    [Plugin] Flattery papercraft tools
    91 Posts 41 Posters 136.2k Views 41 Watching
    • Subsonic MikeS
      Subsonic Mike
      I need help to.
      I do all that it says in the readme but it doesn't appear on sketchup
      Please help!
      Design Crash Learn
        @subsonic mike said:
        I need help to.
        Please help!
        Did you activate its Extension under Preferences ๐Ÿ˜•
        • Subsonic MikeS
          Subsonic Mike
          No, how?
          Design Crash Learn
          • mitcorbM
            mitcorb
            In Sketchup: top line menu: Window>Preferences>Extensions Check box on plugin name.
              mozzie
              Did you copy the unzipped files?
              • Subsonic MikeS
                Subsonic Mike
                No, I extracted them to my downloads folder then copyed them to the SketchUp plugins folder
                Design Crash Learn
                  No, I extracted them to my downloads folder then copied them to the SketchUp plugins folder
                  Did you keep some of the files in any subfolders etc as they were zipped ?
                  • Subsonic MikeS
                    Subsonic Mike
                    Once extracted I moved the entire extracted folder to its location
                    Design Crash Learn
                      NO ?
                      I suspect you need to move the contents of that folder into Plugins...
                      In the Plugins folder there should be one file called flattery.rb and a folder called flattery containing loads of other files.
                      If you unzipped a file called flattery.zip into a folder called flattery then it's one level too deep.... ๐Ÿ˜•
                      • Subsonic MikeS
                        Subsonic Mike
                        I think its best I start again
                        just one thing, is it usual to get an error when you try to extract it directly to the plugins folder?
                        Design Crash Learn
                          No.
                          Exactly what error do you get?
                          (Error messages are very useful in debugging a problem, so please include them when posting.)
                          • Subsonic MikeS
                            Subsonic Mike
                            OK I extracted the files for the 11th time to get the error but this time it extracted fine!
                            BUT the files dont show up when I look in the plugins folder. So I open 7 zip to extract them again but 7 zip shows them in the plugins folder.
                            WHAT'S HAPPENING TO MY COMPUTER!
                            Design Crash Learn
                              I think you have a Compatibility Files issue with Vista - it tucked them away in a Compatibility folder to protect you!
                              Look in the top bar of the Plugins folder window are there any weird folders or icons there...
                              Vista can be a pain when it decides that you shouldn't add files to some folders...
                              • Subsonic MikeS
                                Subsonic Mike
                                I cant seem to see any weird folders icons.
                                Design Crash Learn
                                  Ensure that you don't have any flattery folder or file in your Plugins folder - if you do move them out...
                                  Download the zip file to say your desktop.
                                  Extract it to a folder with the name of the zip file.
                                  Open the folder and select the file and folder in it.
                                  Copy.
                                  Open the Plugins folder and Paste.
                                  You should now have the correct file+folder installed.
                                  Restart Sketchup and 'flattery' might need activating from the Preferences > Extensions section.
                                  Its toolbar is activated off View > Toolbars...
                                  • Subsonic MikeS
                                    Subsonic Mike
                                    IT WORKS! ๐Ÿ˜
                                    Thank you so much guys for helping me get it working! Thank you!
                                    Design Crash Learn
                                      Hoooooooooray!
                                      • G
                                        Gaiv
                                        hi everybody, i study architecture and i really love this plugin, it's very very cool because it's help me a lot to makes paper craft ๐Ÿ˜„ ... thank you conceptor but i just have a little problem, i don't understand how to use the " index Edges" function ๐Ÿ˜• and it's very important for me because i have a very complex modeling to do and it's impossible without this function... someone can help me?
                                          As explained on the tools web-page
                                          When your model is fully constructed, and you are about to unfold it, select the entire thing and press the Index Edges button. This marks all of the edges in your model so that later, when your model is unfolded, Flattery will know what used to be connected. This is critical for the Reunite Edges tool, and helpful for the Add Tabs tool.
                                          So do it at the start and thenunfold...
                                          • G
                                            Gaiv
                                            it's what i do, but there is nothing ๐Ÿ˜’ when the volume is complete i select all the model and i press the index Edges button but nothing appear =s
                                            maybe it's a bug?
                                            • 2 / 5
