    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 535.2k Views 108 Watching
      gistman
      Seems like a fantastic tool, although I can't get it to work- "Can`t click "Next point". Any tool." Same as maxosmedia. I'm using windows XP with SU v7 and reloaded it as TIG suggested. I was wondering if there is conflict with another plug-in? Just a guess as I have no experience writing ruby.
        maxosmedia
        @tig said:
        @maxosmedia said:
        Error Loading File building_structure_tool.rb
        > > no such file to load -- building_structure_tool\tst_main.rb
        MacOSX SU8
        I suspect you have misinstalled from the zip file.
        When a script comes in a zip file you usually get one script [.rb] file and a folder containing everything else that the rb file 'loads' or needs to work.
        The 'loose' rb file and the folder MUST be put into your Plugins folder exactly as they are arranged in the zip file.
        Do not move files from the subfolder into the Plugins folder.
        This shows the only two additional things that you should have in your Plugins folder after the installation.[attachment=0:3vlvifww]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3vlvifww] If you have put some of the files in Plugins that should actually be in the subfolder then please move/remove as needed...
        TIG, Thank you! I just did. Therefore, no error at this point. Error may be found in document building_structure_tool.rb strings 5β€”10:
        %(#FF0000)[require 'building_structure_tool\tst_main.rb'
        require 'building_structure_tool\tst_extend_to_face.rb'
        require 'building_structure_tool\tst_extend_to_structure.rb'
        require 'building_structure_tool\tst_chamfer_structures.rb'
        require 'building_structure_tool\tst_grow_to_structure.rb'
        require 'building_structure_tool\tst_grow_to_face.rb']
        These lines contain a "" instead of the "/" for macintosh file system.
        If I correct the document building_structure_tool.rb, the tool is loaded with no error messages, but the tool does not work!
          tak2hata
          Hi, TIG and maxosmedia.
          Thank you for helping.
          I am out now.
          I will correct it after.
          I will investigate the cause.
          Please wait for a while.
          by TAK2HATA
          • Bob JamesB Offline
            Bob James
            Same for me.
              paddyclown
              @bob james said:
              Same for me.
              yeh, me too 😞, no second click possible, (SU pro 8 on Vista platform)....
                I have now loaded the tool and get the same problems...
                Here are two 'tweaked' files that work.
                Replace one in Plugins and the other in the tool's own subfolder.
                I have swapped the \ to / in the 'require' statements.
                I have trapped a 'read_default' error. The author having used/tested the tool for some time won't have realized that his code crashed if a particular registry entry was missing [probably as he had written that entry ages ago in earlier tested code], but because it crashes at the start the entry never gets written ! In 'tst_main', at line #123, I've added a trap so there is no crash and it now works, writing the needed registry entry the first time you use the tool, and so all is now well...building_structure_tool.rbtst_main.rb
                  macannurc
                  thanks to both tak2hata & Tig πŸ€“
                  I can finally test it, and it seems a plugin with great potential
                  Google SketchUp Pro 7 (7.0.10248)
                  Mac OSX 10.4.11, old PPC G4
                    tak2hata
                    Thanks TIG!
                    It was not hit on at all where I am necessary to put up the hand.
                    It was doubted that it was a problem of the inch in my conception.
                    Now It work with your help!
                    EDIT: by TIG - An updated version of all of the files is now available here...
                    http://forums.sketchucation.com/viewtopic.php?p=315482#p315482
                    Hi,howardhong!
                    I'm grad to see you.
                    Help from Korea and other countries will surely recovers Japan.
                    Therefore, we also work hard.
                    Thanks for all!
                    best regard.
                    by TAK2HATA
                    • HumpmetwiceH Offline
                      Humpmetwice
                      Is there anyway to add beam sizes to this?
                        paddyclown
                        just a word: thankyou ! πŸ‘
                        well done guys, a nifty tool is born... maybe you should get together with Goh who does the 1001bit tools ? Between you you may just turn SU into the only fun BIM program out there πŸ˜„
                        all the best...
                          In the folder 'building_structure_tool' there are two CSV files:
                          default_pflist.csv contains the steel sizes and standard sizes of other things used in the tool
                          You can edit those in plain text editor - e.g. around line #151
                          ##STEEL_BEAM,β€œSœ¬—À,,,,,,
                          b15,H-150x75x5x7,,,,matSTEEL,BLACK,BLACK
                          b19,H-198x99x4.5x7,,,,matSTEEL,BLACK,BLACK
                          This 'b15' is one country's standard 'code', and the 4 relevant sizes in 'mm', 'material' etc... but you can add your own - just ensure that the ',' count is the same...
                          You could also add other things like additional items at the end...
                          Also default_pipelist.csv contains 'tube' code/sizes.
                            Bob James
                            Does anyone have a "Rosetta Stone" to convert these codes into USA codes?
                            • W Offline
                              watkins
                              Don't forget this:
                              http://www.cad-addict.com/2009/07/sketchup-plugins-engineering-toolbox.html
                              and this:
                              http://sketchup.engineeringtoolbox.com/flange-beams-columns-to_10.html
                              There is also beamtool.rb and Steels.rb which can be found here http://rld.crai.archi.fr/rld/plugins_list_az.php
                              Regards,
                              Bob
                                try this http://www.structural-drafting-net-expert.com/steel-beam.html ?
                                My old SteelSections includes most UK/EU sizes... in the txt file...
                                • W Offline
                                  watkins
                                  Dear TIG,
                                  Where would one find 'ye olde SteelSection.rb'?
                                  Regards,
                                  Bob
                                    @watkins said:
                                    ...Where would one find 'ye olde SteelSection.rb'?...
                                    Try here http://rhin.crai.archi.fr/rld/plugin_details.php?id=412 [all all good scripts go in the twilight of their years.........]
                                    • W Offline
                                      watkins
                                      Ah, didn't realise that Steels was the same as SteelSection.
                                      Thanks, Bob
                                        It would appear that this plugin causes the old grayed out menu items. I haven't seen that for awhile but it happened after I installed this one. I've deleted it and I have no problem.
                                          tak2hata
                                          Thanks about the info of world steel beam tables.
                                          I will read it later.
                                          Earthquake hit me now!
                                          Very Terrible.
                                          by TAK2HATA
                                            @dave r said:
                                            It would appear that this plugin causes the old grayed out menu items. I haven't seen that for a while but it happened after I installed this one. I've deleted it and I have no problem.
                                            This new tool does add 14 additional commands, which might just tip you over the mythical limit and then causes gray-outs...
                                            It needs those for the Toolbar, but since it doesn't use context-menus it's weird as that is the usual connection...
                                            You don't need to uninstall the tool completely, you can simply rename 'building_structure_tool.rb' as 'building_structure_tool.rb.txt' so it isn't auto-loaded at startup; then later if you want the tool's functions you can type load "building_structure_tool.rb.txt" in the Ruby Console and it's loaded for the rest of that session...
                                            Do you have 'ContextMenuOptimizer' by AlexM, which tries to optimize 'commands' to reduce 'gray-outs'?
                                            • 16
                                            • 17
                                            • 2 / 17
