    1.5k Posts 477 Posters 4.1m Views 477 Watching
      deanlegg
      😳 Doh!!
      Thanks Tig
      • T
        Tikva2
        Hi, i have a problem, and i really don`t know what to do...
        http://s009.radikal.ru/i308/1103/87/efabcbbcf61d.jpg
          axiaosnail
          wonderful!It improves my efficiency.Thanks!
          • fredo6F
            Tikva2,
            Could you post the model.
            It looks like you have an extra edge on the face.
            fredo
            • T
              Tikva2
              Fredo, do you mean this?sorry, i dont speak english quite well))
              http://i017.radikal.ru/1103/f6/0da6ec16c106.jpg
              http://i065.radikal.ru/1103/92/56978e7d3afb.jpg
              beforehand thank you.
              • fredo6F
                I was just asking if you could post the SKP file of your model so that I have a closer look.
                • T
                  Tikva2
                  Ok
                  http://depositfiles.com/files/au8d700qi
                  • ArchiblogA
                    Archiblog
                    Thank you for this very useful plugin.
                    • fredo6F
                      @tikva2 said:
                      Ok
                      I cannot download the file.
                      Could you attach it to your answer (via upload attachment)
                      Thanks very much
                      • T
                        Tikva2
                        @tikva2 said:
                        Ok
                        Thanks very much
                        Here it is)
                        thanks a lot
                        123.skp
                        • fredo6F
                          Tikva,
                          I had a look at the model and now understand what happens.
                          The offset border (in green) on the large face must cross an edge which is contiguous to the main edge (in red) at its extremity in order to be prolonged.
                          This is the case if the offset is small enough:
                          However, if the offset is larger, then there is NO intersection of the green border with an edge which is contiguous to the red edge you want to round. In this case, RoundCorner simply defaults to terminating the offset border at the orthogonal projection of the edge to round.
                          I can try to do something about it, but anyway, it will create problems on the shape which have no easy solution.
                          You may want to redraw the shaping so that you arrange the first edge on the curved part is longer than the offset.
                          As an alternative, you can try to use Subdivide and Smooth, which operates on a different approach and is less sensitive to the geometry of edge and faces.
                          • T
                            Tikva2
                            ok,I understand))
                            thank you very much for this plugin)))
                              shredder7753
                              how can i download? it says i dont have the permissions?
                              • I
                                inna.newyork
                                i downloaded all per instruction,restarted computer, but my sketchup( pro6) says can't find those two plugins! what's wrong????
                                • fredo6F
                                  Did you download LibFredo6 and follow the instructions which are in the main post (in particular about the unzip operation)?
                                  • T
                                    Tamp
                                    thanks a lot, it's really be usefull. πŸ˜„
                                    • N
                                      Neocene
                                      Hi there. I've had no problem installing you other great plugins. However I can't get the round corners to work. The icon shows up in the menus but when I try to click on a surface, nothing happens. I've followed your instructions in installing but I can't figure out what I'm doing wrong.
                                        You have the current LibFredo installed?
                                        You unzipped the correct files/folders into the plugins directory?
                                        • N
                                          Neocene
                                          yes I have. All the other plug ins work fine with no problems.
                                          Here are the errors that are showing up in the ruby script
                                          Error; #<Errno;;EACCES; Permission denied - E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/FredoTraceRoundCorner.txt>
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `initialize'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `open'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `create_file'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2210;in `trace'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;58;in `initialize'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `new'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `launch'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;33;in `action__mapping'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `call'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `launch_action'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;143;in `launch_action'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;159;in `startup'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `call'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `command_invoke'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;661;in `build_config_commands'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
                                          E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `call'
                                          • fredo6F
                                            Neocene,
                                            Could you install the version 2.2c.
                                            Normally it does not log traces to file.
                                            Apparently, you have some access restriction for creating files by program in your Program directory.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 74
                                            • 75
                                            • 19 / 75
