    [Plugin] Edge Tools
    211 Posts 74 Posters 323.4k Views 74 Watching
    • demD
      dem
      Line disappears, when I try to snap it with angle matching on another side. 😞
      http://dem.inf.ua/skp/oops.png
        Are you keeping the cursor over the face?
        (I know it's something that could use some improvement.)
        • demD
          dem
          Yes. And I notice vertical snap, when moving cursor down.
          http://dem.inf.ua/skp/snap.png
            That is something I can not control - it's the SketchUp inference engine.
            • K
              kreartur
              Hi Thomas
              I'd love to use your cool tool but after installing the files I always get the following window saying:
              uninitialized constant TT::LibFehler beim Laden der Datei tt_edgetools.rb
              what can I do to run your program?
              Thank you
                @kreartur said:
                Hi Thomas
                Thank you
                Go to the download page [post#1] and use the link to the required 'Library' [TT_Lib2] and install in the Plugins folder as instructedCapture.PNG
                • C
                  cobb89
                  is close gaps same as the commercial plugin CloseOpens available on smustard??...I haven't used CloseOpens.. 😒
                    ahnvtk
                    These are really useful, thanks!
                    It wasn't so obvious how to enter a distance threshold (or that you needed to) in the "Value Control Box" (measurements toolbar) for the "close edge gaps" tool. After you select the tool it seems you can't select the measurement toolbar; apparently you're just supposed to type. If the toolbar can be selected that will be a bit more intuitive.
                    However I'm not figuring out how to use the "make vertices colinear" at all; where is that demonstrated (or where could it be)?
                      ahnvtk
                      Oh, I figured that last out; re-read the post really carefully 😄 a video shows best however.
                        I don't know what CloseOpens is... 😕
                          That's not something I can control. It's how SketchUp works. All tools that use the VCB acts like that.
                            ahnvtk
                            Ok. Thanks.
                            Responding to the previous - CloseOpens is, uh, I dunno either.. do you mean Close Edge Gaps? The video gives at least good guidance on figuring it out.
                              Yea - I wasn't sure how to describe it, because I made the tool to solve a specific problem I had, so I made the video to demonstrate it inaction. I try to make videos more often these days as they are so much more effective in demonstrating the usage.
                              • halroachH
                                halroach
                                this set of plugins works amazingly well! you're the man thomthom!
                                Just one question about inspect and close edge gaps:
                                When I hover the mouse over some of the dots there is the "best solution" and there are other solutions visible.
                                if I want to choose a different solution than the recommended, how do I get about doing that?
                                I would recommend using alt or ctrl as a toggle for choosing different options, if it's for choosing an alternate path, or for deleting. (I may have missed parts of the videos... so forgive me if the answer is out there somewhere)
                                FlexTools - Super Quick Windows, Doors, Slats...
                                • mitcorbM
                                  mitcorb
                                  For the sake of clarification: "Close Opens" is a script by Todd Burch $20us at Smustard.com
                                    There isn't any way for that at the moment. Sorry.
                                    • H
                                      HFM
                                      Hey Thomas, thanks for this plugin [it is saving me a heap of time redrawing a city map 😄 ]
                                      I do have one question though, is there a way for the plugin to ignore lines outside the component or group when splitting faces in two? At the moment I'm redrawing a map to have nice 90o corners [which makes pulling up to 3d a hell of a lot easier 😄] And while it usually is very clear which line is which, when an original line comes close to the 90o that I want it is harder to see which line you're continuing.
                                      http://forums.sketchucation.com/download/file.php?mode=view&id=65863&sid=1128763a1204bff415e7b7098ae972ee
                                        hm... your image isn't loading for me...
                                        • H
                                          HFM
                                          Oh well, it wasn't related to the question.
                                          http://forums.sketchucation.com/download/file.php?mode=view&id=65877&sid=1f1005ae594012dd65bf0057585f6022
                                          I just thought you deserved it! 😄
                                            Ah - I see.
                                            I didn't quite understand the question so I thought it was related.
                                            You're saying the tool picks up edges from outside the current context?
                                            • 11
                                            • 4 / 11
