    [Plugin] Grow
    45 Posts 19 Posters 69.2k Views 19 Watching
      There have been several threads about 'Grow' [they keep growing πŸ˜’ ]... so it's been decided to make one new central point where it'll be based - and that right HERE!
      Usage:
      Move/Place Objects,Select them and pick Grow.
      Pick Point.
      Enter desired data in dialogs and see results.
      Undo is in 1 step.
      Note that non-grouped Faces and Edges can stick together after 'Growing'.
      Play around to see types of results...
      Shape, location, scale, order all produce different results...
      Linear Scaling goes 1 2 3 4 5 6 7... on any scaling factor
      Exponential + goes 1 2 4 8 16 32... on any scaling factor != 1
      Exponential - goes 1 1/2 1/4 1/8 1/16 1/32... on any scaling factor != 1
      Fibonacci + goes 1 1 2 3 5 8 13... on any scaling factor
      Fibonacci - goes 1 1 1/2 1/3 1/5 1/8 1/13... on any scaling factor
      http://sketchucation.com/resources/pluginstore?pln=Grow
        Khai
        ..and what does it do?
          Grows. Take one every evening (and one extra before sex but never more than two a day)
            Gaieus! πŸ˜’
            I've added an explanation to the download page...
            It's been around so long that I forgot that it might be new to some of you... πŸ˜•
              Ah well, sorry for the bad joke indeed (I could not resist however)
              πŸ˜„
              • soloS Offline
                Csaba,you have grow.rb confused with viagra.rb.
                  You know, at my age you take everything whose label says "grow".
                  πŸ˜’
                    I've heard that the super-strength-viagra - like you use - is so potent, that if you don't swallow it quickly enough you get a stiff-neck πŸ˜’
                      Keep on topic guys. I'd hate to have to shaft you outta here. So quit the dickin' around. It is easter after all. The time to reflect on what rose from the dead only to disappear again.
                        Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
                        So if I have the last previous one, non need to download this one? 😳
                        My favorite one 😎
                          So if I have the last previous one, no need to download this one? 😳
                          Correct.
                          I suspect you already have the latest version.
                          Reinstalling it won't do any harm - it'll just be a waste of two minutes that you'll never see again πŸ˜‰
                            yes old but yet 2.1 2007 01 21 πŸ˜‰
                              It IS an 'oldie but a goldie'...
                              It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do...
                              It still works!!! πŸ˜„
                              • pyrolunaP Offline
                                pyroluna
                                Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! β˜€
                                  That IS one of the demos from looooong ago... πŸ˜’
                                    d12dozr
                                    Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! β˜€
                                    http://goo.gl/f7ooYh
                                      That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it... πŸ˜„
                                      Here're some [old] examples...Grow Examples.zip
                                        d12dozr
                                        Thank you for those πŸ‘ ...now isn't someone working on a video tutorial? πŸ˜‰
                                          Grow is so old that there was only 16mm film back then πŸ˜‰
                                            d12dozr
                                            So a black and white silent film? That works! πŸ˜„
                                            • 1 / 3
