    How to hide some elements ?
    11 Posts 7 Posters 2.0k Views 7 Watching
    • mitcorbM Offline
      mitcorb
      Make your selection that you wish to hide. Edit> Hide. Or start working with layers. Place elements on various layers, eg Layer 1- Bldg 1, Layer 2...
      In your example, make each building a named component and proceed.
        There is existing a plug "Invert selection" 😉
        In this crazzy plug Selection Toys by Thomthom 😎
        A must to have! ☀
        • Select your Building
        • Inverse selection
        • Hide
          so you will have only your building! 😉
          ledisnomad
          If you make that element a group or component, when you go in to edit it, you can choose to fade or hide everything else (Window > Model Info > Components > Fade Rest of Model slider and check box). I have a shortcut key assigned to toggle this setting so I can hide everything else on the fly.
          • E Offline
            erzane
            thanks a lot for your quick replies !
            ok I will check all that
            • E Offline
              erzane
              so, I checked this hiding
              it's easy to hide as you say
              I did
              selection>right click>hide
              but now my question is :
              if I continue to work on buidlings I need (not hided ones)
              -how can I reput in apparence the buidlings I hided before ?
              in everytime
              thanks
              p.s. about layers
              it looks like the layers option seems to be a little bit to complicate
              I prefere photoshop layer system
              so, I hope I will no need to use it on sketchup
              because all buldings I made I will transfer it to PS for colour and overthere I can put each ones on layers
                You can also use the Ouliner for select anything you want 😉
                  Jim
                  Hidden geometry is maintained (by default) per Scene, so you could create a Scene with everything visible, hide some items and then add another Scene. (Window menu > Scenes dialog.)
                  Scenes are not only for creating Camera views - in fact you can opt for a Scene not to update the Camera, and only update hidden geometry by selecting only the Hidden Geomtry property on the Scenes Dialog.
                  http://sketchup.google.com/support/bin/answer.py?answer=39656
                  [flash=480,385:riigq1d2]http://www.youtube.com/v/qEYmiKh-sqs?fs=1&hl=en_US[/flash:riigq1d2]
                  • E Offline
                    erzane
                    pilou :
                    -what is ouliner ? do you wanna mean 'outliner' ?
                    jim :
                    -layer technique is not so difficult as I see
                    thanks for the tip
                    it looks good, I think I will use it
                      Windows > Outliner
                      Now you'll see a dialogue box that lists groups/components
                        One important thing no matter you hide things or put them on (hidden) layers; NEVER EVER hide or put geometry that is not grouped (or in a component) on to other than Layer 0. If ou want to hide something (or put onto another layer), simply select it > right click and make group. Then hide the group or put it onto any layer you wish.
                        You can always unhide your things from under the Edit menu > Unhide command or even view hidden geometry from the View menu.
