    [Plugin] Grow
    45 Posts 19 Posters 70.1k Views 19 Watching
      Ah well, sorry for the bad joke indeed (I could not resist however)
      πŸ˜„
      • soloS Offline
        Csaba,you have grow.rb confused with viagra.rb.
          You know, at my age you take everything whose label says "grow".
          πŸ˜’
            I've heard that the super-strength-viagra - like you use - is so potent, that if you don't swallow it quickly enough you get a stiff-neck πŸ˜’
            • Rich O BrienR Online
              Keep on topic guys. I'd hate to have to shaft you outta here. So quit the dickin' around. It is easter after all. The time to reflect on what rose from the dead only to disappear again.
                Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
                So if I have the last previous one, non need to download this one? 😳
                My favorite one 😎
                  So if I have the last previous one, no need to download this one? 😳
                  Correct.
                  I suspect you already have the latest version.
                  Reinstalling it won't do any harm - it'll just be a waste of two minutes that you'll never see again πŸ˜‰
                    yes old but yet 2.1 2007 01 21 πŸ˜‰
                      It IS an 'oldie but a goldie'...
                      It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do...
                      It still works!!! πŸ˜„
                      • pyrolunaP Offline
                        pyroluna
                        Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! β˜€
                          That IS one of the demos from looooong ago... πŸ˜’
                            d12dozr
                            Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! β˜€
                            http://goo.gl/f7ooYh
                              That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it... πŸ˜„
                              Here're some [old] examples...Grow Examples.zip
                                d12dozr
                                Thank you for those πŸ‘ ...now isn't someone working on a video tutorial? πŸ˜‰
                                  Grow is so old that there was only 16mm film back then πŸ˜‰
                                    d12dozr
                                    So a black and white silent film? That works! πŸ˜„
                                      Pherim
                                      It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
                                        This is a known issue - SP messes with some existing base class methods and thereby affects a few other scripts...
                                          patricprz
                                          Thanks for recommending this. It works a treat. πŸ‘
                                            Sir.Swaffel
                                            What would be the best way to let it "grow along path"?
                                            • 1 / 3
