    How to get rid of direction information?
    14 Posts 6 Posters 1.0k Views 6 Watching
    • Wo3DanW Offline
      Wo3Dan
      @tig said:
      Unfortunately the view-text, saying Top, Front etc [or in your locale language], is hard coded into the SUp-code....
      I'm not too sure about that.
      If I'm not mistaken I've seen some code that turned it off, for the same purpose of getting clean prints/screenshots. But that was some 2 years ago. I'll see if I can find it again.
      Keep on searching.
        Jim
        Keep on searching.
        Right, it's an option named "ShowViewName" in the Ruby API, but apparently not available through any dialog. The following code, pasted in the Ruby Console window, will turn the text off.
        Sketchup.active_model.options["ShowViewName"] = false
          kyyu
          Thanks, that's very interesting. I couldn't get it to work, but googled it and found it was mis spelled. Should be:
          Sketchup.active_model.rendering_options["ShowViewName" = false]
          • Wo3DanW Offline
            Wo3Dan
            Thanks Jim and thanks kyyu.
            At least (part of) my memory is still working as should.
            To get the ViewName (Top, Front, etc.) back, replace false by true
              You [I] live and learn... ๐Ÿ˜„
                Jim
                Sketchup.active_model.rendering_options["ShowViewName"] = false
                Thanks for the correction. I should have taken an extra 2 seconds and tested it.
                There is another RenderingOption named "DisplayText" which toggles the display of text, which is also not available in any dialog.
                  Could you make custom view names and make them appear for specific scenes?
                    I already made a tool for that ๐Ÿ˜’ - it adds screen-text initially with the scene-name [editable] put onto its own layer [that is only 'on' in that scene]...
                    http://forums.sketchucation.com/viewtopic.php?p=293602#p293602
                      I'm sorry TIG. I vaguely remember that now. I can't keep track of all your fine plugins. If they don't get used frequently, they escape my memory. And my memory seems to be getting shorter and shorter.
                        I know the problem...
                        Anyway... I already made a tool for that ๐Ÿ˜’ - it adds screen-text initially with the scene-name [editable] put onto its own layer [that is only 'on' in that scene]...
                        ๐Ÿ˜‰
                        Now, a why am I standing at the fridge with the door open moment... ๐Ÿ˜ฎ
                          ๐Ÿ˜‰
                          Because you have to go to the loo?
                            C.Wolf
                            Thanks for your help everybody!
                            With the ruby console and the posted command everything is fine now!
                            Still much for us to discover with Google SketchUp... ๐Ÿ˜„
