    Double Line 2 (dline.rb update)
    52 Posts 15 Posters 21.8k Views 15 Watching
      Jim
      @tig said:
      In passing... I not that you latest version of dline2 missed a 'start_operation' around line #287 so it's still not v6 compatible... πŸ˜’
      It's effectively defining 'double-click' to be taken as 'enter' - I note that ones 'Double ligne' and the others 'Double line' are also probably typos left over from Didier...
      I only intended to add some user-interface niceties such as persistent options for selfish reasons, and didn't look too closely at the other parts of the script. I did add version checking to the other start_operation, thanks.
      Download link in first post. http://forums.sketchucation.com/viewtopic.php?f=323&t=33875#p297720
        Your download link isn't working for me again [ http://forums.sketchucation.com/viewtopic.php?f=323&t=33875#p297720 viewtopic.php?f=323&t=33875#p297720 ]
        It should be http://forums.sketchucation.com/viewtopic.php?p=297720#p297720 viewtopic.php?p=297720#p297720 ???
        What do you get if you copy the link from the 'square' as I suggested earlier ?
          Jim
          @tig said:
          whilst I am sure that there are very 'good reasons' for your suggested approach, I can still see little benefit to me personally to break a habit of a lifetime and actually do things 'properly' πŸ˜’
          I might have to take your attitude on this one. πŸ˜†
          404 Not Found
          (forums.sketchucation.com)
          • simon le bonS
            simon le bon
            Thank you so much to both of you Dear Tig and Jim.
            Double line works now "like a charm" in V6 πŸ‘ πŸ‘
            +simon
              Yes works fine in v6 β˜€
                Jim
                @tig said:
                @jim said:
                No one really responded when I asked the question about begin-rescue clause with start_operation. Probably a poor choice for a topic sentence on my part.
                http://forums.sketchucation.com/viewtopic.php?f=180&t=22338
                Great minds think alike... fools never differ...
                I agree that this begin-rescue way is less prone to error like your .version v. .version_number typo which screwed Pilou's v6...
                I'm sticking with the explicit version check because it is self-explanatory. The reader can understand from the code that something has changed in SketchUp version 7.0.
                The begin-rescue clause is cryptic, and doesn't explain anything.
                  JerryD5150
                  I have downloaded and installed the original dline plugin on Sketchup 8 Pro and it seems to work fine. I have installed it on Sketcup 8 free version and it does not show up in the Draw tab. Is this plug in good only on Pro or should it work in the free version?
                  Also....
                  I have also installed the dline2 plugin and when I try to use it the settings window does not open up when I select it from the Draw menu like it did on dline.
                  Help me out someone!
                  • Didier BurD
                    Didier Bur
                    The trick is to press the TAB key anytime you want to set new parameters for your "walls". It's an enhancement by J. Foltz but I forgot to display it in the status bar.
                    I've published a patch for dline2 on SU8 here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=804
                    Regards,
                    DB
                    • H
                      hebeijianke
                      @didier bur said:
                      Regards,
                      [attachment=0:3j3upq39]<!-- ia0 -->dline2.jpeg<!-- ia0 -->[/attachment:3j3upq39]
                      It is not work
                      undefined method `file_loaded?' for main:Object
                      • Didier BurD
                        Didier Bur
                        Don't know why it doesn't work on your side.
                        Workaround: open dline2.rb in a text editor, replace the four last lines with these:
                        #Menu
                        #if( not file_loaded?("dline2.rb"))
                            UI.menu("Draw").add_item("Double Line") { Sketchup.active_model.select_tool(Bur;;Dline_Tool.new) }
                        #end
                        #file_loaded("dline2.rb")
                        DB
                          @hebeijianke said:
                          It is not work
                          @didier bur said:
                          Because the plugin doesn't require sketchup.rb - which is required for file_loaded? to work.
                          Other users probably had plugins that loaded before this plugin that required the file and therefore the bug has not been noticed.
                          • Didier BurD
                            Didier Bur
                            Thanks TT, I was not aware of that. It is fixed (at least on RLD because I cannot edit Jim's post πŸ˜‰).
                            DB
                              dmorong
                              This plugin does not show up on my mac version. No load error, no selection in the menu.
                              I have tried it in both plugin folders
                              Any suggestions?
                              David
                              Macbook Pro 16" (M1)
                              Mac 12.1
                              Sketchup 22.0.353
                              • Didier BurD
                                Didier Bur
                                @Mac users: please help dmorong if you can, because the script works here on Mac πŸ˜’
                                DB
                                  dmorong
                                  Thanks for the confirmation, I had not looked in the Draw Menu, just in plugins and tools. So on a Mac it loads in the Draw Menu, which certainly makes sense.
                                  The info on the Ruby Depot says it will load in the Tools Menu.
                                  Mac 12.1
                                  Sketchup 22.0.353
                                  • EdsonE
                                    Edson
                                    sorry, jim and didier,
                                    as far as I am concerned, dline2 on mac is hardly an improvement over dline. I get no dialog and the tool behaves oddly. see below: a z-shaped wall ends up like two triangles. going back to dline. thanks anyway.
                                    http://www.mahfuz.arq.br
                                      dmorong
                                      I also tried it out, once I found it, and the tab key does not invoke the options palette, so there is no way to adjust the parameters. A well designed double line tool, like the one in Bonzai, would be really useful in my field. (design for film and stage)
                                      Mac 12.1
                                      Sketchup 22.0.353
                                      • EdsonE
                                        Edson
                                        two suggestions: the old dline and the wall tool in 1001bit tools, a fine set of plugins.
                                          SIVA SUNDAR
                                          Hii Everybody can u make tutorials of this topics ................ πŸ˜„
                                            awadrummer
                                            Is this still available anywhere? The download link no longer works. I like the dline2.rb that I got from http://rhin.crai.archi.fr/rld/plugin_details.php?id=804, but haven't figured out a way to change the default values. I like the idea of it storing the last values used.
                                            Thank you!
                                            Chris B.
                                            • 2 / 3
