    [Plugin] Grow
    45 Posts 19 Posters 71.9k Views 19 Watching
      I suspect you already have the latest version
      yes old but yet 2.1 2007 01 21 πŸ˜‰
      It IS an 'oldie but a goldie'...
      It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do...
      It still works!!! πŸ˜„
      • pyrolunaP
        pyroluna
        Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! β˜€
          That IS one of the demos from looooong ago... πŸ˜’
            d12dozr
            Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! β˜€
            http://goo.gl/f7ooYh
              That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it... πŸ˜„
              Here're some [old] examples...Grow Examples.zip
                d12dozr
                Thank you for those πŸ‘ ...now isn't someone working on a video tutorial? πŸ˜‰
                  Grow is so old that there was only 16mm film back then πŸ˜‰
                    d12dozr
                    So a black and white silent film? That works! πŸ˜„
                    • P
                      Pherim
                      It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
                        This is a known issue - SP messes with some existing base class methods and thereby affects a few other scripts...
                        • P
                          patricprz
                          Thanks for recommending this. It works a treat. πŸ‘
                            Sir.Swaffel
                            What would be the best way to let it "grow along path"?
                              Not this tool...
                              Look for Chris Fullemr's ComponentStringer and RickW's ComponentAlongPath ...
                                Sir.Swaffel
                                Well I do need some kind of scaling. As you can see from the image, I'm trying to make a spiraling tower. I need to make windows in the vertical segments, but the tower is quite large and the vertical segments get smaller as the tower gets higher. So I need the windows to follow the spiraling path upwards AND have them scaled down according to the height. Then I'm going to subtract them from the vertical segments to create the arched openings. It's a total headache πŸ˜’
                                  Try DrawHelix for the rail[s] - you can have different start/end radii and a straight-curve for the profile...Capture.PNG Here's quick example, worry about the fripperies like the door-arch later...
                                    mikenon
                                    Hi - This is almost exactly what I need, but I would like to use other functions. Is there a way to alter this so that instead of choosing from linear/exponential/fibonacci I have the ability to select my own values. I need some other periodic functions, like sine-wave. I imagine, the easiest way to do this would be to just allow values to be passed in a list. So if I want 100 copies, I pass in a list with 100 numbers for x-offset. Is this possible?
                                    Mike
                                      Yes IF YOU redo the code.
                                      It's probably easiest to make a new tool that is run in a way that can take arguments - in your case an array of values, which it then uses to do something.
                                      That way the processing is somewhat independent of the outcome...
                                      Do not forget that there are already many tools that process CSV/TSV files so in your case you simply have a file in the format x,y,z [and even rotx,roty,rotz,scalex/,scaley,scalez etc] - one 'point' per line and then do something with the point - add cpoints, join up the points with lines etc, place an instance at every point and rotate it/scale it... You could make the 'table' file from Excel osa...
                                      IF you explain better what it is you want to achieve and supply a typical xyz... data set I might be able to quickly bodge something together, though I am quite busy... 😐
                                      • brookefoxB
                                        brookefox
                                        I'm a new 'grow' user and am confronted with immediate splats after after processing. Knowing how diligent TIG is about resolving issues, I don't doubt the problem is a conflict with one of the plugs I've recently installed. Prior to uninstalling them in batches to try to isolate the culprit, I thought I'd ask if there anyone had problems but did not mention them. I get no results searching splats here.
                                        Thanks.
                                        EDIT: Whatever the problem was, it has gone away.
                                        ~ Brooke
                                          Here's a minor update http://forums.sketchucation.com/viewtopic.php?p=324331#p324331
                                          v2.2 avoids a clash with some rogue scripts' messing with base classes/methods for selection/group and/or miscast observers, that a very few users had reported recently.
                                          Now fixed for all [I hope!]...
                                          • brookefoxB
                                            brookefox
                                            Thank you, TIG. Your attentive diligence is inspiring.
                                            ~ Brooke
                                            • 2 / 3
