    [Plugin] Flattery papercraft tools
    91 Posts 41 Posters 116.7k Views 41 Watching
      Pumpkin Pirate
      @gaieus said:
      This is very cool! I know Jim has a plugin to unfold geometry but this seems to be a much more "advanced" tool!
      Then there is the Waybe plugin but then that's commercial.
      So this will definitely be a hit for many hobbyists and such! πŸ‘
      If you do not mind, I have "borrowed" some of your images for The Daily CatchUp. πŸ˜‰
      Wow, no, I don't mind at all! In fact I'm thrilled!
      @xrok1 said:
      very nice. it would be great if you could predefine the tab sizes or have all tabs after the first one be doubleclick to repeat size. also the option to have auto number tab and corresponding edge (one that appears red when creating tab). πŸ˜„
      A setting for the width of the double-click tabs seems like a pretty good idea. Not so sure about automatic numbering, though. It would be kind of difficult to get it into the SVG file in a reliable way, and I've generally found that it's hard to know the best order to glue tabs in until you've tried putting the model together a few times. I'll think about it though.
      • X Offline
        xrok1
        thanks for considering it. with regards to the numbering, its not for the order of assembly, i was thinking more for organizing what goes where when gluing. (tab A glues to edge A) but you could glue tab Z to edge Z first it doesn't matter.
        • utilerU Offline
          utiler
          Very cool mate; and very generous!!! πŸ‘
          Welcome the the forum! πŸŽ‰
          Just Curious...
            Not sure that I have patience to glue all the pieces πŸ’š
            But very cool plug! 😎
            • I Offline
              ideas_arte
              wonderful! very very very grateful to you.
              This plugin has me very happy!
              http://www.addemoticons.com/emoticon/animated/AddEmoticons04262.gif
              Best wishes
              su model
              svg in Inkscape
              export good, good editing
              • Mike LuceyM Offline
                Mike Lucey
                Thanks Pumkin Pirate,
                This plugin will prove to be very useful. BTW, I have made a donation and hope that others will do likewise to help you continue its development πŸ‘
                Mike
                  Pumpkin Pirate
                  Mike
                  Wow, Thank you! I'm glad you found it useful. I'm going to do my best to keep it steadily improving.
                    tfdesign
                    @escapeartist said:
                    This could also be used for simple sheet metal patterns.
                    Exactly my thoughts too! If bend radii could be specified too, as well as thickness (I haven't checked yet), this tool will be as powerful as the one in Solidworks!
                    A brilliant addition. Thanks very much!
                    Tom
                    • N Offline
                      no8one
                      Heyy !!
                      plzz some help
                      i downloaded this awesome plugin but when i put it in the plugins folder it's not shown in skitchup
                      and i tired it on 2 computers
                      plzz helpp ,,
                      • Subsonic MikeS Offline
                        Subsonic Mike
                        I need help to.
                        I do all that it says in the readme but it doesn't appear on sketchup
                        Please help!
                        Design Crash Learn
                          @subsonic mike said:
                          I need help to.
                          Please help!
                          Did you activate its Extension under Preferences πŸ˜•
                            Subsonic Mike
                            No, how?
                            Design Crash Learn
                            • mitcorbM Offline
                              mitcorb
                              In Sketchup: top line menu: Window>Preferences>Extensions Check box on plugin name.
                                mozzie
                                Did you copy the unzipped files?
                                  Subsonic Mike
                                  No, I extracted them to my downloads folder then copyed them to the SketchUp plugins folder
                                  Design Crash Learn
                                    No, I extracted them to my downloads folder then copied them to the SketchUp plugins folder
                                    Did you keep some of the files in any subfolders etc as they were zipped ?
                                      Subsonic Mike
                                      Once extracted I moved the entire extracted folder to its location
                                      Design Crash Learn
                                        NO ?
                                        I suspect you need to move the contents of that folder into Plugins...
                                        In the Plugins folder there should be one file called flattery.rb and a folder called flattery containing loads of other files.
                                        If you unzipped a file called flattery.zip into a folder called flattery then it's one level too deep.... πŸ˜•
                                          Subsonic Mike
                                          I think its best I start again
                                          just one thing, is it usual to get an error when you try to extract it directly to the plugins folder?
                                          Design Crash Learn
                                            No.
                                            Exactly what error do you get?
                                            (Error messages are very useful in debugging a problem, so please include them when posting.)
                                            • 1 / 5
