    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Is There Any Way to Make This?
    17 Posts 9 Posters 1.1k Views 9 Watching
      Catmando
      http://upload.wikimedia.org/wikipedia/commons/0/09/Strasburg_muenster_rosette_westfassade.jpg
      See those cinquefoils in the corners of that window? I know how to draw those in Sketchup (I was also able to make trefoils and quatrefoils), but I can't figure out what the darn radius for the thing would be. As you can see, they're the optimal size available for a circle in the area provided. Any suggestions on how to do this? I'm still a newbie when it comes to stuff like this... so help is much appreciated. 😄 Thank you!
        First of all, I would use a circle with a segment count that is divisible by ten (around the cinquefoils, there are those ten pikes or what that should conveniently adjust to the segment count of the surrounding circle). Then of course you still need some bulging - say at least 3 segments between each - that would be 30 segments for a circle. Or 40 maybe but considering the overall complexity of the whole shape, I would not go over that.
          Catmando
          Thanks for the suggestion on the segment number; by default, I use powers of 2, but I'll go with 30. Still not sure how I would go about making the circle, though, which was my original question (sorry if it was unclear). I can't figure out how to find the center point nor the length of the radius (although I could make it if I had either). In case you're curious, I'm assuming the diameter of the main circle is 16 units.
            Just to clarify; we are talking about the four, smaller things in the corners now, right? (Otherwise quite strange shape; the main, big circle has 16 "petals" and it would be extremely hard to combine it with a number of 30).
            I also like the way SU currently has the segment count as it is conveniently divisible with many things (but 5)
            So you ean you cannot find the centerpoint of the circle? Or cannot define a radius or it?
              d12dozr
              So the circle needs to be tangent to the 3 points of contact...maybe this will help?
              Tig's True Tangent http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
              http://goo.gl/f7ooYh
                Khai
                maybe these will help?
                http://www.slideshare.net/ozi/drawing-a-cinqefoil
                • EscapeArtistE Offline
                  EscapeArtist
                  I wouldn't know how to calculate the radius or diameter to fit into the specific area, but I fooled with the geometry until I found a working method. I figured medieval architects were fond of arcs and circles to create things, so it should be possible to decipher it with the same tools. It calculates to 0.574468085106383 of the distance which is a bit useless of a number, but to make it fit perfectly I just used lines and circles. Basically 3 circles to midpoints, and then selecting another midpoint. I tried it with varying segment counts and it worked every time. Here it is:
                  • Jean LemireJ Offline
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas:
                    Tangent circles.skp
                    Tangent circles V7.skp
                      Catmando
                      @jean lemire said:
                      Hi folks.
                      Perfect! 😄 Thank you! That helped a lot. Everything is much clearer now. Also, d12dozr, interesting plugin. I'll try it out sometime. 😉
                        mac1
                        catmando
                        A tip.
                        I cannot open Jena's post since still on 7 so hope this is not a repeat
                        "They" had a compass also.
                        Consider this: You can inscribe a circle in a triangle by bisecting its angles and this will give the circles center.( Jean has a very creative way to do this. (Rotate one side to other and then /2). For the corner case this makes it very easy. For the smaller ones the question is where are the tangents points unless you want to make your model with many segments. In either case remember there are no real tangents in SU ( have not looked at TIG's true tangent plugin however). The reason I say this is the definition of a tangent is: " The limit of line through points 1 and 2 on a curve as point 2 approaches point 1". For SU you will get two different answers ( ie different line slopes ) as you approach a vertex from one direction vs another and therefore tangent does not exist. 😕
                          Jean Lemire
                          Hi folks.
                          V7 added in my previous post.
                          Best regards.
                            mac1
                            Jean thanks
                            Old school really helps.
                            I see getting second circle with triangle only problematic in finding the tangent points
                            • Wo3DanW Offline
                              Wo3Dan
                              @mac1 said:
                              ..... For SU you will get two different answers ( ie different line slopes ) as you approach a vertex from one direction vs another and therefore tangent does not exist. 😕
                              @mac1,
                              For informative purpose see attached file.
                              The "real" tangent in a vertex of the segmented arc in SU is easy to find.
                              Rotate/copying one segment_extention towards the other segment and then apply dividing technique ( type /2 [Enter] ).
                              Zoom in on the vertex through scene 1->5. Each subsequent smaller arc is created on a "parent" larger segment by the magenta tangent arc.
                              I'm not quite sure if your answer contradicts this tangent technique so.... the model is for informative purpose.
                              Thanks Jean for your excelent solution.
                              Tangent construction in detail
                              • mitcorbM Offline
                                mitcorb
                                @Wo3Dan:
                                Your skp is in version 8, even though your profile says you use version 7. I attempted to download and found this out.
                                • Wo3DanW Offline
                                  Wo3Dan
                                  @mitcorb said:
                                  @Wo3Dan:
                                  Your skp is in version 8, even though your profile says you use version 7.......
                                  How stupid of me, thanks for letting me know. Here's version7 file.
                                  (I'll change my profile to SU8)
                                  Same model in version SU7
                                  • mitcorbM Offline
                                    mitcorb
                                    Believe me, sir. Stupid is not a word I would associate with you. You help so many here. 👍 😄
                                      Catmando
                                      Hey guys! Just stopping by and sharing how the third circle came to be:
                                      http://img96.imageshack.us/img96/1656/rosewindowscreenshot1.png
                                      You can probably trace what I did here... I was following Jean Lemire's guide (thank you very much for that, by the way!) and found a pretty simple method. I drew the tangent of the first circle you suggested I use and then drew a line from the radius of the second circle off to the right along the red axis. I found the radius of the third circle was exactly one-half the radius of the second, so I made a line of that distance and aligned it to the green axis at the point where the tangent and the radius-line-thingy met. The other end of that line was the center of the circle, and from there I drew the shape. 😄
                                      That may be unclear, and if so, I apologize... I didn't bother to label the lines or anything. The only thing that bothers me is that the first and third circles don't exactly meet up, but it's understandable considering they're all using under 40 sides. It's not very noticeable from afar anyway.
