    [Plugin] Free Rotate 4.4
    92 Posts 22 Posters 56.9k Views 22 Watching
    • jeff hammondJ Offline
      i somewhat found the thread about the problem with tab on mac..
      i'm pretty sure fredo had a mac specific thread asking about this but i can't find it.
      http://forums.sketchucation.com/viewtopic.php?p=128952#p128952
      he was confused because he used 9 as he did with JPP, which works.. but it wasn't working with freescale.
      maybe he'll see this thread.
        After a flurry ... a recap...
        TAB works with key code 9, 15?, 30??, 48??? - on PC and Mac ??
        On the separate issue - I thought I'd trapped for all of the 'exactly axial' axis glitches - obviously NOT πŸ˜’
        That is fixable...
        EDIT: simple typo that broke it - fixed... now waiting for Tab issue to resolve...
          That is fixable...
          no, tab doesn't work with any of those numbers (on mac)
          out of curiosity, i used 121 (for 'y'.. as i don't have anything assigned to that key in SU)
          and it did work.. i was able to get into axial_rotate.
            From some research...
            TAB is keycode 9 on PC and MAC [or 0x09 hex] - i.e. ASCII.
            With some locale keyboards TAB is keycode 15 [Thai?]
            TAB is also 0x30 hex which is 48 in some locale keyboards [FR?] - as in [k]VK_Tab...
            I'll trap for 9, 15 and 48 for now and reissue v4.1 will the axis glitch fixed... πŸ˜’
              Here's v4.1 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
              A typo has been fixed with the Axis on the X_AXIS which glitched unexpectedly. πŸ˜’
              The 'Tab' press for MAC key code adjusted to 9, 15 and 48 to try and trap all platforms/locales. πŸ˜•
              Menu 'Windows > Instructor' help added...
              [Note: this is [i]not working (yet) - so for now open ../FreeRotate/index.html in your web-browser untill this is fixed...][/i] πŸ€“
                sorry TIG.. tab key still not working in v4.1 on mac.
                  BUM! 😑
                  ANY Mac user's getting it to work ??
                  I can't see why not... as it now accepts keycode 9, 15 or 48 as a TAB key press...
                  Any ideas, 'team' ? πŸ˜’
                    BUM! 😑
                    I can't see why not as it now accepts keycode 9, 15 or 48 as the TAB key press...
                    fwiw, i tried 2D tools tab key (which i haven't needed before) and i think it's broken also.
                    but yeah, i'm thinking it's something other than which # to use.. i've checked a few different scripts which have tab key functionality in them, which work, and they use 9
                      Jeff
                      I know 2D Tools uses the same code - I'll have to fix that when I know for sure what the problem is... πŸ˜’
                      I've attached a short 'keycode' script.keycode.rb Can you put it into your Plugins folder and open a SKP.
                      In the Ruby Console type keycode and activate the main window and follow the simple instructions.
                      Press the 'Tab' key and report what keycode it says [on a PC it says '9'].
                      You can try pressing other non-shortcut 'modifier' keys to get there keycodes too.
                      As soon as you press a shortcut key it exits...
                      Thanks for your help.
                      PS: Change the tool's suffix to .rb.txt after testing so it no longer loads... πŸ€“
                        here's a little variety pack πŸ˜„
                        shift-- You Pressed Keycode = 131072
                        control-- 262144
                        option/alt-- 524288
                        command-- 1048576
                        return(enter)-- 13
                        Y -- 121
                        (shift)Y -- 89
                        I -- 105
                        down arrow -- 63233
                        left arrow -- 63234
                        / -- 47
                        tab -- does nothing
                          hey TIG
                          i did a little investigating and think i found what's causing the problem..
                          with keycode.rb, i changed line#9 to
                          def onKeyUp(key, repeat, flags, view) ..(instead of onKeyDown)
                          it's now returning 9 when i push the tab key
                          i was digging through some fredoscale v1 files and found a version where tab was broken on mac then found what it looks like after he fixed it..
                          broken:
                          #Handle key down events
                          def onKeyDown(key, rpt, flags, view)
                          	key = Traductor.check_key key, flags, false
                          	case key
                          	when CONSTRAIN_MODIFIER_KEY		#Shift key Uniform vs. non-uniform
                          		@shift_down = true
                          		change_free_uniform()
                          		return
                          	when COPY_MODIFIER_KEY			#Ctrl key - Center vs. Opposite
                          		@ctrl_down = true
                          		change_from_center()
                          		return
                          	when 13
                          		return
                          	when 9							#TAB - Ask dimensions
                          		ask_dimensions() unless @post_validate
                          		return
                          	@vcb_return = false
                          	#Function Key options
                          	return if check_function_key(key, rpt, flags, view)
                          	#trapping the arrow keys for imposed direction or plane
                          	unless @dragging
                          		vecdir = nil
                          		normal = nil
                          		[[VK_UP, Z_AXIS], [VK_RIGHT, X_AXIS], [VK_LEFT, Y_AXIS], [VK_DOWN, @NUL_AXIS]].each do |kv|
                          			if key == kv[0]
                          				vecdir = kv[1]
                          				break
                          		if vecdir && !already_in_box?(vecdir)
                          			@pk_vecdir = vecdir
                          			execute_by_mode view
                          fixed:
                          #Handle key up events
                          def onKeyUp(key, rpt, flags, view)
                          	key = Traductor.check_key key, flags, true
                          	case key
                          		@shift_down = false
                          		@ctrl_down = false
                          		onMouseMove 0, @x, @y, view if @x
                          	when 13
                          		execute_by_mode view unless @vcb_return
                          		@vcb_return = false
                          	else
                          		@from_center = ! @from_center if @ctrl_down
                          (sorry, i don't know if i copy/pasted too much or too little of that script for it to be helpful 😳 πŸ˜„ ..but hopefully the answer is in there somewhere)
                            Please could you try changing your version of FreeRotate.rb.
                            from the TAB code being under
                            def **onKeyDown**(key, repeat, flags, view)
                            to it being under
                            def **onKeyUp**(key, repeat, flags, view)
                            if key==9 or key==15 or key==48 ### TAB =9 for PC, MAC 15/48 for some locales ?
                                  if @tab
                                    self.make_disk()if @state>2
                                    if @state==0
                                      @msg=@msgAXIALPIVOT
                                    elsif @state==1
                                      @msg=@msgAXIALAXIS
                                    else
                                      @state=2
                                      @msg=@msgAXIALHANDLE
                                    end#if
                                    @tab=false ### axial
                                  else
                                    self.make_globe()if @state>2
                                    if @state==0
                                      @msg=@msgFREEPIVOT
                                    elsif @state==1
                                      @msg=@msgFREEAXIS
                                    else
                                      @state=4
                                      @msg=@msgFREE
                                    end#if
                                    @tab=true ### free
                                  end#if
                                  view.invalidate if @ip.display? or @ip1.display?
                                end#if
                            It's only in the one line, save and open a SKP...
                            Retry FreeRotate and see if the TAB key now works on your MAC and you toggle between 'Free' and 'Axial' modes...
                            Keep the Ruby Console open to see any errors etc...
                            For some reason TAB 'down' is plain flaky on the Mac - but perhaps TAB 'up' isn't !?
                            If it then works on the PC too I'll change it around... otherwise I'll do both - one test for PC one for MAC ...
                            I think we are getting near to a solution here...
                            I'll issue an updated version soonest...
                            Then I need to fix ALL tools for MAC with the same issue... πŸ€“
                            PS: by the way here's a new version of keycode.rb that reports key-pressed and key-released events...keycode.rb
                              Here's v4.2 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                              The glitch with 'Tab' [9] on MAC etc trapped by using 'key-up' not 'key-down' check ❓
                              Don't know why... but it works... πŸ˜’
                              • mitcorbM Offline
                                mitcorb
                                FYI:
                                At least on my machine, the new zipped versions do not overwrite the original stand alone rb, so I did not see the toolbar icon, and I had two instances of FreeRotate in the Plugins dropdown menu. I simply deleted the original rb file in the SU7 plugins subfolder and restarted the program. The toolbar icon loaded and, I assume the old menu line disappeared.
                                Maybe this will help someone.
                                  working now on mac..
                                  i'll check 2d tools in a little bit.
                                  thanks a ton.
                                  [ed]- keycode.rb now returns 9 when releasing the tab key.. there's only one other key on my keyboard that exhibits the same behavior (no number on keydown) and that's the delete key 127
                                    Tab on OSX doesn't work on keyDown?
                                      correct.
                                      it appears to do absolutely nothing (in sketchup)
                                      depending on my system prefs, keydown will either activate the VCB regardless of what tool i'm using or cycle through all of my toolbar icons. (ie- i can activate a tool via it's icon without mouse clicking it)
                                      it's as if the system is keeping tab keydown for itself and won't allow it to be re-assigned
                                        d12dozr
                                        TIG, thanks for the plugin πŸ‘
                                        Rich, thanks for the video πŸ˜„
                                        http://goo.gl/f7ooYh
                                        • ken28875K Offline
                                          ken28875
                                          Wow! Awesome. That's what I needed. πŸ‘ πŸ‘
                                          Thanks, TIG.
                                          _KN
                                          Follow Your Dreams.
                                            Here's 4.3 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                                            A typo (= v ==) in code corrected around line#708: was not affecting results.
                                            The Gizmos' Guides are displayed even when Guides are set to be 'off' in the current Style [the 'off' setting is momentarily suspended and then restored].
                                            • 4 / 5
