    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 137.4k Views 95 Watching
    • unclebimU Offline
      unclebim
      Thank you thomthom and TIG, I have Fredo's plugins and all my plugins are updated. I have indeed too much of them loaded so I shall try to resolve that. I also have some component related items graying out like Explode, which happens with Tgi3D loaded. I have to cleanup the pligins obviously.
        gulcanocali
        Hi unclebim,
        Could you please give us more details about the problem you mention when Tgi3D is loaded? You can also write to our Support team from our website.
        We have not observed such behaviour ourselves. Could you please uninstall Tgi3D only and see if the problem goes away? We would appreciate your feedback so that we can resolve the issue, if any, quickly.
        Gulcan Ocali
        Product Manager
        http://www.Tgi3D.com
        • unclebimU Offline
          unclebim
          Thank you all, I have managed to get both Artisan and Tgi3D working without graying out context menu items, I have installed the Alex M script that TIG pointed to and deleted two dozens of files from the Plugins folder. So there is no problem with Artisan or Tgi3D.
          Regards
          Serafim
            muddpuddle
            Just ordered! 😄
            Artisan is a great addition to Sketchup.
              Lobster
              Congratulations on releasing this plugin! I can't imagine how much dedication was required.
              Thanks for providing an upgrade for what seems like a totally different kettle of fish, and it is good to get an evaluation period. Six days left and a bit of work to do.....artisan evaluation resize.png
              will be signing up as soon as my latest work cheque clears.
              Regards
              Sam
              • Gus RG Offline
                Gus R
                Dale,
                Great plugin and the upgrade price from SDS was very economical.
                I have a slight problem though which I hope I can describe. I make a proxy from a group and then copy the component for use in another part of the model. Everything's fine and when I update the proxy with higher iterations the component off to the side updates accordingly. However, when I close SU and then return to the skp and update that same proxy the component shoots off to one side and can sometimes be mirrored or even up or down along the z axis.
                Am I doing something wrong and/or has this been touched upon anywhere in Sketchucation?
                Anyone else encounter this or has an answer would be appreciated.
                Thx.
                www.instagram.com/gusrobatto/
                www.facebook.com/gusrobatto
                  museummaker
                  https://lh6.googleusercontent.com/_Mbz1E6DAT2U/TXvt2xxDMGI/AAAAAAAAFEM/suLDClJQk3I/s912/head-1.jpg
                  Amazing plug in, my trial is almost over but will definitely buy this one, it is so much fun and really calls up a different level of creativity-- like having SU on steroids.
                  THANK YOU!
                    Patrick, where will that cool thing fit on your street of house? Are you going to put in on the front lawn? 😄
                      museummaker
                      I guess it could but you got me thinking. Baking some foolishness now. 😕
                        Let me know when it's finished. 😄
                        • W Offline
                          Whaat
                          @gus r said:
                          Dale,
                          Thx.
                          That's weird. I'll have to test it out. Thanks for the report!
                          • Gus RG Offline
                            Gus R
                            Hi Dale. It happens when you put them in a group. Try an experiment with the attached skp.
                            1. Update the iterations for the proxies in the foreground and as you can see the components in the background update accordingly.
                            2. Group the components in the background and go back to changing the iterations with the proxies and the components continue to update accordingly.
                            3. Save this file with the grouped components with a different name such as "aritsan test 02.skp".
                            4. Start a new SketchUp file or close SketchUp.
                            5. Open "aritsan test 02.skp" and now when you update the iterations on the proxies the components will flip to a different location.
                            This happens when I either group or create a component.
                            artisan test 01.skp
                            • charly2008C Offline
                              charly2008
                              I have not yet worked with Artisan. But I find the best free alternative to generate organic forms is Sculptris and Sketchup. As far as I can judge the demonstrations is all this possible also with Sculptris. Comments are welcome, maybe I'm wrong.
                              Charly
                              Object imported from Sketchup to Sculptris
                              Changed with Sculptris.
                              Object reimported into Sketchup
                                About Sculptris & Su see this thread By Simon le Bon 😉
                                  laucity0513
                                  I know this is strange but I don't know why.
                                  I have installed this tool (15 days trial) and when I was trying to use the subdivide and smooth tool, it failed.
                                  There is no Iterations to be set and the geometry doesn't turn into mesh like what shown in video.
                                  Any idea? Thanks!
                                  • W Offline
                                    Whaat
                                    @laucity0513 said:
                                    Any idea? Thanks!
                                    Make sure you are either first selecting faces or are selecting a group or component that contains faces (not nested groups and components)
                                    Also, please check for error messages in the Ruby Console (Window->Ruby Console)
                                    • W Offline
                                      Whaat
                                      @charly2008 said:
                                      Charly
                                      Sculptris is a great program but like any external app, you can quickly run into workflow problems if you need to make changes to the geometry after you have already imported it into SketchUp. It is always nice to keep everything in the same application.
                                      Also, I don't think Sculptris is tailored very well to landscape and terrain modeling (I could be wrong). Artisan really excels at this. How would you even do this with Sculptris? For example, when modeling a real-world scene you need to have all of your references (site plan, surrounding buildings, scenery) visible to provide context as you are modeling
                                      Artisan also has many other tools besides sculpting that are awesome to finally have inside SketchUp (Soft selection, vertex editing, make planar, subdivision surfaces, paint brush, selection brush)
                                      Why not give a try for free and see what you think?
                                      • Gus RG Offline
                                        Gus R
                                        @laucity0513 said:
                                        Any idea? Thanks!
                                        My first question would be is it working though?
                                        In order to see the mesh you have to turn on hidden geometry (Top menu selection: View --> Hidden Geometry). Then:
                                        **1. Select the group containing your proxy geometry.
                                        1. Click on "Subdivide and Smooth" which will generate a default 1 iteration.
                                        2. Now, go back and double click on that same group and a small "Settings" window should pop up where you can set:
                                        a. Iterations from 1 to 4.
                                        b. Auto-update option checkbox.**
                                        Hope that helps.
                                          laucity0513
                                          @whaat said:
                                          @laucity0513 said:
                                          Any idea? Thanks!
                                          Yes. I did select faces or a group. 😞 What is nested groups?
                                          I draw a square, pull it up and group it, that's all. It should at least turns the cube into a sphere I guess?
                                            "Nested object"s are when one group is inside another group or a component-definition etc...
                                            • 14
                                            • 15
                                            • 8 / 15
