    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      @rv1974 said:
      But don't make it a separate tool. Insert it in the cleanup. Those rubies pullulate like cockroaches ๐Ÿ™‚
      I was planning on adding it to Edge Tools. One completely automatic, one where on can inspect, like solid inspector.
      Could add the automatic version to CleanUp3.
      • plot-parisP Offline
        plot-paris
        oh, will that be in the near future?
          CleanUp 3 and Edge Tools 2 will be out next week. ( And the feature of closing small caps will be in Edge Tools. )
          • Z Offline
            Zenhipster
            Tested the plug-in here on such a model. Does not work.
            Inside a lot of extra polygons.
            magicube
              There's nothing to clean up there. There's not a single line that is not part of the components (which are all perfectly solid so cannot be any stray geometry in them).
              If you want to get rid of the separating edges/faces, you need to explode the whole thing first and run another plugin:
              http://forums.sketchucation.com/viewtopic.php?f=180&t=12668&p=92295#p92295
              (Nice model, by the way!) ๐Ÿ˜‰
              • jason_marantoJ Offline
                jason_maranto
                Or you could just use the "outer shell" command from the solid tools in Sketchup 8.
                Best,
                Jason.
                • honoluludesktopH Offline
                  honoluludesktop
                  @zenhipster said:
                  ............ Inside a lot of extra polygons.
                  If you are trying to remove the polygons "out of view", this app will not do that.
                    ๐Ÿ‘
                      Well, had a closer look. Neither solution will work properly as the pieces are not aligned correctly (there are extremely small but gaps)
                      • Arty2A Offline
                        Arty2
                        Not sure if it's the proper thread for this tip, but here goes.
                        Wow, it looks promising. One suggestion, though: you could use big buttons instead of radio buttons and check-boxes. Such elements need more precision to click them (because they are small) and when using such plugin several times it can come more handy.
                        This was a request about v3 in another thread, that is very easily solvable by just using some proper HTML and keeping the radio buttons / checkboxes too.
                        Just make use of the <label> tag like this:
                        <label for="idname">Descriptive text here; <input type="radio" name="whatever" id="idname" /></label>
                        and that should keep everyone happy ๐Ÿ˜„
                          That it uses already, and thatรฆs what the initial v3 will be using. ๐Ÿ˜„
                          • Arty2A Offline
                            Arty2
                            That's great then, you should advertise it as "click the text and the checkbox is magically selected"
                            Keep it up mate :]
                              Keep it up mate :]
                              I'll be doing a video presentation.
                              Another issue with the UI is displaying extra information. At the moment I use tooltips for each element, but I want to provide a better interface for this as well. But now I just need to get this first version out, otherwise it'll never be done.
                              (Btw, you're a webdesigner? Scripter/programmer? Doing any SketchUp plugins?)
                              Cheers!
                                Version 3
                                • New UI
                                • More cleaning
                                Remember to update TT_Lib2
                                  Thanks Thom
                                    Been playing and love the new %/Timer feature ๐Ÿ‘
                                    Ban witheld...temporarily
                                    • boofredlayB Offline
                                      boofredlay
                                      Nice update. Thanks.
                                        mac1
                                        ThomThom
                                        a QUESTION:
                                        Possibility of " other" errors. I don't know what the program float is, single, double etc but a 32 bit float only has a equivalent 24 bits. See IEEE 754 single precision floating point. In addition the Taylor series expansion, or what ever is used, of the arc trig functions could come into play althought I doubt you are using that??
                                        • srxS Offline
                                          srx
                                          Thank you for this very useful plugin.
                                          www.saurus.rs
                                            blajnov
                                            Thank you very much for the update, but downloading SketchUP Pro v.8, an error ...
                                            • 11
                                            • 48
                                            • 49
                                            • 9 / 49
