    [Plugin] Free Rotate 4.4
    92 Posts 22 Posters 60.0k Views 22 Watching
    • jeff hammondJ Offline
      here's a little variety pack πŸ˜„
      shift-- You Pressed Keycode = 131072
      control-- 262144
      option/alt-- 524288
      command-- 1048576
      return(enter)-- 13
      Y -- 121
      (shift)Y -- 89
      I -- 105
      down arrow -- 63233
      left arrow -- 63234
      / -- 47
      tab -- does nothing
        hey TIG
        i did a little investigating and think i found what's causing the problem..
        with keycode.rb, i changed line#9 to
        def onKeyUp(key, repeat, flags, view) ..(instead of onKeyDown)
        it's now returning 9 when i push the tab key
        i was digging through some fredoscale v1 files and found a version where tab was broken on mac then found what it looks like after he fixed it..
        broken:
        #Handle key down events
        def onKeyDown(key, rpt, flags, view)
        	key = Traductor.check_key key, flags, false
        	case key
        	when CONSTRAIN_MODIFIER_KEY		#Shift key Uniform vs. non-uniform
        		@shift_down = true
        		change_free_uniform()
        		return
        	when COPY_MODIFIER_KEY			#Ctrl key - Center vs. Opposite
        		@ctrl_down = true
        		change_from_center()
        		return
        	when 13
        		return
        	when 9							#TAB - Ask dimensions
        		ask_dimensions() unless @post_validate
        		return
        	@vcb_return = false
        	#Function Key options
        	return if check_function_key(key, rpt, flags, view)
        	#trapping the arrow keys for imposed direction or plane
        	unless @dragging
        		vecdir = nil
        		normal = nil
        		[[VK_UP, Z_AXIS], [VK_RIGHT, X_AXIS], [VK_LEFT, Y_AXIS], [VK_DOWN, @NUL_AXIS]].each do |kv|
        			if key == kv[0]
        				vecdir = kv[1]
        				break
        		if vecdir && !already_in_box?(vecdir)
        			@pk_vecdir = vecdir
        			execute_by_mode view
        fixed:
        #Handle key up events
        def onKeyUp(key, rpt, flags, view)
        	key = Traductor.check_key key, flags, true
        	case key
        		@shift_down = false
        		@ctrl_down = false
        		onMouseMove 0, @x, @y, view if @x
        	when 13
        		execute_by_mode view unless @vcb_return
        		@vcb_return = false
        	else
        		@from_center = ! @from_center if @ctrl_down
        (sorry, i don't know if i copy/pasted too much or too little of that script for it to be helpful 😳 πŸ˜„ ..but hopefully the answer is in there somewhere)
        • TIGT Online
          Please could you try changing your version of FreeRotate.rb.
          from the TAB code being under
          def **onKeyDown**(key, repeat, flags, view)
          to it being under
          def **onKeyUp**(key, repeat, flags, view)
          if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ?
                if @tab
                  self.make_disk()if @state>2
                  if @state==0
                    @msg=@msgAXIALPIVOT
                  elsif @state==1
                    @msg=@msgAXIALAXIS
                  else
                    @state=2
                    @msg=@msgAXIALHANDLE
                  end#if
                  @tab=false ### axial
                else
                  self.make_globe()if @state>2
                  if @state==0
                    @msg=@msgFREEPIVOT
                  elsif @state==1
                    @msg=@msgFREEAXIS
                  else
                    @state=4
                    @msg=@msgFREE
                  end#if
                  @tab=true ### free
                end#if
                view.invalidate if @ip.display? or @ip1.display?
              end#if
          It's only in the one line, save and open a SKP...
          Retry FreeRotate and see if the TAB key now works on your MAC and you toggle between 'Free' and 'Axial' modes...
          Keep the Ruby Console open to see any errors etc...
          For some reason TAB 'down' is plain flaky on the Mac - but perhaps TAB 'up' isn't !?
          If it then works on the PC too I'll change it around... otherwise I'll do both - one test for PC one for MAC ...
          I think we are getting near to a solution here...
          Thanks for your help.
          I'll issue an updated version soonest...
          Then I need to fix ALL tools for MAC with the same issue... πŸ€“
          PS: by the way here's a new version of keycode.rb that reports key-pressed and key-released events...keycode.rb
          • TIGT Online
            Here's v4.2 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
            The glitch with 'Tab' [9] on MAC etc trapped by using 'key-up' not 'key-down' check ❓
            Don't know why... but it works... πŸ˜’
            • mitcorbM Offline
              mitcorb
              FYI:
              At least on my machine, the new zipped versions do not overwrite the original stand alone rb, so I did not see the toolbar icon, and I had two instances of FreeRotate in the Plugins dropdown menu. I simply deleted the original rb file in the SU7 plugins subfolder and restarted the program. The toolbar icon loaded and, I assume the old menu line disappeared.
              Maybe this will help someone.
                working now on mac..
                i'll check 2d tools in a little bit.
                thanks a ton.
                [ed]- keycode.rb now returns 9 when releasing the tab key.. there's only one other key on my keyboard that exhibits the same behavior (no number on keydown) and that's the delete key 127
                  Tab on OSX doesn't work on keyDown?
                    correct.
                    it appears to do absolutely nothing (in sketchup)
                    depending on my system prefs, keydown will either activate the VCB regardless of what tool i'm using or cycle through all of my toolbar icons. (ie- i can activate a tool via it's icon without mouse clicking it)
                    it's as if the system is keeping tab keydown for itself and won't allow it to be re-assigned
                      d12dozr
                      TIG, thanks for the plugin πŸ‘
                      Rich, thanks for the video πŸ˜„
                      http://goo.gl/f7ooYh
                      • ken28875K Offline
                        ken28875
                        Wow! Awesome. That's what I needed. πŸ‘ πŸ‘
                        Thanks, TIG.
                        _KN
                        Follow Your Dreams.
                        • TIGT Online
                          Here's 4.3 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                          A typo (= v ==) in code corrected around line#708: was not affecting results.
                          The Gizmos' Guides are displayed even when Guides are set to be 'off' in the current Style [the 'off' setting is momentarily suspended and then restored].
                          • E Offline
                            eddy
                            Salut Γ  tous, Wow! Awesome, very useful. πŸ‘ πŸ‘ πŸ‘
                            Thanks, TIG.
                            @ ++ Eddy
                            • TIGT Online
                              Here's v4.4 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                              You might have seen elsewhere on the forums that a fix for the Instructor window has been stumbled upon... which means it can now be used for custom tools [with the right code] as well as the built-in tools...
                              My FreeRotate always had the Instructor window's files etc, but they never displayed... until now. It was believed that the Instructor part of th API was broken, but it turns out that although it is 'sort of', it is fixable after all with some ingenuity in building the file-paths etc...
                              FreeRotate's Instructor window should work cross-platform - feedback please, especially from MAC users...
                                I see trails in the Instructor dialog box. I can see it but each transitions is slighty greyed resulting in below...
                                • TIGT Online
                                  i know... I noticed this too... I need to have a look at the gif to see if I can improve it πŸ˜•
                                  PS: the gif is fine BUT SUp itself seems to add some ghosting... I'm going to compare it with the built in stuff...
                                  The html/gif/css works fine in an ordinary browser - the browser that loads for the Instructor is screwed... πŸ˜• πŸ˜•
                                  I just wanted to get the thing out and tested to see what the issues are if any, especially with MACs or users with odd set ups......
                                    It's perfect in Firefox and IE.
                                      What versions of IE are you guys dealing with?
                                      • TIGT Online
                                        I have IE8...
                                        It loads OK directly in that... but when it loads via SUp it's 'ghosting'... πŸ˜’
                                        My html's code is just cloned from the built-in Instructor html files...
                                          ie9
                                            @tig said:
                                            I have IE8...
                                            quirks mode vs standards mode?
                                            Embedded webcontrols falls back to quirks more often than the standalone - so one doesn't always get the same results.
                                            • 4 / 5
