    1.5k Posts 478 Posters 4.3m Views 478 Watching
      @deanlegg said:
      Hi Fredo
      I just downloaded this but i didnt get LIBFREDO_Dir_36 or Libfredo6.rb
      Have I missed something
      Re-read the first post from whence you downloaded the main tool... It tells you that the you need to download the Lib AND has a link to get it...Capture.PNG
        deanlegg
        😳 Doh!!
        Thanks Tig
        • T
          Tikva2
          Hi, i have a problem, and i really don`t know what to do...
          http://s009.radikal.ru/i308/1103/87/efabcbbcf61d.jpg
            axiaosnail
            wonderful!It improves my efficiency.Thanks!
            • fredo6F
              Tikva2,
              Could you post the model.
              It looks like you have an extra edge on the face.
              fredo
              • T
                Tikva2
                Fredo, do you mean this?sorry, i dont speak english quite well))
                http://i017.radikal.ru/1103/f6/0da6ec16c106.jpg
                http://i065.radikal.ru/1103/92/56978e7d3afb.jpg
                beforehand thank you.
                • fredo6F
                  I was just asking if you could post the SKP file of your model so that I have a closer look.
                  • T
                    Tikva2
                    Ok
                    http://depositfiles.com/files/au8d700qi
                    • ArchiblogA
                      Archiblog
                      Thank you for this very useful plugin.
                      • fredo6F
                        @tikva2 said:
                        Ok
                        I cannot download the file.
                        Could you attach it to your answer (via upload attachment)
                        Thanks very much
                        • T
                          Tikva2
                          @tikva2 said:
                          Ok
                          Thanks very much
                          Here it is)
                          thanks a lot
                          123.skp
                          • fredo6F
                            Tikva,
                            I had a look at the model and now understand what happens.
                            The offset border (in green) on the large face must cross an edge which is contiguous to the main edge (in red) at its extremity in order to be prolonged.
                            This is the case if the offset is small enough:
                            However, if the offset is larger, then there is NO intersection of the green border with an edge which is contiguous to the red edge you want to round. In this case, RoundCorner simply defaults to terminating the offset border at the orthogonal projection of the edge to round.
                            I can try to do something about it, but anyway, it will create problems on the shape which have no easy solution.
                            You may want to redraw the shaping so that you arrange the first edge on the curved part is longer than the offset.
                            As an alternative, you can try to use Subdivide and Smooth, which operates on a different approach and is less sensitive to the geometry of edge and faces.
                            • T
                              Tikva2
                              ok,I understand))
                              thank you very much for this plugin)))
                                shredder7753
                                how can i download? it says i dont have the permissions?
                                • I
                                  inna.newyork
                                  i downloaded all per instruction,restarted computer, but my sketchup( pro6) says can't find those two plugins! what's wrong????
                                  • fredo6F
                                    Did you download LibFredo6 and follow the instructions which are in the main post (in particular about the unzip operation)?
                                    • T
                                      Tamp
                                      thanks a lot, it's really be usefull. πŸ˜„
                                      • N
                                        Neocene
                                        Hi there. I've had no problem installing you other great plugins. However I can't get the round corners to work. The icon shows up in the menus but when I try to click on a surface, nothing happens. I've followed your instructions in installing but I can't figure out what I'm doing wrong.
                                          You have the current LibFredo installed?
                                          You unzipped the correct files/folders into the plugins directory?
                                          • N
                                            Neocene
                                            yes I have. All the other plug ins work fine with no problems.
                                            Here are the errors that are showing up in the ruby script
                                            Error; #<Errno;;EACCES; Permission denied - E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/FredoTraceRoundCorner.txt>
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `initialize'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `open'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `create_file'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2210;in `trace'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;58;in `initialize'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `new'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `launch'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;33;in `action__mapping'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `call'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `launch_action'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;143;in `launch_action'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;159;in `startup'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `call'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `command_invoke'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;661;in `build_config_commands'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
                                            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `call'
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 74
                                            • 75
                                            • 19 / 75
