    How to hide some elements ?
    11 Posts 7 Posters 1.9k Views 7 Watching
    • E Offline
      erzane
      if I select an element (buidling) and I would like to work on it only
      I will need to hide the others buidlings around
      so, my question is
      how to hide any no selected elements please ?
      pls see this capture for better understanding
      http://img847.imageshack.us/img847/8905/capture01u.jpg
      • mitcorbM Offline
        mitcorb
        Make your selection that you wish to hide. Edit> Hide. Or start working with layers. Place elements on various layers, eg Layer 1- Bldg 1, Layer 2...
        In your example, make each building a named component and proceed.
          There is existing a plug "Invert selection" 😉
          In this crazzy plug Selection Toys by Thomthom 😎
          A must to have! ☀
          • Select your Building
          • Inverse selection
          • Hide
            so you will have only your building! 😉
            ledisnomad
            If you make that element a group or component, when you go in to edit it, you can choose to fade or hide everything else (Window > Model Info > Components > Fade Rest of Model slider and check box). I have a shortcut key assigned to toggle this setting so I can hide everything else on the fly.
            • E Offline
              erzane
              thanks a lot for your quick replies !
              ok I will check all that
              • E Offline
                erzane
                so, I checked this hiding
                it's easy to hide as you say
                I did
                selection>right click>hide
                but now my question is :
                if I continue to work on buidlings I need (not hided ones)
                -how can I reput in apparence the buidlings I hided before ?
                in everytime
                thanks
                p.s. about layers
                it looks like the layers option seems to be a little bit to complicate
                I prefere photoshop layer system
                so, I hope I will no need to use it on sketchup
                because all buldings I made I will transfer it to PS for colour and overthere I can put each ones on layers
                  You can also use the Ouliner for select anything you want 😉
                    Jim
                    Hidden geometry is maintained (by default) per Scene, so you could create a Scene with everything visible, hide some items and then add another Scene. (Window menu > Scenes dialog.)
                    Scenes are not only for creating Camera views - in fact you can opt for a Scene not to update the Camera, and only update hidden geometry by selecting only the Hidden Geomtry property on the Scenes Dialog.
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                    [flash=480,385:riigq1d2]http://www.youtube.com/v/qEYmiKh-sqs?fs=1&hl=en_US[/flash:riigq1d2]
                    • E Offline
                      erzane
                      pilou :
                      -what is ouliner ? do you wanna mean 'outliner' ?
                      jim :
                      -layer technique is not so difficult as I see
                      thanks for the tip
                      it looks good, I think I will use it
                      • Rich O BrienR Online
                        Windows > Outliner
                        Now you'll see a dialogue box that lists groups/components
                          One important thing no matter you hide things or put them on (hidden) layers; NEVER EVER hide or put geometry that is not grouped (or in a component) on to other than Layer 0. If ou want to hide something (or put onto another layer), simply select it > right click and make group. Then hide the group or put it onto any layer you wish.
                          You can always unhide your things from under the Edit menu > Unhide command or even view hidden geometry from the View menu.
