    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Barcelona Chair [TUTORIAL]
    19 Posts 12 Posters 5.8k Views 12 Watching
    • Gus RG Offline
      Gus R
      Here's a Barcelona chair that I fully modeled in SketchUp and rendered in Kerkythea.
      The leather upholstery and buttons was created using the standard Subdivide and Smooth with piping using "lines into tubes" and everything else is standard free SketchUp tools.
      I'm thinking about uploading the model to the Components forum. The cleaned up model with stool is about 1.7 MB.
      I modeled this to provide high detail for interior rendering and other work. Thus, it is not a completely 100 percent replica but it's very close.
      Barcelona chair close-up.
      Barcelona chair and stool.
      Barcelona chair and stool - Black
      Barcelona chair and stool - Red
      ➑ Update 1:
      OK, I added part 1 of a tutorial which covers the basics for the cushions. This might wind up in the Tutorials Forum but here it for now.
      Barcelona Chair Tutorial: The Cushion - Part 1
      ➑ Update 2:
      Barcelona Chair Tutorial: Piping - Part 2
      ➑ Update 3:
      Tutorials saved as SU6:
      Barcelona Chair Tutorial: The Cushion - Part 1 (SU6)
      Barcelona Chair Tutorial: Piping - Part 2 (SU6)
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Rich O BrienR Online
        You did a wonderful job on that model. Would like to see some wirferames!
        • Gus RG Offline
          Gus R
          Thanks. Was just working on some images of the SketchUp model itself.
          Back Edges + X-Ray in SketchUp
          Back Edges + Hidden Geometry
          Kerkythea
            cadmunkey
            Superb model, well done. I have the white one myself!
            • jarynzlesaJ Offline
              jarynzlesa
              super modeling πŸ‘ . any chance to sharing?
              http://www.vizualizaceschodiste.mypage.cz/
              • HieruH Offline
                Hieru
                Fantastic work πŸ‘
                Would you mind sharing your technique for modelled the piping on the chair?
                www.davidhier.co.uk
                  jsteacy
                  great modeling! A few snap shots of how you did it would be great! +1 for sharing it if you are willing to.
                    designerstuart
                    i'm interested in how you created the seat surface - not familiar with subdivide and smooth. did you extrude and intersect, followme or something more clever?
                      Slimdog
                      Great render and model. Good to see that some people find kerkythea easy.
                      • V Offline
                        Vicspa
                        Great job Gus, πŸ‘ hope you can find time to put out a tutorial on the seat and piping. πŸ˜„
                        • Gus RG Offline
                          Gus R
                          Thank you again. I'm still trying to get a hang of Kerkythea which does get easier with time. The key like most everything is practice, practice, practice.
                          I added a tutorial for the cushion above. Might get to the piping later today or tomorrow but for now it's as simple as using the line work from the component sections for the cushion (see skp file) and using Lines to Tubes. The centerline of the tubes and piping is the same line(s)you'll find around the component. It's a simple matter of copying and pasting the required line from the component.
                          Make sure to weld the line work before creating the tube. Also, just make one tube (piping) section which you can convert into a component. There would be two piping components for the tufted area and one for the perimeter of the cushion (top and bottom).
                          • HieruH Offline
                            Hieru
                            Thanks for taking the time to put together a really informative tutorial - it really helped me to better understand proxy modelling. Cheers πŸ‘
                            www.davidhier.co.uk
                              GdBTM
                              wow! it's a very good model!
                              can you share the .skp file for the previous versions of sketchup?
                              • Mike LuceyM Offline
                                Mike Lucey
                                Great work Gus and thanks for the tutorial πŸ‘
                                • Gus RG Offline
                                  Gus R
                                  Thanks and you're welcome. I just added a piping tutorial. You'll need "Lines into Tube" which is available here at Sketchucation.
                                  Here's the latest incarnation of the Barcelona Chair using Artisan rather than SDS. I used the sculpt brush to bump up the tufts a tiny but which also helps to smooth them out. Also did some dimension adjustments on the chair frame, stool and revised the steel to 12mm thickness.
                                  • brodieB Offline
                                    brodie
                                    I'm still on v7 but the tutorial is really intriguing. Anyone mind saving a copy down to v7 and sharing?
                                    -Brodie
                                    • Gus RG Offline
                                      Gus R
                                      -Brodie
                                      Brodie, I just uploaded parts 1 and 2 as version 6. Went down one more version just in case there are others still on 6. Hope that works for you.
                                      • V Offline
                                        Vicspa
                                        If not 6, here are versions for 7. Hope it works for you.
                                        Robatto%20-%20BarcelonaV7_1.skp
                                        Robatto%20-%20BarcelonaV7_2.skp
                                        • brodieB Offline
                                          brodie
                                          Thanks a lot for that! It was a great tutorial!
                                          -Brodie
