    Report face surface
    26 Posts 6 Posters 3.2k Views 6 Watching
    • EarthMoverE
      EarthMover
      TIG - You are a hell of a guy! Your generosity is truly inspiring. β˜€
      Content Creator at Skapeup
      • Didier BurD
        Didier Bur
        My 2 cents:
        This one will output the same TSV file as TIG's, but sorted by orientation, adds a sub-total per orientation and a general total at the end.
        afflitto, non parlo italiano πŸ˜„
        Enjoy!
        RelazioneFacceSortedTotal.zip
        DB
        • F
          flyman
          I could NEVER expect a so "fast-in-make" and "match-to-my-desire" script! 😍
          You can't imagine how many hour I can earn by this script... Much, much thanks to TIG and to DidierBur!
          This script-making-story has interested me in Ruby. It is difficult to learn? Because I had 20 years old a good experience in Autolisp (programming language for Autocad).
          And, abusing of you time and kindness, are there any Ruby's manual-tutorial? πŸ˜†
          Another thanks to everybody!
          flyman
          • Didier BurD
            Didier Bur
            I also had long time ago some experience with Autolisp and learned to program with it.
            Some books including tutorials can be found here: http://rhin.crai.archi.fr/rld/automatic_SketchUp.php
            some links here: http://rhin.crai.archi.fr/rld/links_ruby_sites.php
            some plugins links here:http://rhin.crai.archi.fr/rld/links_plugins_sites.php
            and last but not least: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
            If you have some knowledge in Autolip and OO programming, Ruby is quite easy to learn (IMHO).
            Regards,
            DB
            • L
              ledisnomad
              I'm always amazed at how quickly questions and requests get answered here at SketchUcation!
              This script, modified a little, is serving me well as a way to get the areas of my master plan models. However, not being familiar with Ruby, yet, I wonder what it would take to do the following: sum the area each material.
              To put it another way, I'd like a report that reads:
              There is 460.33sf of material 01.
              There is 230.15sf of material 02.
              etc.
              And it would have to work with groups and components and exclude back-faces... that's the part that makes me hesitate to try to do it myself, not knowing Ruby, yet. What do y'all think?
              • Didier BurD
                Didier Bur
                Actually you can select a face with some material, then right-click and choose 'select all with same material', then display the 'entity info' window where you'll get the corresponding area. But that's a manual process.
                I think it will be a good starting idea for you to learn Ruby. Download some scripts related to materials and start from them.
                DB
                • L
                  ledisnomad
                  The select all with same material only works in the current context, not in components and groups, but thanks for the suggestion.
                  • Didier BurD
                    Didier Bur
                    Here is a quick script that sums areas by material. It doesn't dig into groups or comps.
                    areas_mats.zip
                    DB
                      To find areas of materials inside groups/components... [pseudo-coded]
                      txt=""
                      model.definitions.each{|defn|
                        insts=defn.instances
                        num=insts.length
                        next if num==0
                        mats=[]
                        defn.entities.each{|e|
                          next if not e.class==Sketchup;;Face
                          mats << [e.material, e.area]
                        txt << num.to_s+"\n"
                        mats.each{|m| txt << m[0]+","+m[1]+"\n" }
                      puts txt
                      and so on to assemble a list of materials with areas within definitions. multiply by 'num' to get total area of all instances of each definition etc etc...........
                      • Didier BurD
                        Didier Bur
                        Not that simple, don't forget that instances can be scaled...
                        DB
                          I realize that but he has to start somewhere πŸ˜’
                          • L
                            ledisnomad
                            This is great. Thanks everybody! Definitely a start that I can work with. At the moment, I don't need to worry about scaled instances of components, so I'll be able to use this and expand it's functionality as I need it. Thank you everybody.
                            • B
                              byrnebm
                              These scripts are very useful. However, I am wondering if it is possible to go further with this to help me with what I use sketchup for. I draw a 3d floor plan of a house which is basically just lots of boxes/rooms adjoining each other. For each room I need the area of each wall and its orientation. However the orientation is from the perspective of being inside that room. So say I am inside the room and I am looking at the wall in question, the orientation of the wall is basically the direction I am facing, for example North. If I was in the room adjoining and am now looking at the same wall but from the other side of it, the orientation is now the opposite direction ie south. These scripts dont quite cater for this and I am wondering if it is even possible to make such a script. So when i click on one side of a wall its orientation is one direction but if I click on the other side of it, its orientation is the opposite direction.
                              • 2 / 2
