    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 17.4k Views 15 Watching
      Jim
      @tig said:
      whilst I am sure that there are very 'good reasons' for your suggested approach, I can still see little benefit to me personally to break a habit of a lifetime and actually do things 'properly' 😒
      I might have to take your attitude on this one. 😆
      http://forums.sketchucation.com/viewtopic.php?f=323&t=33956#p298681
      • simon le bonS Offline
        simon le bon
        Thank you so much to both of you Dear Tig and Jim.
        Double line works now "like a charm" in V6 👍 👍
        +simon
          Yes works fine in v6 ☀
            Jim
            @tig said:
            @jim said:
            No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
            Great minds think alike... fools never differ...
            I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
            I'm sticking with the explicit version check because it is self-explanatory. The reader can understand from the code that something has changed in SketchUp version 7.0.
            The begin-rescue clause is cryptic, and doesn't explain anything.
              JerryD5150
              I have downloaded and installed the original dline plugin on Sketchup 8 Pro and it seems to work fine. I have installed it on Sketcup 8 free version and it does not show up in the Draw tab. Is this plug in good only on Pro or should it work in the free version?
              Also....
              I have also installed the dline2 plugin and when I try to use it the settings window does not open up when I select it from the Draw menu like it did on dline.
              Help me out someone!
              • Didier BurD Offline
                Didier Bur
                The trick is to press the TAB key anytime you want to set new parameters for your "walls". It's an enhancement by J. Foltz but I forgot to display it in the status bar.
                I've published a patch for dline2 on SU8 here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=804
                Regards,
                DB
                • H Offline
                  hebeijianke
                  @didier bur said:
                  Regards,
                  [attachment=0:3j3upq39]<!-- ia0 -->dline2.jpeg<!-- ia0 -->[/attachment:3j3upq39]
                  It is not work
                  undefined method `file_loaded?' for main:Object
                    Didier Bur
                    Don't know why it doesn't work on your side.
                    Workaround: open dline2.rb in a text editor, replace the four last lines with these:
                    #Menu
                    #if( not file_loaded?("dline2.rb"))
                        UI.menu("Draw").add_item("Double Line") { Sketchup.active_model.select_tool(Bur;;Dline_Tool.new) }
                    #end
                    #file_loaded("dline2.rb")
                    DB
                      @hebeijianke said:
                      It is not work
                      @didier bur said:
                      Because the plugin doesn't require sketchup.rb - which is required for file_loaded? to work.
                      Other users probably had plugins that loaded before this plugin that required the file and therefore the bug has not been noticed.
                        Didier Bur
                        Thanks TT, I was not aware of that. It is fixed (at least on RLD because I cannot edit Jim's post 😉).
                        DB
                          dmorong
                          This plugin does not show up on my mac version. No load error, no selection in the menu.
                          I have tried it in both plugin folders
                          Any suggestions?
                          David
                          Macbook Pro 16" (M1)
                          Mac 12.1
                          Sketchup 22.0.353
                            Didier Bur
                            @Mac users: please help dmorong if you can, because the script works here on Mac 😒
                            DB
                              dmorong
                              Thanks for the confirmation, I had not looked in the Draw Menu, just in plugins and tools. So on a Mac it loads in the Draw Menu, which certainly makes sense.
                              The info on the Ruby Depot says it will load in the Tools Menu.
                              Mac 12.1
                              Sketchup 22.0.353
                              • EdsonE Offline
                                Edson
                                sorry, jim and didier,
                                as far as I am concerned, dline2 on mac is hardly an improvement over dline. I get no dialog and the tool behaves oddly. see below: a z-shaped wall ends up like two triangles. going back to dline. thanks anyway.
                                http://www.mahfuz.arq.br
                                  dmorong
                                  I also tried it out, once I found it, and the tab key does not invoke the options palette, so there is no way to adjust the parameters. A well designed double line tool, like the one in Bonzai, would be really useful in my field. (design for film and stage)
                                  Mac 12.1
                                  Sketchup 22.0.353
                                  • EdsonE Offline
                                    Edson
                                    two suggestions: the old dline and the wall tool in 1001bit tools, a fine set of plugins.
                                      SIVA SUNDAR
                                      Hii Everybody can u make tutorials of this topics ................ 😄
                                        awadrummer
                                        Is this still available anywhere? The download link no longer works. I like the dline2.rb that I got from http://rhin.crai.archi.fr/rld/plugin_details.php?id=804, but haven't figured out a way to change the default values. I like the idea of it storing the last values used.
                                        Thank you!
                                        Chris B.
                                        • G Online
                                          Gábor
                                          Is the one at the plugin store working for you?
                                          https://sketchucation.com/pluginstore?pln=dline2
                                            awadrummer
                                            Sorry for the delayed response. I don't receive notifications I guess when someone replies to my comments. Thank you Gábor, I got it working.
                                            • 3 / 3
