    [Plugin] Purge All
    65 Posts 32 Posters 146.1k Views 32 Watching
      j40
      I tried to use purgeall.rb on my scene, but it fezzes SU and than crash. 😲
      Similar thing happens when i use su's purge on this model.
      I have more than 200 materials of witch i use only 5 !
      Top3D Studio
      • Chris FullmerC Offline
        Try doing a manual purge by going to Window>Model Info>Statistics>Purge All
        See if that crahes SU also.
          Sounds like it's something with the model.
          Have you tried importing to a new file?
            😳 Oops, I totally missed the line where J40 said they had already tried it manually. Sorry!
              chango70
              I've recently had some issues with purge all and VRay 1.05. Basically the purge all removes some relinked Jpeg texture overides (they remain in the Sketchup Model but just doesn't render). Can be fixed easily be relinking the image. Is there a way around this? Or should I create SKMs manually for all the new textures I use?
                I don't understand.
                Texture overrides?
                Create SKMs manually?
                  chango70
                  @thomthom said:
                  I don't understand.
                  Texture overrides?
                  What I mean is. When you are unsatisfied with a defaul sketchup texture (.skm) what we do is relink it to a new texture.
                  If you rename the relinked file and right click on it and do a save-as, you can save it as a .skm file in your default sketchup material library.
                    cupko
                    Just want to thanks TIG on this amazing plugin πŸ˜„ πŸ‘
                    • W Offline
                      watkins
                      Dear TIG,
                      This plugin would be even better with two icons: Purge All (no choice) and Purge Selected (with the dialogue box and choices).
                      Is this something that you could add to your long to-do list?
                      Best wishes,
                      Bob
                      • W Offline
                        watkins
                        Dear TIG,
                        Would it be possible for the 'report' to list what it has purged? At the moment it simply tells you how many of each type it has purged (6 components, 2 layers etc), but not what. I would find that option really useful when working on large models
                        Kind regards,
                        Bob
                          @watkins said:
                          Dear TIG,
                          Kind regards,
                          Bob
                          It would have to be into some 'log' file with the model - say log='Model-Purgelog.txt' which auto opens if you have 'Report' set. [That could extend to No|Yes|Log ]. It WOULD take more time as it needs to make a lists for each type purged - e.g. for components defsIN=model.definitions.to_a and then after the purge defsOUT=model.definitions.to_a, then find what's 'gone' defsGONE=defsIN-defsOUT, then find their names and add them to the 'log' with defsGONE.each{|d|file.puts(d.name)}... I'll think about it... πŸ€“
                            Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=82559#p82559
                            The Report option now has Yes/No/Log
                            If you choose 'Log' then as well as reporting the numbers purged in a dialog, it also writes a file called 'ModelName-PurgeLog.txt' into the model's folder [or 'Untitled-...' and in the 'default folder' if it's yet to be saved]: that file then auto-opens at the end - it lists the numbers AND the 'names' of each of the purged items...
                            All as Bob's [watkins] request πŸ˜‰
                            • W Offline
                              watkins
                              Dear TIG,
                              Thank you so much for making the changes. I will find the additions very useful.
                              Kind regards,
                              Bob
                              • W Offline
                                watkins
                                Dear TIG,
                                Just a quick note to thank you for the additions. The plugin is now definitely the dog's love spuds (translate that into Spanish).
                                Thanks,
                                Bob
                                  morri
                                  @watkins said:
                                  Dear TIG,
                                  Thanks,
                                  Bob
                                  Seconded!
                                  Another Bob
                                    troikhongxanh
                                    cool !!! thank you very much
                                    • halroachH Offline
                                      halroach
                                      I just saw this post, and posted a REQ which might be related to this:
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=41498
                                      It would be really useful to purge all models within a folder or a set of folders... (I believe it would save on tons of wasted space)
                                      FlexTools - Super Quick Windows, Doors, Slats...
                                        Not a bad idea. I'd like to see all the models on the server purged. So many that are never purged... grrrr
                                          Jim
                                          Yeah, this project seems ideal for doing these batch operations... too bad no one is working on it.
                                            tspco
                                            I just downloaded it tried it works well, but is the report saved somewherw?, or is the dialog box after use, the report?
                                            SU make 2017, /Twilight Render Hobby
                                            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                            • 2 / 4
