    Barcelona Chair [TUTORIAL]
    19 Posts 12 Posters 6.9k Views 12 Watching
      jsteacy
      great modeling! A few snap shots of how you did it would be great! +1 for sharing it if you are willing to.
        designerstuart
        i'm interested in how you created the seat surface - not familiar with subdivide and smooth. did you extrude and intersect, followme or something more clever?
          Slimdog
          Great render and model. Good to see that some people find kerkythea easy.
          • V Offline
            Vicspa
            Great job Gus, πŸ‘ hope you can find time to put out a tutorial on the seat and piping. πŸ˜„
            • Gus RG Offline
              Gus R
              Thank you again. I'm still trying to get a hang of Kerkythea which does get easier with time. The key like most everything is practice, practice, practice.
              I added a tutorial for the cushion above. Might get to the piping later today or tomorrow but for now it's as simple as using the line work from the component sections for the cushion (see skp file) and using Lines to Tubes. The centerline of the tubes and piping is the same line(s)you'll find around the component. It's a simple matter of copying and pasting the required line from the component.
              Make sure to weld the line work before creating the tube. Also, just make one tube (piping) section which you can convert into a component. There would be two piping components for the tufted area and one for the perimeter of the cushion (top and bottom).
              www.instagram.com/gusrobatto/
              www.facebook.com/gusrobatto
              • HieruH Offline
                Hieru
                Thanks for taking the time to put together a really informative tutorial - it really helped me to better understand proxy modelling. Cheers πŸ‘
                www.davidhier.co.uk
                  GdBTM
                  wow! it's a very good model!
                  can you share the .skp file for the previous versions of sketchup?
                  • Mike LuceyM Offline
                    Mike Lucey
                    Great work Gus and thanks for the tutorial πŸ‘
                    • Gus RG Offline
                      Gus R
                      Thanks and you're welcome. I just added a piping tutorial. You'll need "Lines into Tube" which is available here at Sketchucation.
                      Here's the latest incarnation of the Barcelona Chair using Artisan rather than SDS. I used the sculpt brush to bump up the tufts a tiny but which also helps to smooth them out. Also did some dimension adjustments on the chair frame, stool and revised the steel to 12mm thickness.
                      • brodieB Offline
                        brodie
                        I'm still on v7 but the tutorial is really intriguing. Anyone mind saving a copy down to v7 and sharing?
                        -Brodie
                        • Gus RG Offline
                          Gus R
                          -Brodie
                          Brodie, I just uploaded parts 1 and 2 as version 6. Went down one more version just in case there are others still on 6. Hope that works for you.
                          • V Offline
                            Vicspa
                            If not 6, here are versions for 7. Hope it works for you.
                            Robatto%20-%20BarcelonaV7_1.skp
                            Robatto%20-%20BarcelonaV7_2.skp
                            • brodieB Offline
                              brodie
                              Thanks a lot for that! It was a great tutorial!
                              -Brodie
