    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • fredo6F
      Chromecatz,
      No progress so far, because I cannot reproduce the problem.
      Could you drop the two attached files into the ROUNDCORNER_Dir_22 folder, then, after restarting Sketchup, exercise one the laynch of the plugin, the selection of edges and the generation of geometry.
      RoundCorner_Tool.rb
      RoundCorner_Algo.rb
      Also, could you have the Ruby console open during this process, just in case you would see a message.
      There is a trace file generated, FredoTraceRoundCorner.txt in the SU Plugin directory. Could you post it back or send it by PM.
      Thanks very much.
        deanlegg
        Hi Fredo
        I just downloaded this but i didnt get LIBFREDO_Dir_36 or Libfredo6.rb
        Have I missed something
          @deanlegg said:
          Hi Fredo
          Re-read the first post from whence you downloaded the main tool... It tells you that the you need to download the Lib AND has a link to get it...Capture.PNG
            deanlegg
            😳 Doh!!
            Thanks Tig
            • T
              Tikva2
              Hi, i have a problem, and i really don`t know what to do...
              http://s009.radikal.ru/i308/1103/87/efabcbbcf61d.jpg
                axiaosnail
                wonderful!It improves my efficiency.Thanks!
                • fredo6F
                  Tikva2,
                  Could you post the model.
                  It looks like you have an extra edge on the face.
                  fredo
                  • T
                    Tikva2
                    Fredo, do you mean this?sorry, i dont speak english quite well))
                    http://i017.radikal.ru/1103/f6/0da6ec16c106.jpg
                    http://i065.radikal.ru/1103/92/56978e7d3afb.jpg
                    beforehand thank you.
                    • fredo6F
                      I was just asking if you could post the SKP file of your model so that I have a closer look.
                      • T
                        Tikva2
                        Ok
                        http://depositfiles.com/files/au8d700qi
                        • ArchiblogA
                          Archiblog
                          Thank you for this very useful plugin.
                          • fredo6F
                            @tikva2 said:
                            Ok
                            I cannot download the file.
                            Could you attach it to your answer (via upload attachment)
                            Thanks very much
                            • T
                              Tikva2
                              @tikva2 said:
                              Ok
                              Thanks very much
                              Here it is)
                              thanks a lot
                              123.skp
                              • fredo6F
                                Tikva,
                                I had a look at the model and now understand what happens.
                                The offset border (in green) on the large face must cross an edge which is contiguous to the main edge (in red) at its extremity in order to be prolonged.
                                This is the case if the offset is small enough:
                                However, if the offset is larger, then there is NO intersection of the green border with an edge which is contiguous to the red edge you want to round. In this case, RoundCorner simply defaults to terminating the offset border at the orthogonal projection of the edge to round.
                                I can try to do something about it, but anyway, it will create problems on the shape which have no easy solution.
                                You may want to redraw the shaping so that you arrange the first edge on the curved part is longer than the offset.
                                As an alternative, you can try to use Subdivide and Smooth, which operates on a different approach and is less sensitive to the geometry of edge and faces.
                                • T
                                  Tikva2
                                  ok,I understand))
                                  thank you very much for this plugin)))
                                    shredder7753
                                    how can i download? it says i dont have the permissions?
                                    • I
                                      inna.newyork
                                      i downloaded all per instruction,restarted computer, but my sketchup( pro6) says can't find those two plugins! what's wrong????
                                      • fredo6F
                                        Did you download LibFredo6 and follow the instructions which are in the main post (in particular about the unzip operation)?
                                        • T
                                          Tamp
                                          thanks a lot, it's really be usefull. πŸ˜„
                                          • N
                                            Neocene
                                            Hi there. I've had no problem installing you other great plugins. However I can't get the round corners to work. The icon shows up in the menus but when I try to click on a surface, nothing happens. I've followed your instructions in installing but I can't figure out what I'm doing wrong.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 74
                                            • 75
                                            • 19 / 75
