    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 37.1k Views 21 Watching
    • E
      Ecuadorian
      Martin, this plug-in has now proved to be a life-saver. I now have a project with several scenes for an animation and when I added SketchyPhysics into the mix I had two options: Manually turn off the Physics Joints layer in every single scene... or do it in a couple of click with VisMap. 👍
      -Miguel Lescano
      • bagateloB
        bagatelo
        I think this is not working in SU8. 😢
        • B
          bizmen
          what do you mean its not working. Man its working perfectly.
          This plugin is very efficient if you made your layers properly.
          Thank you the plugin creator 🎉 🎉 🎉
          • bagateloB
            bagatelo
            not working to me....
              small08
              Love organization and simplicity! Thanks Martin
              • F
                function
                It's not working.
                (worst first post ever)
                • F
                  function
                  😲 to be more helpful - 😒 the html dialog doesn't come up when accessed from the menu, no error messages or anything
                  edit: upon having some other issues in SKP, I flushed my plugins folder; visMap now works- I will update again if I can narrow down which plugin caused the conflict 👍
                  • boofredlayB
                    boofredlay
                    Martin, I get this error when trying to run VisMap 2.
                    The file has 44 layers and 40 scenes.
                      smb5823
                      Hi Martin
                      Great Tool.
                      Would it be possible to extend VisMap 2 to include 'shadows ON/OFF'?
                      In large complex models it would be useful in particular to be able turn off shadows in one or more scenes without having to select, and then wait for the scene to be fully rendered with shadows before you can turn the shadows off.
                      I have models and animations which in the final output need shadows on, but for working and tweaking things the wait for the scene to be fully redrawn is frustrating. What do you think? ❓
                      • H
                        haynesc
                        Hi can anyone help me ?
                        For some strange reason this tolls has stopped working on my machine all of a sudden ... i activate the tool from plugins menu and nothing happens no dialog box opens nothing
                        why would this happen ?
                        • H
                          haynesc
                          ok im now getting this message:
                          Error Loading File vismap2_menu.rb
                          can't convert nil into String
                          • josephkim626J
                            josephkim626
                            Hi, I have been using this plugin until 2014 came out. It hasn't been working for sometime. Will there be any future development?
                              Jim
                              Martin gave me the ok to update this for Sketchup 14/15. I might not have time until the weekend.
                                driven
                                can you leave out the dated css??
                                  db11
                                  That's great news Jim. Will look forward to the update.
                                  • josephkim626J
                                    josephkim626
                                    Same here!
                                      Jim
                                      Here is version 2.1.
                                      • Updated to work with Ruby 2 versions of SketchUp (version 14 or later.) Use the original version if you want to use Vismap2 on earlier versions of SketchUp.
                                      • Made a SketchUp Extension to allow enabling/disabling in extension managers.
                                      I am not sure how to handle distribution. I am unable to put it in the Plugins Store under Martin's name. That would make it harder to do further updates. I could post it under my plugins, but not sure if it would cause much confusion.
                                      vismap-v2.1.rbz
                                        Jim
                                        At some point. Can you help? Do you do Bitbucket/git?
                                          driven
                                          git, a bit...
                                          I clone things to my mac, mess about, then panic when it asks if I want to commit changes...
                                          I may still even have css for this one, a 'native' os look...
                                          • G
                                            glro
                                            works perfectly again in SU15
                                            thank you
                                            • 1 / 3
