    Report face surface
    26 Posts 6 Posters 2.7k Views 6 Watching
    • F Offline
      flyman
      Thanks you very very much for your work!
      I'm an Italian architect, helped by his son (that is writing this answer!)
        I shall post messages in English with Italian translations [my bad translation!] for you, from now on... πŸ˜‰
        Devo postare i messaggi in Inglese con traduzione Italiana [la mia traduzione difettosa] per voi, d'ora in poi πŸ˜‰ πŸ˜‰
          Flyman
          Here is my script that should do what you want - put it into the 'Plugins' folder and follow the instructions...
          Qui Γ¨ mia script che se io dΓ  che cosa volete - messo esso nel 'Plugins' e segue le istruzioni...
          c) TIG 2011
          RelazioneFacce.rb
          To use type 'relazionefacce' in the Ruby Console.
          It makes a report of all selected faces.
          By Reference, Orientation, Area [sqm to 2 dp] and Material.
          This is printed in the Ruby Console.
          If the SKP has been saved a TSV file is made with it and it is
          automatically opened.
          Note that all text is in Italian.
          Per utilizzare scrivere 'relazionefacce' nella Console di Ruby.
          Si fa un report di tutte le facce selezionate.
          Con Riferimento, Orientamento, Area [mq a 2 dp] e Materiale.
          Questo Γ¨ stampato nella Console di Ruby.
          Se il SKP Γ¨ stato salvato un file TSV Γ¨ fatto con esso e si apre
          automaticamente.
          Notare che tutto il testo Γ¨ in italiano.
          Donations by PayPal to info @ revitrev.org
          Version 1.0 20110203 First Issue.
          ---RelazioneFacce.rb
          • EarthMoverE Offline
            EarthMover
            TIG - You are a hell of a guy! Your generosity is truly inspiring. β˜€
            Content Creator at Skapeup
            • Didier BurD Offline
              Didier Bur
              My 2 cents:
              This one will output the same TSV file as TIG's, but sorted by orientation, adds a sub-total per orientation and a general total at the end.
              afflitto, non parlo italiano πŸ˜„
              Enjoy!
              RelazioneFacceSortedTotal.zip
              DB
              • F Offline
                flyman
                I could NEVER expect a so "fast-in-make" and "match-to-my-desire" script! 😍
                You can't imagine how many hour I can earn by this script... Much, much thanks to TIG and to DidierBur!
                This script-making-story has interested me in Ruby. It is difficult to learn? Because I had 20 years old a good experience in Autolisp (programming language for Autocad).
                And, abusing of you time and kindness, are there any Ruby's manual-tutorial? πŸ˜†
                Another thanks to everybody!
                flyman
                  Didier Bur
                  I also had long time ago some experience with Autolisp and learned to program with it.
                  Some books including tutorials can be found here: http://rhin.crai.archi.fr/rld/automatic_SketchUp.php
                  some links here: http://rhin.crai.archi.fr/rld/links_ruby_sites.php
                  some plugins links here:http://rhin.crai.archi.fr/rld/links_plugins_sites.php
                  and last but not least: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                  If you have some knowledge in Autolip and OO programming, Ruby is quite easy to learn (IMHO).
                  Regards,
                  DB
                    ledisnomad
                    I'm always amazed at how quickly questions and requests get answered here at SketchUcation!
                    This script, modified a little, is serving me well as a way to get the areas of my master plan models. However, not being familiar with Ruby, yet, I wonder what it would take to do the following: sum the area each material.
                    To put it another way, I'd like a report that reads:
                    There is 460.33sf of material 01.
                    There is 230.15sf of material 02.
                    etc.
                    And it would have to work with groups and components and exclude back-faces... that's the part that makes me hesitate to try to do it myself, not knowing Ruby, yet. What do y'all think?
                      Didier Bur
                      Actually you can select a face with some material, then right-click and choose 'select all with same material', then display the 'entity info' window where you'll get the corresponding area. But that's a manual process.
                      I think it will be a good starting idea for you to learn Ruby. Download some scripts related to materials and start from them.
                      DB
                        ledisnomad
                        The select all with same material only works in the current context, not in components and groups, but thanks for the suggestion.
                          Didier Bur
                          Here is a quick script that sums areas by material. It doesn't dig into groups or comps.
                          areas_mats.zip
                          DB
                            To find areas of materials inside groups/components... [pseudo-coded]
                            txt=""
                            model.definitions.each{|defn|
                              insts=defn.instances
                              num=insts.length
                              next if num==0
                              mats=[]
                              defn.entities.each{|e|
                                next if not e.class==Sketchup;;Face
                                mats << [e.material, e.area]
                              txt << num.to_s+"\n"
                              mats.each{|m| txt << m[0]+","+m[1]+"\n" }
                            puts txt
                            and so on to assemble a list of materials with areas within definitions. multiply by 'num' to get total area of all instances of each definition etc etc...........
                              Didier Bur
                              Not that simple, don't forget that instances can be scaled...
                              DB
                                I realize that but he has to start somewhere πŸ˜’
                                  ledisnomad
                                  This is great. Thanks everybody! Definitely a start that I can work with. At the moment, I don't need to worry about scaled instances of components, so I'll be able to use this and expand it's functionality as I need it. Thank you everybody.
                                    byrnebm
                                    These scripts are very useful. However, I am wondering if it is possible to go further with this to help me with what I use sketchup for. I draw a 3d floor plan of a house which is basically just lots of boxes/rooms adjoining each other. For each room I need the area of each wall and its orientation. However the orientation is from the perspective of being inside that room. So say I am inside the room and I am looking at the wall in question, the orientation of the wall is basically the direction I am facing, for example North. If I was in the room adjoining and am now looking at the same wall but from the other side of it, the orientation is now the opposite direction ie south. These scripts dont quite cater for this and I am wondering if it is even possible to make such a script. So when i click on one side of a wall its orientation is one direction but if I click on the other side of it, its orientation is the opposite direction.
