    Thumbnails in Windows 64bit not SU
    8 Posts 6 Posters 2.3k Views 6 Watching
      If you run Windows 7 64bit you can not see thumbnails for your saved models in Windows Explorer. But if you install Q-Dir (Freeware) it enables Thumbnails for .skp. I discovered this by accident after installing Q-Dir recently.
      Here's an example....
      As an added bonus I've also installed WizMouse recently and noticed that it enables use of your Scroll-Wheel in the Component/Material Browser which is a big time saver if you ask me!
      There is a checkbox under settings that needs to be enabled for this to work...
      Enable mouse wheel for apps without mouse wheel support
      I've haven't noticed any issues as yet with this enabled but if anyone does let me know.
      Hope you find these useful?
      • dereiD
        derei
        This feature should be added in a future SU release, also with a keyword filter box, like in outliner. Maybe Google guys will think the same πŸ˜„
        DESIGNER AND ARTIST DEREI.UK
        • K
          Khai
          the Skp only works in Qdir since it's using 32bit librarys to do the preview.
          you get the same effect with FreeCommander etc.. Windows Explorer still won't see them properly 😞
            I see what the big kerfuffle is now. I don't use thumbnails normally, list view does me. But now I see what Bombom's beef with 64bit is. He wants thumbnails enabled from within SU.
            I'll shuffle off into the distance..... 😞
              MysticThumbs ($25) gives you thumbnails for .skp and .skm along with a host of other formats under 64bit Windows.
              http://mysticcoder.net/mysticthumbs.html
              πŸ‘
                That I knew, I just never clicked the within SU part πŸ˜’
                I've edited topic title to reflect this and moved Bombom one place up in my πŸ‘Š list!
                • N
                  nitav
                  thanks.!!!
                  • designerbursaD
                    designerbursa
                    XnView - Image viewer that also displays thumbnails for SketchUp files
