    Dynamic Arrows
    11 Posts 6 Posters 5.5k Views 6 Watching
      Soundtracker
      Hi!
      I'm trying to figure out a way to achieve this kind of "arrows".
      Do you guys have any idea how to make them inside sketchup, plugin maybe...
      http://farm1.static.flickr.com/177/436153258_83c83421c1_z.jpg
      (model sketchup + microstation arrows)
      http://www.treehugger.com/smarter386.jpg
        Maybe with extrude edges by Rails by Tig 😉
        Here I am using only 2 curves ! A curve welded and a line (2 segments welded)
        In case of using 4 curves (2 profils + 2 rails)
        Each curve 2 by 2 must have same number of segments for a more speedy result!
          Soundtracker
          Thanks Pilou! I'll try that might work, I was searching a sort of "stripe or arrow along 3d path" simmilar to this would be awesome
          http://www.fordesigner.com/pic/big/200810261352878177801.jpg
            Here's a couple of 3D swooshing arrows, made from some welded curves and a straight 2-segment profile with EEbyRails, afterwards the arrowheads were drawn on, the edges were hidden and transparent materials added to the surfaces...Capture.PNG
              Couldn't you use PowerPoint?
              Or Illustrator if you have that?
              Or do you want to orbit with these arrows?
                Soundtracker
                Yes I'd like to draw it inside sketchup. I think a spline with EEbyRails solves it, thanks TIG 😉
                  You can of course all deform in any 3D ways, size etc...by Fredo Scale 👍!
                  So some dynamic 3D forms! 😎
                    Or like this 😉
                    Grow by Tig with some various possibities of regulates! 👍
                    Curviloft by Fredo6 👍
                    So just one line to draw, and 3 lines for the top arrow! 😎
                    Total = 4 lines 💚
                    I dont think that you can find more speedy and easy! ☀
                      TIG, that shape is very lovely! 😉
                        Soundtracker
                        Great! Thanks a lot for your help guys
                          dtrarch
                          Hi soundtracker
                          Just use the SU text fcn and instead of entering text in the box just press the [space] and no text is entered. 👍
                          Pushpin for leader.
                          Not perfect but OK for quick notation.
                          dtr
