    Is There Any Way to Make This?
    17 Posts 9 Posters 1.6k Views 9 Watching
    • Jean LemireJ
      Jean Lemire
      Hi folks.
      See this SU file for ideas:
      Tangent circles.skp
      Tangent circles V7.skp
      • C
        Catmando
        @jean lemire said:
        Hi folks.
        Perfect! 😄 Thank you! That helped a lot. Everything is much clearer now. Also, d12dozr, interesting plugin. I'll try it out sometime. 😉
          mac1
          catmando
          A tip.
          I cannot open Jena's post since still on 7 so hope this is not a repeat
          "They" had a compass also.
          Consider this: You can inscribe a circle in a triangle by bisecting its angles and this will give the circles center.( Jean has a very creative way to do this. (Rotate one side to other and then /2). For the corner case this makes it very easy. For the smaller ones the question is where are the tangents points unless you want to make your model with many segments. In either case remember there are no real tangents in SU ( have not looked at TIG's true tangent plugin however). The reason I say this is the definition of a tangent is: " The limit of line through points 1 and 2 on a curve as point 2 approaches point 1". For SU you will get two different answers ( ie different line slopes ) as you approach a vertex from one direction vs another and therefore tangent does not exist. 😕
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            V7 added in my previous post.
            Best regards.
              mac1
              Jean thanks
              Old school really helps.
              I see getting second circle with triangle only problematic in finding the tangent points
              • Wo3DanW
                Wo3Dan
                @mac1 said:
                ..... For SU you will get two different answers ( ie different line slopes ) as you approach a vertex from one direction vs another and therefore tangent does not exist. 😕
                @mac1,
                For informative purpose see attached file.
                The "real" tangent in a vertex of the segmented arc in SU is easy to find.
                Rotate/copying one segment_extention towards the other segment and then apply dividing technique ( type /2 [Enter] ).
                Zoom in on the vertex through scene 1->5. Each subsequent smaller arc is created on a "parent" larger segment by the magenta tangent arc.
                I'm not quite sure if your answer contradicts this tangent technique so.... the model is for informative purpose.
                Thanks Jean for your excelent solution.
                Tangent construction in detail
                • mitcorbM
                  mitcorb
                  @Wo3Dan:
                  Your skp is in version 8, even though your profile says you use version 7. I attempted to download and found this out.
                  • Wo3DanW
                    Wo3Dan
                    @mitcorb said:
                    @Wo3Dan:
                    Your skp is in version 8, even though your profile says you use version 7.......
                    How stupid of me, thanks for letting me know. Here's version7 file.
                    (I'll change my profile to SU8)
                    Same model in version SU7
                    • mitcorbM
                      mitcorb
                      Believe me, sir. Stupid is not a word I would associate with you. You help so many here. 👍 😄
                      • C
                        Catmando
                        Hey guys! Just stopping by and sharing how the third circle came to be:
                        http://img96.imageshack.us/img96/1656/rosewindowscreenshot1.png
                        You can probably trace what I did here... I was following Jean Lemire's guide (thank you very much for that, by the way!) and found a pretty simple method. I drew the tangent of the first circle you suggested I use and then drew a line from the radius of the second circle off to the right along the red axis. I found the radius of the third circle was exactly one-half the radius of the second, so I made a line of that distance and aligned it to the green axis at the point where the tangent and the radius-line-thingy met. The other end of that line was the center of the circle, and from there I drew the shape. 😄
                        That may be unclear, and if so, I apologize... I didn't bother to label the lines or anything. The only thing that bothers me is that the first and third circles don't exactly meet up, but it's understandable considering they're all using under 40 sides. It's not very noticeable from afar anyway.
