    [Plugin] Purge All
    65 Posts 32 Posters 149.1k Views 32 Watching
      Mr S
      Well, it might not provide any fancy effects but this is an addictive little tool.
      Its amazing how much "stuff" is hiding in the background that you are unaware of.
      Particulary after importing CAD drawings it removes a lot of unwanted content.
      I keep wanting to run it every five minutes to see if it can remove anything else that shouldn't be there!
      Thanks.
      Mr S
        j40
        I tried to use purgeall.rb on my scene, but it fezzes SU and than crash. 😲
        Similar thing happens when i use su's purge on this model.
        I have more than 200 materials of witch i use only 5 !
        Top3D Studio
        • Chris FullmerC
          Try doing a manual purge by going to Window>Model Info>Statistics>Purge All
          See if that crahes SU also.
            Sounds like it's something with the model.
            Have you tried importing to a new file?
            • Chris FullmerC
              😳 Oops, I totally missed the line where J40 said they had already tried it manually. Sorry!
              • C
                chango70
                I've recently had some issues with purge all and VRay 1.05. Basically the purge all removes some relinked Jpeg texture overides (they remain in the Sketchup Model but just doesn't render). Can be fixed easily be relinking the image. Is there a way around this? Or should I create SKMs manually for all the new textures I use?
                  I don't understand.
                  Texture overrides?
                  Create SKMs manually?
                  • C
                    chango70
                    @thomthom said:
                    I don't understand.
                    Texture overrides?
                    What I mean is. When you are unsatisfied with a defaul sketchup texture (.skm) what we do is relink it to a new texture.
                    If you rename the relinked file and right click on it and do a save-as, you can save it as a .skm file in your default sketchup material library.
                    • C
                      cupko
                      Just want to thanks TIG on this amazing plugin 😄 👍
                      • W
                        watkins
                        Dear TIG,
                        This plugin would be even better with two icons: Purge All (no choice) and Purge Selected (with the dialogue box and choices).
                        Is this something that you could add to your long to-do list?
                        Best wishes,
                        Bob
                        • W
                          watkins
                          Dear TIG,
                          Would it be possible for the 'report' to list what it has purged? At the moment it simply tells you how many of each type it has purged (6 components, 2 layers etc), but not what. I would find that option really useful when working on large models
                          Kind regards,
                          Bob
                            @watkins said:
                            Dear TIG,
                            Kind regards,
                            Bob
                            It would have to be into some 'log' file with the model - say log='Model-Purgelog.txt' which auto opens if you have 'Report' set. [That could extend to No|Yes|Log ]. It WOULD take more time as it needs to make a lists for each type purged - e.g. for components defsIN=model.definitions.to_a and then after the purge defsOUT=model.definitions.to_a, then find what's 'gone' defsGONE=defsIN-defsOUT, then find their names and add them to the 'log' with defsGONE.each{|d|file.puts(d.name)}... I'll think about it... 🤓
                              Here's v1.5 http://forums.sketchucation.com/viewtopic.php?p=82559#p82559
                              The Report option now has Yes/No/Log
                              If you choose 'Log' then as well as reporting the numbers purged in a dialog, it also writes a file called 'ModelName-PurgeLog.txt' into the model's folder [or 'Untitled-...' and in the 'default folder' if it's yet to be saved]: that file then auto-opens at the end - it lists the numbers AND the 'names' of each of the purged items...
                              All as Bob's [watkins] request 😉
                              • W
                                watkins
                                Dear TIG,
                                Thank you so much for making the changes. I will find the additions very useful.
                                Kind regards,
                                Bob
                                • W
                                  watkins
                                  Dear TIG,
                                  Just a quick note to thank you for the additions. The plugin is now definitely the dog's love spuds (translate that into Spanish).
                                  Thanks,
                                  Bob
                                    morri
                                    @watkins said:
                                    Dear TIG,
                                    Thanks,
                                    Bob
                                    Seconded!
                                    Another Bob
                                    • T
                                      troikhongxanh
                                      cool !!! thank you very much
                                      • halroachH
                                        halroach
                                        I just saw this post, and posted a REQ which might be related to this:
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=41498
                                        It would be really useful to purge all models within a folder or a set of folders... (I believe it would save on tons of wasted space)
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                          Not a bad idea. I'd like to see all the models on the server purged. So many that are never purged... grrrr
                                            Jim
                                            Yeah, this project seems ideal for doing these batch operations... too bad no one is working on it.
                                            • 2 / 4
