    [Plugin] Edge Tools
    211 Posts 74 Posters 328.0k Views 74 Watching
    • C
      cobb89
      is close gaps same as the commercial plugin CloseOpens available on smustard??...I haven't used CloseOpens.. πŸ˜’
        ahnvtk
        These are really useful, thanks!
        It wasn't so obvious how to enter a distance threshold (or that you needed to) in the "Value Control Box" (measurements toolbar) for the "close edge gaps" tool. After you select the tool it seems you can't select the measurement toolbar; apparently you're just supposed to type. If the toolbar can be selected that will be a bit more intuitive.
        However I'm not figuring out how to use the "make vertices colinear" at all; where is that demonstrated (or where could it be)?
          ahnvtk
          Oh, I figured that last out; re-read the post really carefully πŸ˜„ a video shows best however.
            I don't know what CloseOpens is... πŸ˜•
              That's not something I can control. It's how SketchUp works. All tools that use the VCB acts like that.
                ahnvtk
                Ok. Thanks.
                Responding to the previous - CloseOpens is, uh, I dunno either.. do you mean Close Edge Gaps? The video gives at least good guidance on figuring it out.
                  Yea - I wasn't sure how to describe it, because I made the tool to solve a specific problem I had, so I made the video to demonstrate it inaction. I try to make videos more often these days as they are so much more effective in demonstrating the usage.
                  • halroachH
                    halroach
                    this set of plugins works amazingly well! you're the man thomthom!
                    Just one question about inspect and close edge gaps:
                    When I hover the mouse over some of the dots there is the "best solution" and there are other solutions visible.
                    if I want to choose a different solution than the recommended, how do I get about doing that?
                    I would recommend using alt or ctrl as a toggle for choosing different options, if it's for choosing an alternate path, or for deleting. (I may have missed parts of the videos... so forgive me if the answer is out there somewhere)
                    FlexTools - Super Quick Windows, Doors, Slats...
                    • mitcorbM
                      mitcorb
                      For the sake of clarification: "Close Opens" is a script by Todd Burch $20us at Smustard.com
                        There isn't any way for that at the moment. Sorry.
                        • H
                          HFM
                          Hey Thomas, thanks for this plugin [it is saving me a heap of time redrawing a city map πŸ˜„ ]
                          I do have one question though, is there a way for the plugin to ignore lines outside the component or group when splitting faces in two? At the moment I'm redrawing a map to have nice 90o corners [which makes pulling up to 3d a hell of a lot easier πŸ˜„] And while it usually is very clear which line is which, when an original line comes close to the 90o that I want it is harder to see which line you're continuing.
                          http://forums.sketchucation.com/download/file.php?mode=view&id=65863&sid=1128763a1204bff415e7b7098ae972ee
                            hm... your image isn't loading for me...
                            • H
                              HFM
                              Oh well, it wasn't related to the question.
                              http://forums.sketchucation.com/download/file.php?mode=view&id=65877&sid=1f1005ae594012dd65bf0057585f6022
                              I just thought you deserved it! πŸ˜„
                                Ah - I see.
                                I didn't quite understand the question so I thought it was related.
                                You're saying the tool picks up edges from outside the current context?
                                • H
                                  HFM
                                  Well, here's an image to make things clearer.
                                  I have a map of a city, imported from Autocad with homes drawn on it. For the scale the .dwg is normally printed at it doesn't matter if a corner is not exactly 90o [this is my replacement for a degrees symbol btw πŸ˜„ ]. So, in Sketchup I create a group on top of this map, use TIG's plugin from 2D tools to create a rectangle and then fill it, or divide it, with your tool. Using this method I take one edge of the rectangle and recreate this inside the rectangle. The only problem, as mentioned before, is that if the new line is getting close to an old line, there is a change you can click a line that is not 90o with the rest of the rectangle. This would later in my process prevent me from easily drawing roofs on these houses.
                                  So the question was, is there a way for you plugin to look only inside the group/component when selecting the first line you want to recreate inside a shape?
                                  Hope this clears things up πŸ˜„
                                  • EarthMoverE
                                    EarthMover
                                    Thom, just finished a project where the Edge Tools came in so handy. What a time saver you've created. Thanks again.
                                    I was wondering if it would be possible to create an additional tool that acts like the Divide Face tool, but does it simultaneously on two opposing faces connected by a shared (corner) edge. I do a lot of corner trim and siding details that require this and do it manually at the moment. It would also be handy for subdividing purposes. Something simple that does like in the image in a single click with a distance input. I guess you could say it's an "offset corner". I figured I'd ask you first as it seems like a logical addition to this toolset.
                                    Content Creator at Skapeup
                                      Lately I've not had as much time as I used to. So I don't feel I can commit to anything right now. Sorry. 😞
                                      • dereiD
                                        derei
                                        Well, this feature would be nice to be added to Artisan! πŸ˜„ As a free-update. Maybe somebody reads this! πŸ’š
                                        DESIGNER AND ARTIST DEREI.UK
                                        • EarthMoverE
                                          EarthMover
                                          No worries bro. Just a thought for the next update whenever you get around to it.
                                          • H
                                            harnstein
                                            Just wanted to say thanks! Comes in very handy!
                                            Great work you're doing, man πŸ˜„
                                            still sketchin'
                                            • 11
                                            • 5 / 11
