    [Plugin] Flattery papercraft tools
    91 Posts 41 Posters 130.3k Views 41 Watching
      Pumpkin Pirate
      @mike lucey said:
      Thanks Pumkin Pirate,
      This plugin will prove to be very useful. BTW, I have made a donation and hope that others will do likewise to help you continue its development ๐Ÿ‘
      Mike
      Wow, Thank you! I'm glad you found it useful. I'm going to do my best to keep it steadily improving.
        tfdesign
        @escapeartist said:
        This could also be used for simple sheet metal patterns.
        Exactly my thoughts too! If bend radii could be specified too, as well as thickness (I haven't checked yet), this tool will be as powerful as the one in Solidworks!
        A brilliant addition. Thanks very much!
        Tom
        • N Offline
          no8one
          Heyy !!
          plzz some help
          i downloaded this awesome plugin but when i put it in the plugins folder it's not shown in skitchup
          and i tired it on 2 computers
          plzz helpp ,,
          • Subsonic MikeS Offline
            Subsonic Mike
            I need help to.
            I do all that it says in the readme but it doesn't appear on sketchup
            Please help!
            Design Crash Learn
              @subsonic mike said:
              I need help to.
              Please help!
              Did you activate its Extension under Preferences ๐Ÿ˜•
                Subsonic Mike
                No, how?
                Design Crash Learn
                • mitcorbM Offline
                  mitcorb
                  In Sketchup: top line menu: Window>Preferences>Extensions Check box on plugin name.
                    mozzie
                    Did you copy the unzipped files?
                      Subsonic Mike
                      No, I extracted them to my downloads folder then copyed them to the SketchUp plugins folder
                      Design Crash Learn
                        No, I extracted them to my downloads folder then copied them to the SketchUp plugins folder
                        Did you keep some of the files in any subfolders etc as they were zipped ?
                          Subsonic Mike
                          Once extracted I moved the entire extracted folder to its location
                          Design Crash Learn
                            NO ?
                            I suspect you need to move the contents of that folder into Plugins...
                            In the Plugins folder there should be one file called flattery.rb and a folder called flattery containing loads of other files.
                            If you unzipped a file called flattery.zip into a folder called flattery then it's one level too deep.... ๐Ÿ˜•
                              Subsonic Mike
                              I think its best I start again
                              just one thing, is it usual to get an error when you try to extract it directly to the plugins folder?
                              Design Crash Learn
                                No.
                                Exactly what error do you get?
                                (Error messages are very useful in debugging a problem, so please include them when posting.)
                                  Subsonic Mike
                                  OK I extracted the files for the 11th time to get the error but this time it extracted fine!
                                  BUT the files dont show up when I look in the plugins folder. So I open 7 zip to extract them again but 7 zip shows them in the plugins folder.
                                  WHAT'S HAPPENING TO MY COMPUTER!
                                  Design Crash Learn
                                    I think you have a Compatibility Files issue with Vista - it tucked them away in a Compatibility folder to protect you!
                                    Look in the top bar of the Plugins folder window are there any weird folders or icons there...
                                    Vista can be a pain when it decides that you shouldn't add files to some folders...
                                      Subsonic Mike
                                      I cant seem to see any weird folders icons.
                                      Design Crash Learn
                                        Ensure that you don't have any flattery folder or file in your Plugins folder - if you do move them out...
                                        Download the zip file to say your desktop.
                                        Extract it to a folder with the name of the zip file.
                                        Open the folder and select the file and folder in it.
                                        Copy.
                                        Open the Plugins folder and Paste.
                                        You should now have the correct file+folder installed.
                                        Restart Sketchup and 'flattery' might need activating from the Preferences > Extensions section.
                                        Its toolbar is activated off View > Toolbars...
                                          Subsonic Mike
                                          IT WORKS! ๐Ÿ˜
                                          Thank you so much guys for helping me get it working! Thank you!
                                          Design Crash Learn
                                            Hoooooooooray!
                                            • 2 / 5
