    Report face surface
    26 Posts 6 Posters 3.2k Views 6 Watching
      <span class="syntaxdefault"></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">FaceReport<br />&nbsp;def&nbsp;initialize</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;ss</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />&nbsp;&nbsp;faces</span><span class="syntaxkeyword">=[];&nbsp;</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"FACE,ORIN,AREA,MATL\n"<br />&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;orin</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;area</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">0.00064516</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_s<br />&nbsp;&nbsp;&nbsp;&nbsp;matl</span><span class="syntaxkeyword">=</span><span class="syntaxstring">"<NIL>"</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">matl</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">display_name&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />&nbsp;&nbsp;&nbsp;&nbsp;text&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">text</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">+</span><span class="syntaxstring">","</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">orin</span><span class="syntaxkeyword">+</span><span class="syntaxstring">","</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">+</span><span class="syntaxstring">","</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">matl</span><span class="syntaxkeyword">+</span><span class="syntaxstring">"\n"<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;text<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil<br />&nbsp;end</span><span class="syntaxcomment">#def<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#class&nbsp;</span><span class="syntaxdefault"></span>
      Copy/Paste this code into a file called 'FaceReport.rb' in the Plugins folder.
      To use it open your .SKP, Select the faces to report on and open the Window >> Ruby Console and type 'FaceReport.new'
      It will list the faces in a comma separated set of lines, by reference,orientation,area,material.
      Note that you will need to do some work on the following:
      'reference' - I don't see this as much use?
      'orientation' - this is currently the 'face.normal' BUT can be converted into a compass direction with some mathematics as every 'normal' makes an angle with the X/Y/Z axes... Instead of N/S/E/W etc why not get the 'angle' in degrees ?
      'area' - this reports in square metres BUT you might want to format it to a number of decimal-places ?
      'material' - this reports the material name or '<NIL>' if it's the default-material.
      You can also easily 'puts' the text of the report into an external .CSV file if desired...
      • F
        flyman
        great,
        now i tried.
        thanks
        flyman
        • F
          flyman
          Yesssssssssss, it work.
          For surface in mq is ok but with two decimal like this "mq. 1234,56"
          For orientation i have thought about this scheme: the value x y understood in the red quadrant brings value in "NE" , the value x y understood in the yellow quadrant brings value in "N" etc etc, but i don't know the language ruby and I am not able to resolve the problem.
          Can you help me yet again ?
          flyman
            I see if I have a spare slot over the next few days...
            It's relatively easy to format the area text to 2 dp.
            You have come up with the N/S?E/W etc orientation testing I was expecting [I AM ahead of you πŸ˜‰ ]
            Meanwhile think about what you want in terms of an 'output' [e.g. a 'file' ??]
            • F
              flyman
              hi
              sorry bu i not understand "You have come up with the N/S?E/W etc orientation testing I was expecting [I AM ahead of you πŸ˜‰ ]
              My english language is bad ,my scholastic studies are ago of many years.
              thanks
              flyman
                I meant that you had worked out the orientation ranges that I had already drafted out...
                I'll try and look at this for you tomorrow...
                [What is you native language?]
                • F
                  flyman
                  Thanks you very very much for your work!
                  I'm an Italian architect, helped by his son (that is writing this answer!)
                    I shall post messages in English with Italian translations [my bad translation!] for you, from now on... πŸ˜‰
                    Devo postare i messaggi in Inglese con traduzione Italiana [la mia traduzione difettosa] per voi, d'ora in poi πŸ˜‰ πŸ˜‰
                      Flyman
                      Here is my script that should do what you want - put it into the 'Plugins' folder and follow the instructions...
                      Qui Γ¨ mia script che se io dΓ  che cosa volete - messo esso nel 'Plugins' e segue le istruzioni...
                      c) TIG 2011
                      RelazioneFacce.rb
                      To use type 'relazionefacce' in the Ruby Console.
                      It makes a report of all selected faces.
                      By Reference, Orientation, Area [sqm to 2 dp] and Material.
                      This is printed in the Ruby Console.
                      If the SKP has been saved a TSV file is made with it and it is
                      automatically opened.
                      Note that all text is in Italian.
                      Per utilizzare scrivere 'relazionefacce' nella Console di Ruby.
                      Si fa un report di tutte le facce selezionate.
                      Con Riferimento, Orientamento, Area [mq a 2 dp] e Materiale.
                      Questo Γ¨ stampato nella Console di Ruby.
                      Se il SKP Γ¨ stato salvato un file TSV Γ¨ fatto con esso e si apre
                      automaticamente.
                      Notare che tutto il testo Γ¨ in italiano.
                      Donations by PayPal to info @ revitrev.org
                      Version 1.0 20110203 First Issue.
                      ---RelazioneFacce.rb
                      • EarthMoverE
                        EarthMover
                        TIG - You are a hell of a guy! Your generosity is truly inspiring. β˜€
                        Content Creator at Skapeup
                        • Didier BurD
                          Didier Bur
                          My 2 cents:
                          This one will output the same TSV file as TIG's, but sorted by orientation, adds a sub-total per orientation and a general total at the end.
                          afflitto, non parlo italiano πŸ˜„
                          Enjoy!
                          RelazioneFacceSortedTotal.zip
                          DB
                          • F
                            flyman
                            I could NEVER expect a so "fast-in-make" and "match-to-my-desire" script! 😍
                            You can't imagine how many hour I can earn by this script... Much, much thanks to TIG and to DidierBur!
                            This script-making-story has interested me in Ruby. It is difficult to learn? Because I had 20 years old a good experience in Autolisp (programming language for Autocad).
                            And, abusing of you time and kindness, are there any Ruby's manual-tutorial? πŸ˜†
                            Another thanks to everybody!
                            flyman
                            • Didier BurD
                              Didier Bur
                              I also had long time ago some experience with Autolisp and learned to program with it.
                              Some books including tutorials can be found here: http://rhin.crai.archi.fr/rld/automatic_SketchUp.php
                              some links here: http://rhin.crai.archi.fr/rld/links_ruby_sites.php
                              some plugins links here:http://rhin.crai.archi.fr/rld/links_plugins_sites.php
                              and last but not least: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                              If you have some knowledge in Autolip and OO programming, Ruby is quite easy to learn (IMHO).
                              Regards,
                              DB
                              • L
                                ledisnomad
                                I'm always amazed at how quickly questions and requests get answered here at SketchUcation!
                                This script, modified a little, is serving me well as a way to get the areas of my master plan models. However, not being familiar with Ruby, yet, I wonder what it would take to do the following: sum the area each material.
                                To put it another way, I'd like a report that reads:
                                There is 460.33sf of material 01.
                                There is 230.15sf of material 02.
                                etc.
                                And it would have to work with groups and components and exclude back-faces... that's the part that makes me hesitate to try to do it myself, not knowing Ruby, yet. What do y'all think?
                                • Didier BurD
                                  Didier Bur
                                  Actually you can select a face with some material, then right-click and choose 'select all with same material', then display the 'entity info' window where you'll get the corresponding area. But that's a manual process.
                                  I think it will be a good starting idea for you to learn Ruby. Download some scripts related to materials and start from them.
                                  DB
                                  • L
                                    ledisnomad
                                    The select all with same material only works in the current context, not in components and groups, but thanks for the suggestion.
                                    • Didier BurD
                                      Didier Bur
                                      Here is a quick script that sums areas by material. It doesn't dig into groups or comps.
                                      areas_mats.zip
                                      DB
                                        To find areas of materials inside groups/components... [pseudo-coded]
                                        txt=""
                                        model.definitions.each{|defn|
                                          insts=defn.instances
                                          num=insts.length
                                          next if num==0
                                          mats=[]
                                          defn.entities.each{|e|
                                            next if not e.class==Sketchup;;Face
                                            mats << [e.material, e.area]
                                          txt << num.to_s+"\n"
                                          mats.each{|m| txt << m[0]+","+m[1]+"\n" }
                                        puts txt
                                        and so on to assemble a list of materials with areas within definitions. multiply by 'num' to get total area of all instances of each definition etc etc...........
                                        • Didier BurD
                                          Didier Bur
                                          Not that simple, don't forget that instances can be scaled...
                                          DB
                                            I realize that but he has to start somewhere πŸ˜’
