory exploded, makes me dizzy.
                      Just knew there was someone out there with a tip that would help out.
                      By the way d12dozer, I found that bunny rabbit ruby, works great! (although the bunnies are starting to get out of control)
                      • jeff hammondJ Offline
                        fwiw, you can also select - > right click -> unhide
                        you can select a bunch of faces along with the hidden lines and it won't matter (ie- window selection etc is ok)..
                        but the real way to avoid it is not to hide any lines in the first place πŸ˜‰
                        (well, for me at least.. i just never have a use for hiding lines as opposed to softening them)
