How to get rid of direction information?
Hello,
At our institute we conduct experiments on navigation with Google SketchUp (Version 8).
Unfortunately we can't get rid of the direction which is at the top left. (See picture)
Does anybody know how to get rid of it?
Thanks for any help!
C.Wolf
Unfortunately the view-text, saying Top, Front etc [or in your locale language], is hard coded into the SUp-code.
Of course, if your views aren't these specific 'types' there is no text visible, so you could make slight adjustments to the camera to avoid them appearing in your [saved] Scene tabs... -
@tig said:
Unfortunately the view-text, saying Top, Front etc [or in your locale language], is hard coded into the SUp-code....
I'm not too sure about that.
If I'm not mistaken I've seen some code that turned it off, for the same purpose of getting clean prints/screenshots. But that was some 2 years ago. I'll see if I can find it again.
Keep on searching. -
Keep on searching.Right, it's an option named "ShowViewName" in the Ruby API, but apparently not available through any dialog. The following code, pasted in the Ruby Console window, will turn the text off.
Sketchup.active_model.options["ShowViewName"] = false -
Sketchup.active_model.options["ShowViewName"] = falseThanks, that's very interesting. I couldn't get it to work, but googled it and found it was mis spelled. Should be:
Sketchup.active_model.rendering_options["ShowViewName" = false] -
@kyyu said:
Sketchup.active_model.rendering_options["ShowViewName" = false]Thanks Jim and thanks kyyu.
At least (part of) my memory is still working as should.To get the ViewName (Top, Front, etc.) back, replace false by true
You [I] live and learn...
Sketchup.active_model.rendering_options["ShowViewName"] = falseThanks for the correction. I should have taken an extra 2 seconds and tested it.
There is another RenderingOption named "DisplayText" which toggles the display of text, which is also not available in any dialog.
Could you make custom view names and make them appear for specific scenes?
I already made a tool for that
- it adds screen-text initially with the scene-name [editable] put onto its own layer [that is only 'on' in that scene]...
http://forums.sketchucation.com/viewtopic.php?p=293602#p293602 -
I'm sorry TIG. I vaguely remember that now. I can't keep track of all your fine plugins. If they don't get used frequently, they escape my memory. And my memory seems to be getting shorter and shorter.
I know the problem...
Anyway... I already made a tool for that
Now, a why am I standing at the fridge with the door open moment...
Because you have to go to the loo?
Thanks for your help everybody!
With the ruby console and the posted command everything is fine now!
Still much for us to discover with Google SketchUp...
With your input, this post could be even better ๐
