    Valiarchitects - plugins
    94 Posts 42 Posters 23.3k Views 42 Watching
      chuck vali
      @manamana said:
      question about licensing on instant road:
      If I have a laptop and a desktop, can I use a "single user license" on both or do I need two copies for that?
      You do not need to purchase additional licenses for your additional machine(s). One license will do.
        BradDAAD
        I've got a long road that seems to split the difference on interacting w/ the terrain. It appears that the outside of the curves attach to the terrain, but the inside of the curves are independent. The attached image is an example, and I've turned on shadows to show the gap between the road and the terrain. I've tried various road widths, max. segments, curve smoothing, number of curves, and sub-grade height, but nothing seems to have much of an impact. The plug-in works with more simple curved forms (also attached), but haven't found a specific 'number of curves' that work consistently or correctly to use that as a guideline. Please help!
        Road with correct path, but it doesn't interact right w/ the terrain.
        Road with simplified (but incorrect) path, which interacts correctly w/ terrain.
          louis.s
          Hi, i'm having trouble with the instant road plugin (free) and sketchup7.1 (free).
          Whatever i'm trying i get "ERROR: No group selected". i have exploded the ground surface as stated and the centerline is in a group. With both selected i activate the plugin and get the error. any tips ? The instant roof plugin is working fine btw.
            chuck vali
            I can't tell, but the road looks too close to the hole for the building. If the shoulder outline intersects any edge of the terrain - including the building hole - it will stop the script.
            If this isn't the issue, could you send me the file? I may be able to figure it out. SketchUp will sometimes confuse 2 different points as having the same location - which will cause a failure. I was surprised to discover this could sometimes happen when points were up to 1/2 inch apart. So when making the road surface, and especially when intersecting the terrain, there is a probability that this will occur. The only solution I found was to try slightly different starting conditions in an attempt to move the point where the tolerance problem occurred.
              chuck vali
              That error message is generated when the script doesn't find any group in the selection set. Are you sure that the centerline is enclosed in a group and not a component?
                louis.s
                Hm, Yes you are right, i used a component. 😳 Because the shortkey to create a component is "g" which lead me to assume it was a group. my mistake.
                Thanks for your reply btw.
                  rvdkruk
                  I'm using SU 8 pro with the freeware version of instant-road.
                  Quite often I get this result:
                  http://img12.imageshack.us/img12/8615/terrein.jpg
                  Uploaded with ImageShack.us
                  The terrain partly covers my roads.
                  Which parameter do I need to tweak?
                  thanks in advance
                    chuck vali
                    @rvdkruk said:
                    thanks in advance
                    This usually happens when the road or road shoulder is larger than the terrain. Are you certain that at the other end of the road (not shown in this image), it isn't too close to the edge of the terrain such that when the script tries to grade the shoulder it falls off the terrain?
                    • bagateloB Offline
                      bagatelo
                      You never be interested in creating plugins designed to make interior furniture?
                      What I mean is to create tools to help make interior designs, such as wardrobes, desks, sinks, shelving. Could be created tools to help build doors, drawers.
                      This software is a scrotum that many use here in Brazil to create interiors:
                      http://www.procad.net/en/produtosDet.aspx?idProdutos=4&idSessao=C
                      Your plugins are very good. I want to buy them soon.
                      Please visit my blog.
                      • W Offline
                        watkins
                        Dear Alex,
                        I'm not too sure what you meant to say, but you might like to check the definition of the word 'scrotum'.
                        Just a moment...
                        (www.thefreedictionary.com)
                        The software might indeed be a 'scrotum' in Brazil, but mostly everywhere else it's a handy place to keep your valuables cool.
                        Regards,
                        Bob
                          Perhaps it's meant as it's 'los cojones del perro' [ES] or it's 'bolas do cão' [PO] ???
                          At least in the UK EN the direct translation means it's 'very good' !
                          Whereas if something is a 'scrotum' in UK EN it is most definitely derogatory !!!
                            chuck vali
                            Alex,
                            Wow, you've made some very impressive designs and models!
                            I think I've already seen plugins for interior objects objects such as cabinets, doors, etc. And furniture design seems to be so much about uniqueness that I'm not sure what I would make the script do. Perhaps I just don't understand the issue enough. What kind of features would a such a script have?
                            Chuck
                            • ddimauroarchD Offline
                              ddimauroarch
                              Hi chuck
                              Could you please check if your website is down? It is affecting the plugin in SketchUp, and I have been unable to use it.
                                MtnArch
                                I just checked the website and it is functioning fine for me. I'm not sure if Chuck still watches the forum, but you can email him here: https://valiarchitects.com/contact
                                Highest Regards,
                                Alan T. Hendry, RA
                                Architect
                                • 5 / 5
