    Dynamic Arrows
    11 Posts 6 Posters 5.1k Views 6 Watching
      Soundtracker
      Hi!
      I'm trying to figure out a way to achieve this kind of "arrows".
      Do you guys have any idea how to make them inside sketchup, plugin maybe...
      http://farm1.static.flickr.com/177/436153258_83c83421c1_z.jpg
      (model sketchup + microstation arrows)
      http://www.treehugger.com/smarter386.jpg
        Maybe with extrude edges by Rails by Tig 😉
        Here I am using only 2 curves ! A curve welded and a line (2 segments welded)
        In case of using 4 curves (2 profils + 2 rails)
        Each curve 2 by 2 must have same number of segments for a more speedy result!
          Soundtracker
          Thanks Pilou! I'll try that might work, I was searching a sort of "stripe or arrow along 3d path" simmilar to this would be awesome
          http://www.fordesigner.com/pic/big/200810261352878177801.jpg
            Here's a couple of 3D swooshing arrows, made from some welded curves and a straight 2-segment profile with EEbyRails, afterwards the arrowheads were drawn on, the edges were hidden and transparent materials added to the surfaces...Capture.PNG
            • Rich O BrienR Online
              Couldn't you use PowerPoint?
              Or Illustrator if you have that?
              Or do you want to orbit with these arrows?
                Soundtracker
                Yes I'd like to draw it inside sketchup. I think a spline with EEbyRails solves it, thanks TIG 😉
                  You can of course all deform in any 3D ways, size etc...by Fredo Scale 👍!
                  So some dynamic 3D forms! 😎
                    Or like this 😉
                    Grow by Tig with some various possibities of regulates! 👍
                    Curviloft by Fredo6 👍
                    So just one line to draw, and 3 lines for the top arrow! 😎
                    Total = 4 lines 💚
                    I dont think that you can find more speedy and easy! ☀
                      TIG, that shape is very lovely! 😉
                        Soundtracker
                        Great! Thanks a lot for your help guys
                          dtrarch
                          Hi soundtracker
                          Just use the SU text fcn and instead of entering text in the box just press the [space] and no text is entered. 👍
                          Pushpin for leader.
                          Not perfect but OK for quick notation.
                          dtr
