    [Plugin] Grow
    45 Posts 19 Posters 69.7k Views 19 Watching
      Keep on topic guys. I'd hate to have to shaft you outta here. So quit the dickin' around. It is easter after all. The time to reflect on what rose from the dead only to disappear again.
        Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
        So if I have the last previous one, non need to download this one? 😳
        My favorite one 😎
          So if I have the last previous one, no need to download this one? 😳
          Correct.
          I suspect you already have the latest version.
          Reinstalling it won't do any harm - it'll just be a waste of two minutes that you'll never see again πŸ˜‰
            yes old but yet 2.1 2007 01 21 πŸ˜‰
              It IS an 'oldie but a goldie'...
              It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do...
              It still works!!! πŸ˜„
              • pyrolunaP Offline
                pyroluna
                Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! β˜€
                  That IS one of the demos from looooong ago... πŸ˜’
                    d12dozr
                    Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! β˜€
                    http://goo.gl/f7ooYh
                      That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it... πŸ˜„
                      Here're some [old] examples...Grow Examples.zip
                        d12dozr
                        Thank you for those πŸ‘ ...now isn't someone working on a video tutorial? πŸ˜‰
                          Grow is so old that there was only 16mm film back then πŸ˜‰
                            d12dozr
                            So a black and white silent film? That works! πŸ˜„
                              Pherim
                              It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
                                This is a known issue - SP messes with some existing base class methods and thereby affects a few other scripts...
                                  patricprz
                                  Thanks for recommending this. It works a treat. πŸ‘
                                    Sir.Swaffel
                                    What would be the best way to let it "grow along path"?
                                      Not this tool...
                                      Look for Chris Fullemr's ComponentStringer and RickW's ComponentAlongPath ...
                                        Sir.Swaffel
                                        Well I do need some kind of scaling. As you can see from the image, I'm trying to make a spiraling tower. I need to make windows in the vertical segments, but the tower is quite large and the vertical segments get smaller as the tower gets higher. So I need the windows to follow the spiraling path upwards AND have them scaled down according to the height. Then I'm going to subtract them from the vertical segments to create the arched openings. It's a total headache πŸ˜’
                                          Try DrawHelix for the rail[s] - you can have different start/end radii and a straight-curve for the profile...Capture.PNG Here's quick example, worry about the fripperies like the door-arch later...
                                            mikenon
                                            Hi - This is almost exactly what I need, but I would like to use other functions. Is there a way to alter this so that instead of choosing from linear/exponential/fibonacci I have the ability to select my own values. I need some other periodic functions, like sine-wave. I imagine, the easiest way to do this would be to just allow values to be passed in a list. So if I want 100 copies, I pass in a list with 100 numbers for x-offset. Is this possible?
                                            Mike
                                            • 1 / 3
