    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 34.9k Views 21 Watching
      MartinRinehart
      One model is a bit troublesome....
      174 Layers, 50 or so Scenes.
      Very interesting. As models go, that's certainly huge. But as numbers go, those are small ones. Computer programs tend to break at, for instance, integers that cross 2 billion (the maximum for twos-complement, 32-bit integers).
      What OS, and exactly what fails? How big is the model and how much RAM is available? Thanks.
        ktkoh
        I downloaded the script and will try it on my woodworking models as I seem to use lots of scenes and layers.
        Question: In a ruby script when I know both the layer name and the scene name what would I have to do to add the layer as visible in the scene?
        Keith
          MartinRinehart
          Scenes are called "Pages" in the API. And just to keep you on your toes, there's a Pages.count method, not Pages.length.
          Each Page comes with a list of invisible layers. You find the layer you want in this list and delete it from the list.
          More generally, I don't encrypt my code. You might find the classes I wrote useful.
            Panga
            Martin, happy to see progress on vismap. Can I suggest one thing that can follow your idea of having a better reading of the whole table. Could it be possible to have one scene number with the normal font and the next one with the bold font, in order to have this :
            12345678910111213141516171819...
            This way when the scene number has two digits, it'll be easier to read them. Or maybe find another way to dissociate scene numbers...just an idea...
            Anyway, thanks for this wonderfull plugin !!
              MartinRinehart
              @panga said:
              ... when the scene number has two digits, it'll be easier to read them.
              Good idea. They were all bold, but boldface is too fat. Doesn't reduce well.
              On the other hand, if I alternated two colors, ...
              Try this. Edit .../Plugins/vismap2/vismap2_main.js. Insert the middle line you see here, at line 83. (Other two lines shown so you can see exactly where it goes.)
                		cell.align='center';
              		cell.style.background = colors[ i % 2 ];
              		cell.style.fontSize = ( size_cb + 1 ) + 'px';
              I think we'll call this the Panga imProvement.
                Panga
                Thanks 😉 . It works perfectly !! I'll give you more feedback soon.
                • E Offline
                  Ecuadorian
                  Thank you, Martin. There have been some situations when I get lost among my layers/scenes, so this will be useful. 👍
                  -Miguel Lescano
                  • E Offline
                    Ecuadorian
                    Martin, this plug-in has now proved to be a life-saver. I now have a project with several scenes for an animation and when I added SketchyPhysics into the mix I had two options: Manually turn off the Physics Joints layer in every single scene... or do it in a couple of click with VisMap. 👍
                    -Miguel Lescano
                    • bagateloB Offline
                      bagatelo
                      I think this is not working in SU8. 😢
                        bizmen
                        what do you mean its not working. Man its working perfectly.
                        This plugin is very efficient if you made your layers properly.
                        Thank you the plugin creator 🎉 🎉 🎉
                        • bagateloB Offline
                          bagatelo
                          not working to me....
                            small08
                            Love organization and simplicity! Thanks Martin
                            • F Offline
                              function
                              It's not working.
                              (worst first post ever)
                              • F Offline
                                function
                                😲 to be more helpful - 😒 the html dialog doesn't come up when accessed from the menu, no error messages or anything
                                edit: upon having some other issues in SKP, I flushed my plugins folder; visMap now works- I will update again if I can narrow down which plugin caused the conflict 👍
                                • boofredlayB Offline
                                  boofredlay
                                  Martin, I get this error when trying to run VisMap 2.
                                  The file has 44 layers and 40 scenes.
                                    smb5823
                                    Hi Martin
                                    Great Tool.
                                    Would it be possible to extend VisMap 2 to include 'shadows ON/OFF'?
                                    In large complex models it would be useful in particular to be able turn off shadows in one or more scenes without having to select, and then wait for the scene to be fully rendered with shadows before you can turn the shadows off.
                                    I have models and animations which in the final output need shadows on, but for working and tweaking things the wait for the scene to be fully redrawn is frustrating. What do you think? ❓
                                    • H Offline
                                      haynesc
                                      Hi can anyone help me ?
                                      For some strange reason this tolls has stopped working on my machine all of a sudden ... i activate the tool from plugins menu and nothing happens no dialog box opens nothing
                                      why would this happen ?
                                      • H Offline
                                        haynesc
                                        ok im now getting this message:
                                        Error Loading File vismap2_menu.rb
                                        can't convert nil into String
                                        • josephkim626J Offline
                                          josephkim626
                                          Hi, I have been using this plugin until 2014 came out. It hasn't been working for sometime. Will there be any future development?
                                            Jim
                                            Martin gave me the ok to update this for Sketchup 14/15. I might not have time until the weekend.
                                            • 1 / 3
